I want to monitor the charging and voltage of my main battery.
What is the best way to do this?
Grant
Battery monitoring
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: Battery monitoring
Eyeman wrote:I want to monitor the charging and voltage of my main battery.
Grant
for how long do you want to do this?
- Town: Jeffreys Bay
- Vehicle: Hilux KZ-TE D/C 4x4
- Real Name: Grant
All the time. I was thinking of installing guages - voltmeter and ammeter?
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Eyeman wrote:All the time. I was thinking of installing guages - voltmeter and ammeter?
Grant I put in the National Luna battery monitor, you can get it for a single or 2 batteries, you can switch of the LED if you want and it also has an alarm on under/over voltage
- Dualmonitors_sm.jpg (8.25 KiB) Viewed 1446 times
Voltmeter is easy to install. Just connect in parallel to your device. An ammeter is a bit of a problem. You either have to connect it in serie or you have to make use of a shunt.
Strictly speaking don't think you need an ammeter as you can always calculate the current if you have the ratings of the devices.
I personally don't like the natianal luna or any other volt meters that show you the voltage by means of LED's. I prefer a digital or even analogue read out so I have the exact voltage.
