Anti Freeze
Witlorrie
Town: Citrusdal
Vehicle: 2002 Hilux KZTE
Real Name: Jacques
Wed Oct 21, 2015 7:34 pm
Might be a stupid question,is it wise to fill your whole cooling system with anti freeze? I am in the process of replacing my KZ TE 2000 model radiator and if there are no negative consequences I want to do it. Second question, what is the capacity of KZ TE cooling system.
Thanks in advance for your replies, not sure whether this is the right place for the post.
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Wed Oct 21, 2015 8:52 pm
Never fill your system with pure undiluted anti freeze
Follw the instructions on the bottle.
http://articles.orlandosentinel.com/198 ... lycol-pure
Thu Oct 22, 2015 6:22 am
Do yourself a favour and buy Toyotas premixed antifreeze (the ones that's pink in colour). It will protect the inside of the engine (no rust) and also has a lubricating effect on the seals. And if you should pick up a leak, it is easy to spot as it leaves a residue
scott west
Vehicle: 93 Hilux
Real Name: Z
Club VHF Licence: HC 117
Thu Oct 22, 2015 7:51 am
CasKru wrote:Do yourself a favour and buy Toyotas premixed antifreeze (the ones that's pink in colour). It will protect the inside of the engine (no rust) and also has a lubricating effect on the seals. And if you should pick up a leak, it is easy to spot as it leaves a residue
+1, and it is more or less the same price as Castrol's premix.
'93 Hilux 4Y EFI
Town: inniedorp
Vehicle: Toy
Thu Oct 22, 2015 8:15 am
and CASTROL manufactures and packages it for Toyota ... :siffler:
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Thu Oct 22, 2015 8:40 am
Good Advice...
HABOOB means "Dust Storm"
Thu Oct 22, 2015 9:10 am
True... but I paid cheaper at Toyota than at Midas for the Castrol branded one :thumbup: :thumbup:
Knuppel
Town: White River
Real Name: Marius
Thu Oct 22, 2015 9:46 am
The only problem with OEM premix is the fact that it causes the cauliflower effect under the rubber hoses where it attaches to the alli pipes. Other than that it is brilliant and expensive
Thu Oct 22, 2015 2:00 pm
Also check with VW or Audi for their pink antifreeze. It is undiluted and was about half the price of the pre-mixed Toyota antifreeze
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Thu Oct 22, 2015 2:25 pm
You get Castrol Radicool in concentrate and premix. I think the concentrate works out quite cheap.
Witlorrie
Town: Citrusdal
Real Name: Jacques
Thu Oct 22, 2015 8:14 pm
Thanks for the info guys, this coming weekend it will be operation fitting a new radiator.
Regards
JohanM
Town: Parys
Vehicle: Prado 120 4.0 V6
Club VHF Licence: X45
Thu Oct 22, 2015 8:45 pm
Knuppel wrote:The only problem with OEM premix is the fact that it causes the cauliflower effect under the rubber hoses where it attaches to the alli pipes. Other than that it is brilliant and expensive
Marius, I have never experienced this with a vehicle that was running from new on the OE antifreeze. It did however happened on my Hilux which was running rusty water when I bought it. So I can say that when corrosion has started it certainly can cause some more "cavities" but despite that, never had a leak. So I will stay with it.
Thu Oct 22, 2015 9:26 pm
Mars wrote:Also check with VW or Audi for their pink antifreeze. It is undiluted and was about half the price of the pre-mixed Toyota antifreeze
The advantage of sticking to the premix is you can always just top-up with premix again and the ratio will always be spot on. If you buy concentrate and have to add fluid to your system, you are never 100% sure if you have the correct ratio
Town: inniedorp
Vehicle: Toy
Fri Oct 23, 2015 7:03 am
worth adding - few years back the engine of my mom's car was completely rebuilt. For some stupid reason they did not put anti-freeze in. SIX MONTHS later the radiator was full of rusty water. Took a LOT of flushing to get the system clean again !!
Yes, certainly "anti-freeze" is part of the game, but do not underestimate the "anti-corrosion" properties of these additives :thumbup:
Toyota or Castrol, just get a quality product and use as per the mixing instructions.
Mon Oct 26, 2015 10:13 am
I hate paying for their water. When the system is completely drained it is easy to get the mix right. I dilute the concentrate at the right ratio before I top up.
Town: inniedorp
Vehicle: Toy
Mon Oct 26, 2015 10:58 am
worth just topping up and testing with plain water first .....
can get expensive if you have a small leak (loose hose clamp) ...
Then drain and fill with the mix
Borntofish
Vehicle: Hilux 86
Real Name: Werner
Mon Oct 26, 2015 1:13 pm
I fork out the money for the Toyota premix. I used to put the green stuff in my 22R and it corroded the pipes away.
Must have had the ratios wrong as Cassie implied.
