BashPlate
- frik
- Town: Boksburg
- Vehicle: KZTE 3.0 4x4
- Real Name: Frik van Dyk
BashPlate
I have decided to build a Bashplate this weekend . I used 6mm steel and even if I have to say it myself it looks really good. I am looking for a place in Boksburg are that can do sandblasting an powder coating if anybody can help please.
Will post pics as soon as I have done the above
Re: BashPlate
Agreed Cassie, powdercoating wont last, but on the other hand 6mm steel will take a while to rust away.. Veral in Boksburg...CasKru wrote:Is dit nie beter om hom te laat passivated nie?
- 2.8 d/cab SFA
- Town: Boksburg
- Vehicle: Yamaha R1
- Real Name: John
Re: BashPlate
Hey frik, once done let me know how much, Also want to one, but too expensive if you buy.
John
- frik
- Town: Boksburg
Re: BashPlate
John so far it only cost me a few welding rods and cutting disks. I got this plate a long time back from a friend (It was suppose to be a plate for a chinese braai) On Saturday morning I discovered this plate 600mm x 500mm and the lights came on. Myself and my youngest son decided to give it a try.2.8 d/cab SFA wrote:Hey frik, once done let me know how much, Also want to one, but too expensive if you buy.
What I did was actually very simpel I cut the plate 80% through then bend it and tag it. Then the next bend and finally I aligned the plate and drilled new holes through the bumber so basically this bash plate is mounted directly to the chassis.
Then the not so lekker job started I drilled 50mm holes and 32 mm holes and believe me doing this on a 6mm plate is not easy.
Then weld and polish and it fits perfectly and it looks really good.
I listen to what you guys are saying but I prefer black powder coating as the two main colours on the bakkie is black and white.
I found a place will take the plate in this afternoon for sandblasting and powder coating
Re: BashPlate
Cool Frik, now please plak a prenkie for us guys what cant imagine what it looks like... 8 )
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: BashPlate
John, on the SFA you dont really need a bashplate for the engine as it is basically protected by the axle itself underneath it. I have found that the standard plate is there more for heat dissapation and to keep the grass out the v-belts than to physically protect the engine and radiator itself as these are mounted up higher and better protected than most IFS vehicle's that need a bash plate to protect steering arms ect.2.8 d/cab SFA wrote:Hey frik, once done let me know how much, Also want to one, but too expensive if you buy.
Re: BashPlate
Agreed Johan, and for an SFA you can make one from light weight alu-tread plate.JohanM wrote:John, on the SFA you dont really need a bashplate for the engine as it is basically protected by the axle itself underneath it. I have found that the standard plate is there more for heat dissapation and to keep the grass out the v-belts than to physically protect the engine and radiator itself as these are mounted up higher and better protected than most IFS vehicle's that need a bash plate to protect steering arms ect.
- 2.8 d/cab SFA
- Town: Boksburg
- Real Name: John
Re: BashPlate
Thanks, makes sense, it has aplastic cover at the bottom, I will just replace with alu plate to bit more sturdy.
Thought of bash plate as Land Rover have that bar in front underneath
John
- frik
- Town: Boksburg
Re: BashPlate
This is how I did it but the photo doesnt do justice to the job.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: BashPlate
Job well done
- Town: jhb
- Vehicle: 95 hilux
- Real Name: jonathan
Re: BashPlate
now you wont have to worry about breaking your diff when driving over taxi's
- frik
- Town: Boksburg
Re: BashPlate
John believe that would give me the pleasure of my life to do that once :Djontheron wrote:now you wont have to worry about breaking your diff when driving over taxi's
Thanks for the compliments it surely is stirdy
- Niel
- Real Name: Niel
Re: BashPlate
Frik, was there any scientific thought process in the placement of the holes and number of them as it could possibly prevent airflow and therefore create more heat?
Nice plate. Can you also take a pic sfrom the side so we can see the shape a bit better (if you don't mind)
- Piesang
- Town: Grabouw
- Real Name: Pieter Pieterse
Re: BashPlate
Dit lyk baie goed.
Jy het nie ook 'n foto van die bumper nieNice plate. Can you also take a pic sfrom the side so we can see the shape a bit better (if you don't mind)
- frik
- Town: Boksburg
Re: BashPlate
Neil with all this rain its dark when I get home in the afternoons but will take more detailed photos this weekend. No I drilled as many holes 50mm and 32mm as I could fit in without weakning the plate . The reason why I drilled them was to get rid of extra weight and the for airflow spesifically where the radiator sits. I honestly dont think I will have a overheating problem as the airflow is more than sufficient and also with the scoop on the bonnet I believe the required airflow takes place.Niel wrote:Frik, was there any scientific thought process in the placement of the holes and number of them as it could possibly prevent airflow and therefore create more heat?
It was a very sinmple way to build this its just the weight of the plate that is not easy to handle but the further you go the more steel you cut off and the easier it becomes to work with it.
Anybody needs help ask and I will try my best
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Re: BashPlate
Good job Frik, I saw that when I moved my intercooler & made a new bashplate, there is a lot of wasted space above it. Looks like a cool place to mount a airtank...
- frik
- Town: Boksburg
Re: BashPlate
Thanks Bushwacker dont give me ideas :D airtank for what use for a locker or to inflate tyresBushwacker wrote:Good job Frik, I saw that when I moved my intercooler & made a new bashplate, there is a lot of wasted space above it. Looks like a cool place to mount a airtank...
- Bushwacker
- Real Name: Piet
Re: BashPlate
U gotit
