17" wheels with 33" tyres for 2008 Vigo
stumps
Town: Alberton
Vehicle: Toyota 4.0L D/C 4x4; Camil
Real Name: Marius
Club VHF Licence: X225
Thu May 21, 2015 11:59 pm
Hi all. Does anyone know if it is possible to put 17" wheels with 33" tyres on a 2008 Vigo. Noted that they came out with 15" tyres and the 31" tyres just don't scrape?
2008 Hilux 4.0L 4x4 (Mufasa)
Toyota 4.0L D/C 4x4; Camil suspesion, Long Range tank, Kilber snorkel
1Co 15:10
But by the grace of God I am what I am: and his grace which was bestowed upon me was not in vain;
http://www.sandriver.co.za" onclick="window.open(this.href);return false; http://www.travelconsortium.co.za" onclick="window.open(this.href);return false;
TOYODA
Vehicle: '89 YN67R with Ford V6 3.0
Real Name: Tiaan
Fri May 22, 2015 12:47 am
Stumps,
With enough time and money anything is possible. :think:
I've read that to run 33x12.5R17 you will need to lift the body and suspension by around 125mm and the rims need to be 8J or 9J and have a negative offset of -5mm or more.
A hammer might also come in handy to push back the pinch weld on the back of the inner fender. Tires will stick stick out by 60mm or more, depending on the offset of the rims. Your biggest problem will be the width of the tire, this is why you will have to lift the Lux to get clearance.
There might be someone with more knowledge regarding this subject, but this was the info I got when I played around with the same idea. 33's on a manual will not be a big problem, but the auto will suffer.
255/85x16 (33.1x10R16) will be a better option. Rims with a +20mm offset and a 3" lift will work. You will need to remove the front mudflaps and trim a bit of body panels.
CMK
Town: Ficksburg
Vehicle: Toyota Hilux 3L D4D 4x4
Real Name: CM
Thu Sep 22, 2016 11:47 am
Ek het 'n 2011 3L D4D D/cab 4x4 met OME suspensie. Ek speel met die gedagte om 285/75/16 op die standard rim te sit. Het enige iemand dit al probeer?
CM Kotze
stumps
Town: Alberton
Real Name: Marius
Fri Sep 23, 2016 7:43 am
Ek het gister 305 65 17 opgesit, maar moet 25mm adapter plate ook op voorkant sit. Die bande raak aan die arm aan die binnekant
Sent from my SM-G930F using Tapatalk
1Co 15:10
CMK
Town: Ficksburg
Real Name: CM
Fri Sep 23, 2016 5:07 pm
Dankie, dink daaraan om dalk spacers voor en langer shackles agter op te sit.
CM Kotze
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Sat Sep 24, 2016 2:46 pm
Why 17!? 285s will fit with either a 3 inch suspension lift or like myself a 2 inch suspension lift and a 2 inch body lift. I run zero offset steelies but you'll get away with p10. You'll want ya grinder and welder handy to do a body mount chop and there'll be some trimming and flogging of the flare, inner guard and body.
segalmarisa
Vehicle: hilux
Real Name: segal
Sun Oct 15, 2017 8:47 am
TOYODA wrote:Stumps,
Not everybody’s cup of tea. But I love my 255/85-16(33x10.5)
pieta.swanepoel
Vehicle: Toyota Hilux SRX 2.5D-4D 4x4 SC
Real Name: Pieta
Sun Oct 15, 2017 3:36 pm
Segal, are you running those tires with a standard setup or raised suspension?
segalmarisa
Vehicle: hilux
Real Name: segal
Sun Oct 15, 2017 11:21 pm
pieta.swanepoel wrote:Segal, are you running those tires with a standard setup or raised suspension?
I’ve raised the suspension Profender Shocks with my own setup on the coils. Sort of a mix between ironman coil design and profender a coil design. Roughly about 60mm of lift I think. Total clearance under bashplate with those tyres is around 340mm. Castor does have be be pushed forward tho to stop any scrubbing on the rear of the fender otherwise they work very well. Busy having rims modified with more offset to give it a beefier look not sure how that’s going to affect the clearance tho.
segalmarisa
Vehicle: hilux
Real Name: segal
Sun Oct 15, 2017 11:24 pm
[IMG]//uploads.tapatalk-cdn.com/201710 ... 48d557.jpg[/IMG]
There is a slightly better side view
