Aftermarket bumper
Jurgen10
Vehicle: 2009 Hilux 4.0 V6 Raider DC 4x4
Real Name: Jurgen
ORRA Call Sign: HC239
Thu Sep 29, 2016 3:42 pm
So, I am planning to fit an aftermarket bumper after a minor altercation in traffic, but don't want to drive down hill the whole time...
Who has fitted an aftermarket bumper, and were you then also compelled to fit spacers to lift the nose because of the extra weight (Without a winch)
Are the standard front coils on a vigo stiff enough to carry the additional load?
I had an ARB on a previous vehicle, but it had torsion bars which we then adjusted to raise the nose.
Lomies
Vehicle: 2013 3.0 D4D D/C 4x4 Hilux
Real Name: Arné
ORRA Call Sign: HC273
Thu Sep 29, 2016 3:48 pm
Hi Jurgen. The coils springs will be able to handle the extra weight (depending on what bumper you fit) but it will pull the nose down. Fitting spacers will be better. Doing a suspension upgrade will be the best thing to do.
mossie89
Town: Paarl
Vehicle: Toyota Hilux D/C 4x4 4.0 v6
Real Name: Riaan
Thu Sep 29, 2016 5:50 pm
I fitted a Iron bullbar and had to lift the nose of the vigo again, just the spacers did not do the job. 4x4 Direct orderd some coil spings from Mikem and togeter with the spacers, whala. Best investment ever
Mossienel
Town: Paarl
Vehicle: Hilux 2011 2.5d4d DC 4x4
Thu Sep 29, 2016 8:51 pm
Had to lift my nose with 25mm spacer in the front aswell after fitting myne.
Sent from my SM-G900F using Tapatalk
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Thu Sep 29, 2016 11:45 pm
Get the suspension done properly!
Image Link Broken
Jurgen10
Real Name: Jurgen
Fri Sep 30, 2016 7:33 am
Thanks guys, what did you hit that caused the whole strut to bend like that ... ?
lukestoyzx
Town: Griffith
Real Name: Luke
Fri Sep 30, 2016 8:20 am
Nothing!!! Just driving down the road, went through a dip in the road and the suspension went down and didn't come up! This caused by installing strut spacers! They allow the strut to bottom out before the lca contacts bump stop causing the shock to bend or snap!
LouisZ
Fri Sep 30, 2016 10:56 am
Shock to bend like that because of the spring was under pressure(spring was compressed too much), look like 50mm spacers. That would give a lift of 100mm. Also cause side shaft angles to be out.
If you fit spacers nothing more than 25mm.
lukestoyzx
Town: Griffith
Real Name: Luke
Fri Sep 30, 2016 11:24 am
They r 30mm spacers. No matter what size you gamble with putting in ya playing with fire. Only safe way to use then is to extend your bump stops accordingly.
Jurgen10
Real Name: Jurgen
Sun Oct 02, 2016 5:32 pm
Fitted the BZT on friday.
Thank you Bruce, I must say fitting the bumper at the factory, you can see the amount of work going into their products. Next on the wishlist is a set of BZT rocksliders.
Sent from my E5603 using Tapatalk
Jurgen10
Real Name: Jurgen
Sun Oct 02, 2016 5:39 pm
[img]//uploads.tapatalk-cdn.com/2016100 ... b7aea5.jpg[/img]
rood
Town: Polokwane
Vehicle: 3l KZTE, 3L Extra cab D4d 4x4, Suzuki SJ413
Real Name: rood
Sun Oct 02, 2016 6:30 pm
Jurgen, as ek mag vra, wat het jy betaal vir die bumper?
Jurgen10
Real Name: Jurgen
Mon Oct 03, 2016 12:35 pm
Die versekering het betaal :P
Die pryse het die 1ste oktober op gegaan.
Gaan loer gerus op http://www.summit4x4.co.za" onclick="window.open(this.href);return false; hulle pryse is baie goed vir wat mens kry in my opinie.
