Vigo exhaust 76mm - advice needed.
muki
Real Name: Mohamed
Mon Dec 05, 2016 12:16 am
I'm looking at upgrading my exhaust. I've got 09 hilux at with unichip in tuned by ksd. They recommended that with 76mm exhaust I would be able to push a bit more power safety.
Is there any disadvantages to fitting 76mm? Who in cape town would you recommend? And should it be done from the downpipe? Cat removed?
Sent from my 2014817 using Tapatalk
JohanW
Town: Strand
Mon Dec 05, 2016 5:04 pm
Muki, just be careful that you don't make that free flow too flowy. I made mine flow verrrrry well. Too well actually and now I get a intermittent (once every 3 months with ambient between 14-16 deg C) P1251 error and subsequent limp mode requiring a shutdown, wait 30sec and start to clear the error.
The stepper motor can't adjust fast enough to prevent a pressure spike in the intake manifold. This happens when you go from coasting/idling behind a truck and floor it it to go past. Not so nice when you go into limp mode then...
But since you mention that you have a chip. Its possible to have the boost threshold level moved or the P1251 error parameters adjusted.
I'm still stuck with a racechip while the unichip is lying in the drawer waiting to be fitted when the world turns a bit slower. I will do a post when the unichip gets fitted and resolves my problem.
So in short, it is possible to have the D4D flow too much. I must add I have a automatic and it seems to be a little more prone to get this P1251 error.
muki
Real Name: Mohamed
Mon Dec 05, 2016 5:45 pm
JohanW wrote:Muki, just be careful that you don't make that free flow too flowy. I made mine flow verrrrry well. Too well actually and now I get a intermittent (once every 3 months with ambient between 14-16 deg C) P1251 error and subsequent limp mode requiring a shutdown, wait 30sec and start to clear the error.
Thanks, I'll definitely keep this in mind. I'm thinking one. Or 2 boxes as I don't want it to be too noisy.
What type of power gains did you get? And who done your exhaust for you?
JohanW
Town: Strand
Mon Dec 05, 2016 10:56 pm
Power gains... No idea. Turbo lag is gone though which makes quite a difference if you know how sluggish takeoff normally is with the AT. Need to get it on the dyno which will happen in the new year when I fit the dastek chip. Kept the original downpipe, since that is nice and big already. Then a single 67mm powerflow box and out the side in front of the right rear wheel. Not loud at all. Just a hearty grumble when the turbo vanes open up. 67mm pipe used from box onwards.
Kaaskrul
Town: Port Elizabeth
Vehicle: 2018 Hilux X-Cab 4x4 Dakar
Real Name: Pierre
Sun Dec 18, 2016 1:13 pm
KSD did my 76mm exhaust. De Graaff bolt on kit. From turbo to the back.
Pulls like a freight train, also with the Unichip.
Go for it!!
JohanW
Town: Strand
Mon Dec 19, 2016 3:21 pm
Kaaskrul wrote:KSD did my 76mm exhaust. De Graaff bolt on kit. From turbo to the back.
Go for it!!
Pierre is your D4d a Auto?
muki
Real Name: Mohamed
Mon Dec 19, 2016 7:48 pm
Go for it!!
When did you have it done? Last time I spoke to ksd they sent me to noise boys.
Can I ask how much it was? Can PM me if you prefer?
Brent Morris
Vehicle: Toyota hilux 3 d4d 4x4 double cab
Real Name: Brent
Wed May 10, 2017 8:33 am
Go for it!!
Hi kaaskrul what Toyota u got I also want to go the degraff 76mm route but don't have a chip my hilux is a 2007 3.0 d4d will it be a problem as mine has 260k on the clock and I don't want to put more strain on a older model with high kilometres. Did u notice more power and better fuel economy as I can't get better than 8.5 k per litre think my exhaust is blocked as my hilux is a bit sluggish I have a pedel booster in as well . I am on what's app if u want to contact me 0826952481 would like to see his you system looks if possible thanks Brent
Sent from my SM-G935F using Tapatalk
Die$eL
Town: Midrand
Real Name: Nishan
Wed May 10, 2017 12:36 pm
If I may ask, what was the cost of the degraaf system?
Real drivers use three pedals
muki
Real Name: Mohamed
Thu May 11, 2017 4:08 pm
I fitted 76mm exhaust system from noise boys yesterday on vigo. Sounds lovely and pulls nicely. Will be going to ksd by end of the month.
Omo
Vehicle: Ford Ranger super cab 3.0 xlt 4x4
Club VHF Licence: HC236
Sun May 14, 2017 3:02 pm
What did the exhaust system cost?
There a two kind of people. Those who pushes a door when it says pull and they who pull a door when it says push.
muki
Real Name: Mohamed
Tue May 16, 2017 9:08 pm
R3500
RiyadhFortuner
Town: Lansdowne
Vehicle: 2015 Ford Ranger T6
Real Name: riyadh
Wed May 17, 2017 9:33 am
Would fitting just a freeflow box have any influence?
That way there is still some restriction but with better flow.
muki
Real Name: Mohamed
Wed May 17, 2017 1:06 pm
There isnt really a consensus from everyone I spoke to. but from the various discussion I had the following seems to be most likely.
1. The catalytic converter will give a big restriction, so removal of this would be ideal.
2. Pipe diameter does not matter much on a turbo diesel, hence you can go as big as 76mm. NA petrol engines need their exhaust matched to the engine.
3. Mandrel bends are best.
4. The box does play a role, but seems to be less important than the catalytic converter or pipe diameter.
5. Major benefit of fitting bigger exhaust is reduction in EGT. And dont forget the lovely noise it makes :D
I may be wrong, so dont take my word on it, but this would be my opinion from the short amount of research I done.
RiyadhFortuner
Town: Lansdowne
Real Name: riyadh
Thu May 18, 2017 9:17 am
Awesome Thanks. I am very familiar with petrol engines, setups etc. Diesel is new to me.
muki
Real Name: Mohamed
Tue May 23, 2017 4:14 pm
Dyno results after remap [IMG]//uploads.tapatalk-cdn.com/201705 ... 03e701.jpg[/IMG]
RiyadhFortuner
Town: Lansdowne
Real Name: riyadh
Wed May 24, 2017 11:10 am
Nice 5.3kw increase
