Camil or Mikem?
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
- Club VHF Licence: M18
Camil or Mikem?
Hi Guys
Coming from a SFA im a bit shocked at howlow the D4D front nose is and so something needs to be done on an otherwise great bakkie.
Have been reading the threads and have decided on either camil from suspension which apparently will give me 60mm lift for Approx R4000 or Mikem which will give me 50mm for R2500.
Im not interested in extremes just want to stop hitting rocks with the bakkie in the veld!
Your comments on the choice?
Re: Camil or Mikem?
Fit Mikem... and light up a Camel!
Luke the lift specs given are when the suspension is new, no matter what you fit, OME, Kameel, Mikem... it will settle and later(hopefully much later) sag... conservatively rather think you are going to get a 30mm lift... and avoid disapointment(spelling )... there may be other options to lift the front of the new Hilux, just ask the guys, like a ball joint lift maybe, and the lift is permanent...
Oom B
Oom B
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
Re: Camil or Mikem?
ok cool thanks
How does a ball joint lift work and what is involved?
- BlouBrakkie
- Town: Fourways
- Vehicle: 2005 Hilux 4x4 D/C 3.0 D4D Raider
- Real Name: Deon
Re: Camil or Mikem?
The best coils you can get for the D4D are the standard ones your car has come out with from the Toyota factory. The steel used and manufacturing of the spring is far far better than any other after market product.
Your best bet would be to replace your front shocks with Bilsteins (get them from Darrell at Mikem).
1. You keep you existing coils (and they can test them at Mikem for you if need be) which are the best out there.
2. The bilstein shock's strut mounting is adjustable so you can change the front height of you car at anytime without adding more hardware. They can but different setting on the shock for you that can allow you to do any lift increases you want in around 15mm increments. This will then allow you in future when you add extras to compensate for the sag, by using a higher setting on the bilsteins. You can get two bilsteins for the front for around the same price as what you were qouted.
I've already ordered my bilsteins from Darrell. It's about a two week wait as the parts are imported from Germany. But if you read anywhere on the web, Bilsteins are definately a cut above the rest!
Good luck and keep us posted!
Re: Camil or Mikem?
Hi Luke,
I'm not very clued up on the ball joint lift thing... take a look at these 2 threads:
viewtopic.php?f=93&t=4874&p=53825
and
viewtopic.php?f=8&t=4004&p=63229
BlumTRD(David) seems to be the man with the knowledge!
B
and
B
- Town: Durbanville
- Vehicle: Prado 120 VX
- Club VHF Licence: B35
Re: Camil or Mikem?
Not sure I follow - Shocks don't give you lift they just absorb shock Unless you fit the camil ones which has a coil as well.
The mount is adjustable but this will only help you to set the lenght of the shock when and if required.
Am I missing something?
- BlouBrakkie
- Town: Fourways
- Real Name: Deon
Re: Camil or Mikem?
Hi Suidwes
I agree with you that the shock itself cannot give you lift, however on the bilsteins (and i know some other American makes) the part of the shock where the bottom part of the coil rests on can be moved up and down the shock's shaft. With the bilsteins this is done with groves on the shock shaft which then house a type of steel cir-clip or 0-ring. On other American brands, the buttom coil strut sits on a thread that you can adjust with a spanner.
So theoretically no the shock in essence isn't giving you the lift, but practically on a coil over shock setup, the shock type can allow you to lift the vehice.....
Hope this makes sense......
- Town: Durbanville
Re: Camil or Mikem?
Very interesting, thanks
- LouisZ
Re: Camil or Mikem?
All what happens is you set the pressure in the shock, this cause the shock to be harder and then it "lifts" the 4x4.
- Town: Durbanville
Re: Camil or Mikem?
Confused again :?
That is what I thought but it sounds like you can actually adjust the coil with this shock....
- LouisZ
Re: Camil or Mikem?
If one adjust the coil by adjusting the coil rest then you adjust the coil to be harder of softer, then the coil lift the 4x4. As mentioned earler there is also shocks that you adjust the pressure. Many years ago before the Air Springs you also had the shocks that you inflated the same as the Air Springs, yet this only improved the load capacity.
- Spartan
- Town: Vanderbijlpark
Re: Camil or Mikem?
Lukelukestrugnell wrote:camil from suspension which apparently will give me 60mm lift for Approx R4000 or Mikem which will give me 50mm for R2500.
Wat is fout met jou somme nie eers die arabs hier gebruik die camel sus nie
Nee ok engelsman, jy lyk my verstaan die werksnipes wrote:Fit Mikem... and light up a Camel!
Ek verstaan dan ook nie, volgens Bilstein website kan die shocks jou lift gee, het n groot stuk gelees oor dit.SuidWes wrote:Confused again
MOBILITATE VINCERE
Spartan
Spartan
Re: Camil or Mikem?
Mikem nuff saidCamil or Mikem?
Re: Camil or Mikem?
Very articulate of you brulukestrugnell wrote:............... im a bit shocked............
Don't let the D4's low nose put a dampener on your enthusiasm, Mikem will lift your Lux and your spirits hey Luke
Proudly Sarf Afrikan enol
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
Re: Camil or Mikem?
I just have to look at my fuel bill and my spirits are high enough! 11km/l and R6.70 per litre diesel... life is good!
The ol SFA was breaking the bank
Re: Camil or Mikem?
What about adding a 10mm spacer on top of the coil? I have done it on my Fortuner due to the inter grated bumper/winch and on my d4d double cab. You get 35 - 40mm lift and no more hanging nose. They cost approx. R300.00(for a set) and R250.00 to fit. I have made 10 sets and have some 10mm spacers left, if you are interested
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
Re: Camil or Mikem?
Thanks Oooms
Can you explain how it works and where i could get it fitted if i do that?
do you have any pics?
cheers
cheers
Re: Camil or Mikem?
It is fitted above the coil, I had mine fitted in Strydom Park fitment Centre
- Town: Shelly Beach
- Vehicle: Toyota D/Cab d4d 4x4
- Real Name: Ryan
Re: Camil or Mikem?
Hi Mark, would you by any chance have anymore of those 10mm spacers available? I think its a briliant idea to get the front end jacked up a bit as I have quite a bit of front sag due to the replacement bumper and winch.
