In my valley the roads are terrible and there is more rock and stones and "slote", than a road. To drive a car is a nightmare, so the best vechicle is a bakkie.(a hilux of course).The only problem with hilux is the shock in front of the back diff, the stones like to hit it full of dents.
'n Boer maak 'n plan: I took an old air intake pipe, and fitted it at the bottom of the shock and sealed it with silicon to keep out dirt.
Andries
How to protect your shocks from stones
- Town: Strand
- Vehicle: '99 Raider 2.7
- Real Name: Hennie
Re: How to protect your shocks from stones
Hi Andries
Baie goeie idee, dit sal wragtig baie help. :) Nou moet ek net die op stuk pyp opspoor. :roll:
Andries
As you said a "boer maak 'n plan", what would your rooinek buddy in Queenstown have called it then?
- Niel
- Real Name: Niel
Great Idea Andries, I have a set of Kubo's and the also have this plast dust ... protector on a s standard. :D
- Town: ......
- Vehicle: .....
- Real Name: ......
Andries, do you find that small stones get into the rear break drums? Had the problem in Nam and had to take the rear wheels off twice to get rid of the culprits! Any body had a similar problem? Great idea with the pipe and thanks for sharing!In my valley the roads are terrible and there is more rock and stones and "slote", than a road. To drive a car is a nightmare, so the best vechicle is a bakkie.(a hilux of course).The only problem with hilux is the shock in front of the back diff, the stones like to hit it full of dents.
- Andries
- Town: Dordrecht
- Vehicle: '94 2.2 4Y Hilux S/C, '87 2.2 4Y Hilux D/C
- Real Name: Andries
Ek het nog nooit so 'n probleem gehad nie. Die ouer Hilux's se agter briekdromme is so toe daar is nie 'n manier vir 'n klippie om in te kom nie. As jy 'n SFA koop sal jy nie klippe in jou dromme kry nie.
- Town: Port Elizabeth
- Vehicle: 2009 Suzuki Jimny
- Real Name: Dawid
I had the same problem and have a few dings in the left rear shock. I used class 6, 50mm irrigation pipe (black flexible one) I used an angle grinder with a diamond disc and cut a section out so that I could fit them over the shock without removing it. I cut a small flap as well to protect the adjustment knob. It will stay in place by itself but to be sure I put some cable ties on. The plastic is thick and flexible and should take the knock.
If you get stones inside the brake drum, check to see if your inspection hole at the bottom has the rubber grommet fitted. Workshops like to loose those. I had mine replaced after a brake service by the workshop.
2009 Suzuki Jimny (Mini Hilux)
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
Dawid wrote:I had the same problem and have a few dings in the left rear shock. I used class 6, 50mm irrigation pipe (black flexible one) I used an angle grinder with a diamond disc and cut a section out so that I could fit them over the shock without removing it. I cut a small flap as well to protect the adjustment knob. It will stay in place by itself but to be sure I put some cable ties on. The plastic is thick and flexible and should take the knock.
