Custom sump
- Town: Bloemfontein
- Vehicle: `87 dc 4x4 Hilux (import)
- Real Name: Simon
Custom sump
Had the problem of the sump hitting the draglink when you go over the smallest bump.
I dont want to start talking about the guy who did the engine conversion because I`l just start swearing!
Had the option of lifting the engine with the engine mounts but there was no more clearance on the firewall or at the bonnet.
Could have done a bodylift and then lift the engine, but the bodylift will have to wait.
So I decided to make a new sump. Here goes...
- Real Name: Simon
Re: Custom sump
Does anyone know how to make pictures smaller? Cant get them on because they are too big!
Re: Custom sump
Simon, read here: viewtopic.php?f=21&t=10068&start=0" onclick="window.open(this.href);return false;
- Real Name: Simon
Re: Custom sump
Awesome! Thanx ooms!
- Real Name: Simon
Re: Custom sump
Look closely you will see the small gap between the sump and the draglink.
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Re: Custom sump
Shoe!! Dit lyk na 'n probleem ja!!
Watse mouter het jy in?
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
- Real Name: Simon
Re: Custom sump
I removed the original sump and adaptor plate, cleaned it nicely and filled the sump with 5l of water to check the level of the oil.
Recorded the level of the oil from the engine block and roughly calculated the dimentions of the new sump. The new sump must keep the oil on the same level.
Picture below is the original sump and adaptor plate with the new adaptor plate in design.
The motor is a Toyota 3C Turbo, which is a Japanese inport. 2.2l
- Real Name: Simon
Re: Custom sump
With the new adaptor plate cut out and fitted just to see if everything fits. The oil pickup is the original.
- Real Name: Simon
Re: Custom sump
Now to start with the sump.
Cut out the ring which will me bolted to the adaptor plate. The sump will then be built from this ring.
Re: Custom sump
From the pics, it looks like the sump would be making contact with the track rod and possibly the top of the axle banjo housing... not the draglink... the draglink is the rod between the J steering arm and powersteering box pitman arm...
Re: Custom sump
Jy moet BAIE goed weld - olie kom op die kleinste plekkies uit!!!
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
Re: Custom sump
Daai plaat lyk na 2mm of dikker, so mens kan hom maar looi met die welder...as hy die binnekante met CO2 welder doen of selfs braze hoort hy dig te weesThabogrobler wrote:Jy moet BAIE goed weld - olie kom op die kleinste plekkies uit!!!
- Real Name: Simon
Re: Custom sump
Ja dis 2mm plaat, werk baie lekker en brand nie maklik gate nie.
Het die sump `n dun lagie olie gesmeer en toe voel water gegooi en gelos oornag. Geen lekplekke nie :o
Verf hom toe met Duram NS7, en siedaar.
Die foto maar baie onduidelik, en verskoon die water, het `n plas getref op die toetsrit.
- Real Name: Simon
Re: Custom sump
Thanx for clearing that Mr B, I dont know all the jargon jet.
