Headlight upgrade - Well worth it!
- Pumba
- Town: Durbanville
- Vehicle: Toyota Hilux 3.0 D4D 4x4
- Real Name: Kobus
- Club VHF Licence: HC112
I just had a Headlight upgrade done on my Land Cruiser by Jos Hartog in Parow industria. It is available for the Lux's so you might want to cocider this one
Jos says that they did tests and found that after the upgrade your dims will have the same intensity as your brights have currently. They adjust it correctly when they are done so that it doesn't blind other drivers. They also don't remove your current wiring loom so that should something go wrong with the installed product you can just reconnect your old stuff.
Ps. This is not a HID kit.
Here are a few before and after photos:
Jesus was blunt: "No chance at all if you think you can pull it off by yourself. Every chance in the world if you let God do it." Mark 10:27(Message)
Re: Headlight upgrade - Well worth it!
Gee Wizz, if its not HiD what do they use. I think this is a must on all old vehicles
Osram...nights?
- Ali3n
- Town: Roodepoort
- Club VHF Licence: B338
Looks good!
PRESENTLY DISADVANTAGED
Most probably a couple of relays and heavy duty wiring direct from the battery through the relay contacts to Osram Nightbreakers or similar. An excellent means of improving your headlights! No extra load on your harness or switchgear (less current load in fact, as the switchgear now only controls the relay coils).
Reflectors and lenses need to be in good condition as well, but OEM Hella lights are not that expensive.
- Pumba
- Town: Durbanville
- Real Name: Kobus
Eish, you make speaking hi tec sound good :!:
It looks like relays in the little box, yes, and the upgrade includes new lenses too
- Stubs
- Town: Onrusrivier Hermanus
- Real Name: Stuart
did the same on mine, clear acrylic lenses and osram nightbreakers,, far superior to the standard......
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Price???? how much moola?
- Stubs
- Real Name: Stuart
headlights were R200 each and the osrams for the two was I remember right about R160....from midas. Headlights from Hoppy...
- GeorgeJvR
- Town: Louis Trichardt
Total cost on the SFA?
Kom wat wil ek bly 'n Bul!
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Kom nou George man, dis DIY werk die vir jou!!GeorgeJvR wrote:Total cost on the SFA?
- KOBUSL
- Town: WOLSELEY
- Real Name: KOBUS
New front lights from Midas or Autozone ( cheap ), relays for ALL lights ( one per light, one per spot ) also cheap, self resetting fuses,
( not cheap ) and cool white or cool blue globes, plus quality wire and lugs : about the price of one not too pricey spotlight, and million % more light.
- GeorgeJvR
Nou verduidelik bietjie hoe werk die storie?JohanM wrote:Kom nou George man, dis DIY werk die vir jou!!GeorgeJvR wrote:Total cost on the SFA?
Ek's bietjie saaaaaaaadag
One can DIY such a project quite easily. Just upgrade the lamps to Silverstars, Cool-Blue's or Night-Breakers (my order of preference) and some decent wiring directly off the battery with two separate 30A relays ... one for headlights and one for spots. Let the light switches operate the relays and keep the runs between the battery and lamps as short as possible with a separate in-line fuse on each feed. Walla!
If you want to go a step further then change the headlamps for clear lenses, but I wouldn't bother with that part myself unless the reflectors were already tarnished.
- GeorgeJvR
Aha nou ek verstaan
Nie te moeilik nie.
Nie te moeilik nie.
Kobus, thanks for posting and directing me here.
The system was initially developed for older Land Cruisers (60, 80 and 70 series), but will work for virtually any make/model where the OEM wiring is not up to the task. Newer Cruisers, Hiluxes, etc have suitable wiring and can only benefit from better globes
It involves a controller (relay box), new loom and, if required replacement headlamps and better globes. The design is plug and play - unplug your old loom, fit the new one; connect box to battery and Bob's your aunty. There is no cutting/splicing involved and OEM wiring remains as OEM
On a typical installation (controller, headlamps and globes), you can expect about a 300% improvement in light output on both high and low beams. PLEASE NOTE that I have not tested any Hilux wiring to date, but I know my old 2.4 would certainly have benefitted
To date I have mostly been using Osram NightBreakers and now the NightBreaker Plus which "promises" longer life (to be proven). I also have a range of Ring Automotive XenonMax globes which provide the same light output as the Osram but "promises" even longer life.
The controller also makes provision for spots and fogs. These can be made to switch independently or on/off with the high and low beams respectively.
Cost of the controller plus loom for single headlamp vehicles is R1 160 while twin headlamp vehicles is R1 285. Installation is R400/R650 respectively, but if you can turn a screwdriver and know that the red wire is positive, then you can DIY
Replacement headlamp units are dependent on model
Note that I would like to test the various Hiluxes before I make any promises Any volunteers for non invasive surgery?
- Pumba
- Town: Durbanville
- Real Name: Kobus
Thanks Jos
There you have it gents - from the horses mouth
- Pumba
- Town: Durbanville
- Real Name: Kobus
Gents, you must see these lights at night... oops, there ain't no night cauz they're to bright And that rimes nogal
The current shape Hilux & Fortuner have decent wiring - the kit will not benefit much. Osram NightBreaker or XenonMax globes will improve light by about 100%
I would like to experiment on the older SFA or 2.7/KZTE IFS models. Anyone?
First volunteer gets a free kit on condition you post an honest feedback report here (pros/cons/happy/unhappy)
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
I would definitely be interested for my SFA, but I'm in 'Toria!Jos Hartog wrote:The current shape Hilux & Fortuner have decent wiring - the kit will not benefit much. Osram NightBreaker or XenonMax globes will improve light by about 100%
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Jos if your serious than we can give it a bash.I have a 2,7 and is in DurbanvilleJos Hartog wrote:The current shape Hilux & Fortuner have decent wiring - the kit will not benefit much. Osram NightBreaker or XenonMax globes will improve light by about 100%
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
Jos, Me too for a SFA - if you keen to do both.
The air is much denser down in CT... the sea air, y'know, so the test will not work there!
I think Klerksdorp is at about the correct altitude for this very important test, located at a height halfway between Zilleville & Gangsterland. And I can offer both, an IFS & SFA Hilux...
Jos, I never got a chance to go to the PO today, will try tomorrow.
George, Steve,
I will do both, thanks for volunteering. Please wait for the new year as we are snowed under 'till then
Eric, if k@kpraat was an art, you'd have an MBA
- Vehicle: 2,4 DC 4x4 Raider
:wth: Huh... Klerksdorp..... right attitude...uh altutude...we don't need bright lights in Klerksdorp...no darkness here, unless you plan a trip out of town!
Jos, is there life outside Klerkies? :wth:
(F_D looks out the window.... Uh-uh, nuffin' but darkness out there. F_D shuffles back to his game of Noughts & Crosses)
