Solenoid swiched by the wiper motor
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Tue Mar 01, 2016 7:44 pm
How do you do it, meaning is it plain tap in on the wire and connect it to the solenoid. That wire to the wiper motor looks very thin to me :D: And I assume the solenoid will not connect while you turning the starter motor?
On my dans, kerk en werk bakkie, I having a NL solenoid under the bonnet, and a BH connection at the back for a loose battery, but I also load a camper for trips, which has its own dc to dc charger and battery.
Thus I want to change the NL solenoid to work of the wiper motor instead from its pc board else it will not connect when I load the camper.
Johan Kriel
Prado
Town: Bellville
Vehicle: Langpad (RAV4)
Wed Mar 02, 2016 10:34 am
Johan ek tel daai sein op by die "lighter".
Draad gaan dan deur daai masiewe rubber net agter die cubby hole
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Wed Mar 02, 2016 12:37 pm
If you want to use the wire on the wiper motor just for a ignition on signal then its fine to use.
Wed Mar 02, 2016 4:21 pm
I also prefer to use the lighter feed wire .... if something goes south, it's no biggie if the lighter socket fuse is blown, at least I still have wipers etc. :winkx:
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Wed Mar 02, 2016 5:56 pm
Thanks, gedoen. :thumbup: En dit werk!
NL pc board gelos, net vir die battery monitors.
img 2.JPG (31.06 KiB) Viewed 815 times
img 1.JPG (33.21 KiB) Viewed 815 times
Johan Kriel
Prado
Town: Bellville
Wed Mar 02, 2016 9:04 pm
Johan op watter kleur draad het jy ingesny ?
Lyk beslis makliker as die lighter idee ....
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Wed Mar 02, 2016 10:49 pm
Chris, daar is n blou draad wat lewendig word as jy die ignition aan sit. Daar is 5 drade op die plug na die wiper motor toe. En ja is sommer by die wiper motor.
Johan Kriel
Prado
Town: Bellville
Wed Mar 02, 2016 11:28 pm
Dankie Johan.
Dit mag dalk die maklikste manier wees om n sein te kry vir die running lights vir die platkar .... sodra Pieter vir ons kwaliteit running-lights inbring ....
xychix
Town: AMSTERDAM
Vehicle: Hilux KUN25
Real Name: Bergman
Thu Mar 03, 2016 10:38 am
Mud Dog wrote:I also prefer to use the lighter feed wire .... if something goes south, it's no biggie if the lighter socket fuse is blown, at least I still have wipers etc. :winkx:
if you tap in the wiper wire you can place an inline fuse (small one, smaller than the wiper one itself) in the signal line to the relay. if the relay shorts internally it will pop the smaller fuse.
Knuppel
Town: White River
Real Name: Marius
Thu Mar 03, 2016 11:57 am
+1
Return to “General Mods”
