Fj cruiser nitro charger to SFA
Town: Nelspruit
Vehicle: '89 Hilux DC
Real Name: Sven
Thu Feb 16, 2017 10:48 am
Was just wondering after seeing a photo of a Toyota Tacoma with old man emus, what is the possibility of using a nitro charger style shock with coil suspension from a Tacoma/fj cruiser and one or 2 leaf springs for the axles for stability on the SFA, obviously there would need to be some shock mount modification but could this not be a suspension option on a SFA?
'89 hilux D/C SFA, import spec.4YImageImageImage
Thu Feb 16, 2017 11:33 am
It's possible of course, but is it advisable? :think:
The spring rate of a suspension system is calculated around the weight of that particular vehicle and the Tacoma as well as the FJ are considerably heavier, especially if the donor vehicle was a diesel. This of course includes the shocks, whose damping rate is similarly matched. You might well find after doing it that you have a very hard suspension with suspension travel (and thus articulation) being severely hindered because of the lighter vehicle weight not being able to deflect the springs sufficiently.
That's just my opinion. :winkx:
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Thu Feb 16, 2017 10:02 pm
Dont waste your time and money! Just buy the right gear the first time!
ORRA Call Sign: x223
Fri Feb 17, 2017 7:04 am
Anything is possible - depending on you pocket depth.
Return to “General Mods”
