2 small things are left to be done after the fan is sorted. I cannot trace the cables for the follow 2 functions.
Alternator charge light cable and rpm cable. In which cradle are these cables running? Driverside or passanger side of the bakkie?
It looks like the rpm cable is black/red and the charge light is black/white from the console but for the life of me, we can't find them in the engin bay.
22R Wireing to Lexus help needed
- Vehicle: Ry die vyand
- Real Name: Reynard
- Club VHF Licence: B01
Elands4x4
Elands4x4
Re: 22R Wireing to Lexus help needed
As ek reg onthou is die RPM draad by die coil in die engine bayCastos wrote:2 small things are left to be done after the fan is sorted. I cannot trace the cables for the follow 2 functions.
Aan waste kant was dit Cassie? As ek van vooraf kyk, regs? Die 3RZ sit party goed anders om en ek is woes deurmekaar. Die probleem is, ons het so bietjie mal gegaan met die sidecutter en ja......
Elands4x4
Elands4x4
As jy voor die bakkie staan regs agter in die hoekCastos wrote:Aan waste kant was dit Cassie? As ek van vooraf kyk, regs? Die 3RZ sit party goed anders om en ek is woes deurmekaar. Die probleem is, ons het so bietjie mal gegaan met die sidecutter en ja......
Thanks man. sal so bietjie loer.
Elands4x4
Elands4x4
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
THe Alternator Charge light will be running from the instrument cluster to the fusebox where it will be joining up with the wires going to the Alternator via the front cradle...
THe wire runs from the Ignition switch (Black with red stripe) to the 7.5Amp fuse (ignition) that is situated in the Kickpanel by the driver side foot. From here it runs to the Lamp in the dash itself (black with yellow stripe). It returns from the light with a Yellow & white wire from the alternator regulator via another 7.5 Amp fuse (charge) to the fusebox.
This is how I have traced it....Hope this helps you
Thanks Johan will check it tonight
Elands4x4
Elands4x4
- Town: JHB
- Real Name: Derrick
IGN + to IG
7.5 to S
and from your lamp on the cluster to L.
Make sure your earth strap is connected to your motor otherwise the alt can't earth for your charge lamp.
If STD ECU than just trace from your tach on the igniter and thats your rev signal
7.5 to S
V8 SOLID
Thanks Derrick. got it sorted just as you've stated
Elands4x4
Elands4x4
