Condor 2.4i conversion
Castos
Town: Nelspruit
Vehicle: Ry die vyand
Real Name: Reynard
Club VHF Licence: B01
Post by Castos »
What do you guys think of a condor 2.4i motor in a Hilux sfa.
Is this a 22R with EFI on or not?
What will the cost be?
I saw on a website that the power is ok, 108kw and 298Nm/T.
Elands4x4
kingdubber
Town: Durbs
Vehicle: Toyota Hilux 4x4 4y
Real Name: Grant
Re: Condor 2.4i conversion
Post by kingdubber »
Hi,
I was thinking along the same lines. But the 2.4i you refer to is completely different. Could be done but you proberly better off with a 2.7i
Castos
Town: Nelspruit
Real Name: Reynard
Post by Castos »
Thanksman.
Nou weet ek.
Elands4x4
3RZ
Vehicle: 2004 Legend 35 Hilux 2.7 DC 4x4
Real Name: Willem Grimsell
Post by 3RZ »
I think they use the 2RZ motor in the Condor, this is basically the predecessor of the 2.7 3RZ motor, they are very highly rated in the states, almost on par with the 2.7 3RZ.
Type In-line, 4-cylinder
Valvetrain SOHC, 8 valves
Displacement 2 438 cc
Bore x Stroke 95 x 86 mm
Compression ratio 8.8 : 1
Power 85 kW @ 4 800 r/min
Torque 195 Nm @ 2 800 r/min
Fuel supply Electronic fuel injection
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
The 1RZ 2.0L, 2RZ 2.4L, 3RZ 2.7L, all use the same block, but the bore, stroke and cylinder heads differ, they all use the same bell housing, (Not the same as anny other Toyota motors), but the bell housing is std fit on the gearbox side.
For the same amount of trouble you can fit a 2.7 wich is multivalve, more economical and more powerfull.
I have fitted a few 2.7's with carburettors with good results.
