Knock sensor on the 7mge
- Gunta
- Real Name: Mark
Has anyone connected their knock sensor on the 7mge. Mine is there but not connected. How would I connect it up and what would the benefit be?
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Knock sensor on the 7mge
In OE systems it is used to optimize ignition timing, i haven't seen an aftermarket system that can accomodate it.
aev@iburst.co.za
- Gunta
- Real Name: Mark
Allan, I have the OEM system its just not connected. I was just wondering what the benefits to connecting it will be.
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Mark, the knock sensor "listens" for knock and retards the timing just enough to prevent it.
the ECU basically tries to advance the timing as much as possible for the ambient conditions (fuel grade, air temp, load etc)
and then listens for knock to back off the timing.
Basically the advantages are the advantages of having your timing as advanced as possible for every condition. i.e. power, economy and smoothness.
- Town: Centurion
- Real Name: Everdt
Mark pm you
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
The other advantage of a knock sensor is that it keeps the pests away. Mine's fitted to the front gate!
- Gunta
- Real Name: Mark
Now I need to find a way to connect it and see if it works. Anyone know where I can get the plug fitting to connect onto knock sensor?
