HI all
I finally got a vehicle last week.
It has a 2001 model 2.7i toyota conversion in it, original ecu wiring etc and it has in total about 105 000km on it.
I am still quite keen to get some more power, but not at the expense of reliability. The hilux goes really well, but with a boat on it could do with a bit more.
My other option is to fit a 2jzgte motor which has a lot more power with about the same fuel consumption.
Danie from supratech will purchase the motor from me that is currently in there and fit the 2 jzgte.
Does anyone have any input as to whther to change to the 2jz , or would you leave it as it is ?
Jon
2.7i OR 2JZ GTE
Re: 2.7i OR 2JZ GTE
The only problem with turbo engines is that they do not perform well off-road.
Ask Ewald here he had the problem with the SupraLux Danie built, its a super racer but too much "uncontrollable" power off-road.
Re: 2.7i OR 2JZ GTE
Jon,
Great news on your "new" Hilux!
What model/year is it? A SFA with the Hilux 2.7i engine in? That should cope pretty well with just about any boat, unless you're talking about a large Sea-Craft. Pics?
- Town: Pietermartizburg
- Vehicle: Hilux 4lt V6 (Vigo)
- Real Name: Jon
Re: 2.7i OR 2JZ GTE
THanks for the response guys. \
It is a 1997, was a 2.4 ltd edition. Has a 2001 2.7i toyota motor in.
Will post some pics when I download the camera this weekend.
Looking forward to making use of it.
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
Re: 2.7i OR 2JZ GTE
Rather keep the 2.7 and fit a supercharger instead,
simoan
simoan
- Real Name: Jon
Re: 2.7i OR 2JZ GTE
hi simon, who does the supercharger.
- SYRON CONVERSIONS
- Real Name: SIMON
Re: 2.7i OR 2JZ GTE
Try Rob Green Motors in JHB, he fitted one to the Colt Rodeo.
simoan
simoan
Re: 2.7i OR 2JZ GTE
Hi Jon,
The 2.7 will be a little light for towing your boat. Also, keep in mind never to tow in 5th gear - no matter what engine, as they tend to strip under heavy load. (even the newer cars have this problem)
I would suggest another engine. Also, Rob Green is SUPER expensive. I don't know if you have enquired yet, but I am sure that you will not be thrilled. My rule is to never convert a standard engine to something it was not meant for. I will always rather look at buying an engineered turbo or supercharged engine that was designed for those applications. All parts are always standard off the shelf then.
I would suggest you stick to your original plan, and get Danie to do the conversion. I recall that you were not too stressed about the off roading bit, but wanted something that could tow and launch your boat with. Turbo power is the only way for those applications, especially in sand.
