97 SFA - Lexus V8 1UZ Conversion.... VVT-i vs non-VVt-i
Town: Sunninghill
Vehicle: Hilux '97 4x4 DC, Lexus V8, Power Brakes, OME, 40mm body raise, 31x15" Firestones on 30mm spacers, Gearmax Diffloc, Snorkel, dual batt, LR tank, Warn winch. 1985 FJ45 LCruiser, OME, ARB lockers FF & RR, 32x16" BFG MT's on 30mm spacers
Real Name: Jim
Tue Mar 20, 2012 1:15 am
Hi All,
As stated in a previous related post on this forum... (See "97 SFA - Lexus V8 1UZ Conversion.... AUTO vs MANUAL")... i've taken the (mental) plunge and i'm doing it... that is - Converting my 97 SFA 2.8D DC Lux to a Lexus V8.
Yes - many, many questions and lots and lots of research - BUT - now i am happy with the decision, and surely the gods will smile upon my particular conversion job and i will emerge a happy man and proud owner of a fantastic new and revitalised '97 V8 Lux.
So - lets admit first of all - I am still not 100% sure on which variant of 1UZ-EF engine - but lets say i am 99.9% there ...and for the benefit of anyone considering going the same route, and for those who wish to add their experience, and tell me im making a huge mistake(!) - you are all most welcome - please post below ... :)
As far as the differences (as i understand them) between the Non-VVt-i and the VVt-i, ive added my 2c worth of PRO's vs CON's:
please feel free to rip it all to shreds... :)
Looking forward to hearing your comments...
p.s. Final decision re VVT-i or non-VVT will be made by wednesday.
Pro's & Con's: Non VVT vs VVT
1UZ-FE Non-VVT-i
1. Cheaper as an initial purchase
2. Simpler - only 1 condenser per row (amongst other things)
3. condensers cheaper (R400 vs R1000 for VVT-i version)
4. if u go Spitronics - only needs 1 ECU module
5. lots of spares around
6. less programming on the ECU to worry about? (could also be a CON?)
1. Less fuel efficient (slightly) - (see VVT-i Pro's below)
2. Less power & torque (see VVT-i Pro's below)
3. Older engine (1989-1996)
1. More fuel efficient - but only to the tune of about 10%, will need about 8 years to make up the difference in cost(!) (i am open to correction on this one... :) )
2. More power and torque (yeah - like you really NEED that extra 10% ha ha!)
3. Lots of spares around - and engine core is backward compatible with non-VVTi engines (not the head or the intake manifold though.)
4. Newer engine (1997 - 2002(?))
1. More expensive as an initial purchase
2. electronics more complex(?)
3. Condensers more expensive (see non-VVT-i PRO's above)
4. Has MORE condensers - (8 vs 2 on the non-VVT-1). BUT - that can also be seen as an advantage - if a condenser fails when you are FAR-AWAY and you forgot your box-of-spiders back home (FAR-AWAY), then u can still get home on 7 or 6 cylinders. (Not the same case for the non-VVT-1 which has 1 condenser per bank of cylinders.)
5. Needs 2 x Spitronics ECU (if this is your choice) - which also means you need 2 x Spitronics ECU carry-on spares in your box-of-spiders if you are going FAR-AWAY.)
Happy to hear you agree or rubbish my brief and admittedly possibly naive, analyses above. I can only learn!
Vehicle: '98 LTD
Real Name: Stefan
ORRA Call Sign: X107
Tue Mar 20, 2012 7:19 am
By no means an expert, but my personal choice would be the 2JZ ;-)
As far as VVTi goes, I've heard from the drifting guys that one has to have the original ECU otherwise you can forget about even getting it started. How true that is I don't know first hand.
mark watson
Town: gauteng
Vehicle: hilux
Real Name: mark
Tue Mar 20, 2012 9:37 am
stefan , there is no problem with the vvt and the spitronics , works well , but as for going with the 2j you must remember the 2j is 70mm longer than the 1uz and already it is a tight squeeze , and the 2j is a more expensive motor than the 1 uz non vvt , grantes there is nothing wrong with the j series motors but not in a 4x4 , bmw and the like yes they work like a bomb , have done the conversions already .
Vehicle: UZJ 42 LX
Real Name: Theo
Tue Mar 20, 2012 10:13 am
AFAIK, the VVT-i has the OEM viscous fan and the motor is "slumped" forward requiring less firewall "convincing" in some trucks. That flat torque curve from 1000 RPM is very attractive in 4x4 application.
Town: Germiston
Vehicle: Ford V6 3.4 Courrier soon to be powered by Yamaha!! Jeep GC 4.7 V8, Aygo broken traded for a Kia Picanto.2ex
Real Name: Fernando
Sun Apr 01, 2012 5:02 am
sure this info could be too late, however pls allow me to still add fuel to the fire
non vvt, has distributors, distributor caps and plug wires, those moving parts somewhere along the way will always need attention
vvt, coil packs, less headaches, imo
as for the extra power of the vvt, as we are basically derestricting the motors from their original set ups, by running no catalytic converters and free flowing systems, then 10% and mire has already been gained, however the same could be said for the vvt, as those now sit in the same boat and have also gained from being derestricting
have fun :beach:
Vehicle: Ford Courier - Vw Caddy - Isuzu kb250 - Mazda 250td/i - Mercedes Benz C230 Compressor sport
Real Name: Rian
Tue Jan 20, 2015 8:55 pm
Just something we have been playing around with. :boss:
https://www.youtube.com/watch?v=trWzSga ... 5JNFC4fvdw
