Essex v6 3.0
- Town: Naboomspruit
- Vehicle: Mazda Drifter
- Real Name: William
Essex v6 3.0
Ek sukkel met my ford v6 engine - het iemand dalk 'n manual - ek kry niks op die internet nie asseblief.
- 519franco
- Town: Richards bay
- Vehicle: 87 Hilux 3L v6 Ford
- Real Name: Franco
Re: Essex v6 3.0
What is wrong.
FORD> Full Off Road Damnation
Sponser: MY DAD
- Stubs
- Town: Onrusrivier Hermanus
- Real Name: Stuart
Re: Essex v6 3.0
stevo you so funny!!!
I have a manual, send me your email dress and I can forward on.....
You will find no help on this forum but a select few who have the Ford V6...because everyone else has no problems with their V8 lexus's, 4Y, 22R's, ......
its a great engine....
- 96-Luxi 4x4
- Vehicle: 1996 Toyota Hilux 4x4 DC Almost Lexus V8
- Real Name: Naas
Re: Essex v6 3.0
Hi Guys
Seems like I have some of the Ford V6 Guyes here. In my other Hilux, my 84 stout single cab 4x4 I have a ford V6, but think it needs some attention. It struggles a bit to start, smokes a bit, and has a few oil leaks.
Should I pull the motor and overhaul it (what would the cost be +-), or do i go with the normal 1UZ V8 on the 5 speed manual.
I think the Ford is enough power, but just thinking of cost and reliability, and also to keep everything Toyota
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Re: Essex v6 3.0
You know what they say "if it doesn't leak oil it needs filling up"96-Luxi 4x4 wrote:Hi Guys
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
Re: Essex v6 3.0
Like Land Rover, Ford is now selling oil in different colours so you can match it to your paving.
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Re: Essex v6 3.0
need to get some for my Ssangyong Mussozepplin wrote:Like Land Rover, Ford is now selling oil in different colours so you can match it to your paving.
- Rider
- Town: Richards Bay
- Vehicle: 1987 Toyota Hilux 4x4 d/c 40mm body lift, KZ-TE Diff with Diff lock, Snorkel, 31" AT tyres , Powered by FORD 3.0 V6 uprated.
- Real Name: Luke
Re: Essex v6 3.0
Lolzepplin wrote:Like Land Rover, Ford is now selling oil in different colours so you can match it to your paving.
PROUD OWNER OF A TOYOTA HILUX AKA AMA-HIPZ
- 96-Luxi 4x4
- Real Name: Naas
Re: Essex v6 3.0
Thanks guys, but was hoping for some real advice
- Town: Port Elizabeth
- Vehicle: none
- Real Name: Julien
Re: Essex v6 3.0
I would also like the manual
where can i get it from?
- Stubs
- Real Name: Stuart
Re: Essex v6 3.0
Hi Julien, I have the manual, send me your email address and during the course of the day will email it to you, its about 6 emails in total as another guy on the fourm was so kind to scan it and email it to me
cheers Stubs
cheers Stubs
- Kat
- Town: Kraaifontein
- Vehicle: Hilux SFA
- Real Name: Eugene
Re: Essex v6 3.0
Also got a Ford V6 in my bakkie, and not ashamed of it, bought my vehicle already with the convertion done to it!!!!! Easy and cheap to fix, and spares readily available. Just want to know if the 4y engine mountings is a straight fit or do you need to modify the mounting brackets that bolt onto the engineblock to fit 4y mountings???? Still uses the old Ford mountings and already replaced four, so they don't seem to be that strong in the bakkie!!!! Furtheron no hickups with the engine, and been driving it for six years now.
Re: Essex v6 3.0
Naas,96-Luxi 4x4 wrote:Hi Guys
The Exxex V6 is still the cheapest Rand/kw you can get!
I'm not an expert but I'm pretty sure you can recon that V6 for under R5k!
I can not see that you can do a Lexus conversion for under R40k and then you have teething problems et al.
Re: Essex v6 3.0
Dont use the std Ford v6 engine mountings. They cannot handle the L/R torque and break. Use the std 4Y engine mountings. They last. I had the same problem on my V6 conversion. You can ask Hoppy how he managed to get them in there.Kat wrote:Also got a Ford V6 in my bakkie, and not ashamed of it, bought my vehicle already with the convertion done to it!!!!! Easy and cheap to fix, and spares readily available. Just want to know if the 4y engine mountings is a straight fit or do you need to modify the mounting brackets that bolt onto the engineblock to fit 4y mountings???? Still uses the old Ford mountings and already replaced four, so they don't seem to be that strong in the bakkie!!!! Furtheron no hickups with the engine, and been driving it for six years now.
- 96-Luxi 4x4
- Real Name: Naas
Re: Essex v6 3.0
Cool. Thanks guys. This helps my decision,when the time is right I will just recon the motor and change engine mountings and re do carb.
Is there a carb kit available for these carbs? I dont know but seems like the standard carb?
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Re: Essex v6 3.0
Hi Naas
Soos ek verstaan is daardie v6 Ford motors op hulle gelukkigste met n 38 weber card op hulle kits is vollop beskikbaar.
- Kat
- Real Name: Eugene
Re: Essex v6 3.0
Hallo Naas
Die V6 het standaard uitgekom met 'n 38 weber DGAS. Ek weet Echlin maak 'n kit vir die carburettor's, en midas behoort dit te verkoop. Hoop dit help.
- Kat
- Real Name: Eugene
Re: Essex v6 3.0
Dankie vir die info ThysThysdJ wrote:Dont use the std Ford v6 engine mountings. They cannot handle the L/R torque and break. Use the std 4Y engine mountings. They last. I had the same problem on my V6 conversion. You can ask Hoppy how he managed to get them in there.Kat wrote:Also got a Ford V6 in my bakkie, and not ashamed of it, bought my vehicle already with the convertion done to it!!!!! Easy and cheap to fix, and spares readily available. Just want to know if the 4y engine mountings is a straight fit or do you need to modify the mounting brackets that bolt onto the engineblock to fit 4y mountings???? Still uses the old Ford mountings and already replaced four, so they don't seem to be that strong in the bakkie!!!! Furtheron no hickups with the engine, and been driving it for six years now.
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Re: Essex v6 3.0
Got my carb kit and other Weber parts from Carburettor City in JHB. I think basic overhaul hit was about R 400
011 3344433
171 Main St
Johannesburg (Gauteng)
011 3344433
171 Main St
Sifu-Lux....I will miss you
- 96-Luxi 4x4
- Real Name: Naas
Re: Essex v6 3.0
Thanks Guys, appreciate all the info
do you know of anyone that will do me a favour and redo the motor, respray and so in JHB, east rand area once the time is right?
- 96-Luxi 4x4
- Real Name: Naas
Re: Essex v6 3.0
Hi guys. Where is the best place to buy engine spares for the fors engine. Pistons cranck bearings etc. friend of mine lost an engine.
Thanks.
Thanks.
- Sifu-Lux
- Real Name: Andrew
Re: Essex v6 3.0
Got all my engine parts for my rebuild from Alert Engine spares and Autozone.
- kfxnando
- Town: Germiston
- Real Name: Fernando
Re: Essex v6 3.0
lots of questions here, sadly haven't looked in here for a while, as I believe I have plenty of answer
yes carburator city about the best place to get the carburator kits
to redo the V6 properly with new parts including engineering, can't be done with 5k anymore
then add a complete clutch kit, closer to 10k for peace of mind
then going from V6 to lexus V8, self am going that trip, although rather slowly, however I tow quiet heavy and big, and if you do every thing your self, you can do it for around 30k
self was lucky as the surge tack was free, clutch is the Ford one as I have a ford Courier and those clutches are cheaper then the Toyota, engine mounting a friend did all the turning and self just bought the vesconite
many brackets like for the bmw radiator and the water bottle, did myself
however have another V8 at home, a Jeep V8, and the V8 sounds so much better then a V6, and the lexus V8 likes to rev, so can't wait to hear my one roar in the bakkie
and just to wet your appetite
my lexus V8 being bench tested before coming home
https://www.youtube.com/watch?v=pJOiGQt_DbE" onclick="window.open(this.href);return false;
enjoy
enjoy
- Stubs
- Real Name: Stuart
Re: Essex v6 3.0
Now Fernando that sounds awesome..... I love my V6 Ford but you cant beat that low rumble when the engine is ticking over, the best...
- Vehicle: v6 essex
- Real Name: christopher
Re: Essex v6 3.0
Hey guys I know this thread was posted a long time ago. I was wondering if sombody could email me the workshop manual for the 3.0 ford v6 motor. I'm having trouble getting it to start
- kfxnando
- Town: Germiston
Re: Essex v6 3.0
Have some where at home, a file with specs
Meaning will need to scan or take photo of the pages to mail
So it wount start?? Lets see if we can help
What did you dobefore it wont start now, or did it go ok one day and the next day it wouldent start
Or did you rebuild the motor
Ignition > points or electronic
What carb is on it
What carb is on it
- Vehicle: v6 essex
Re: Essex v6 3.0
Well I bought this bakkie with a siesed ford v6 motor. I pulled it out and put this motor in. Iv never run the motor before. It has compression. Its got spark. The fuel pump is pumping fuel. It just won't start. If I throw some fuel down the carb it ignites that but does not continue to run
- kfxnando
- Town: Germiston
Re: Essex v6 3.0
Then that narrows it down to carb
Maybe take the top of the carb off and see if there is fuel in the fuel boel, and then you might as well see what size jets are in every where
Mains and air correction jets
Got to start somewhere
- Vehicle: v6 essex
Re: Essex v6 3.0
Ill check the carb tomorrow. But I took it in to carb doctor and they had it on the test motor and it seemed to run fine?
- kfxnando
- Town: Germiston
Re: Essex v6 3.0
Uh!! If it wants to start when you put fuel down the throat and it wants to start but dies then to me it say not getting fuel, maybe someone else has some other ideaschrisv6 wrote:Ill check the carb tomorrow. But I took it in to carb doctor and they had it on the test motor and it seemed to run fine?
However from my experiance and logic, motor not getting fuel
Did u see the carb running on the other motor?? Testing
- Vehicle: v6 essex
Re: Essex v6 3.0
Yeah I did. But I will check it my self tomorrow. The manual says what size the jets should be and all that. I agree with you about the carb theory but haven it tested made me assume its somthing els. So I'll go through it and see what I can find
Re: Essex v6 3.0
The distributor not perhaps 180° out of phase? Can you see the timing marks when the distributor rotor points to #1 plug?
- Vehicle: v6 essex
Re: Essex v6 3.0
If I lighn the front crank pully to its timing mark. Putting piston one at TDC the rotor is facing spark plug point one
- kfxnando
- Town: Germiston
Re: Essex v6 3.0
Also thought of that, as I have been there done that oneFamily_Dog wrote:The distributor not perhaps 180° out of phase? Can you see the timing marks when the distributor rotor points to #1 plug?
However the fact that when fuel gets poured down the carb it wants to run, lead me to think that its not getting fuel
Quick question
Does the carb have two fuel pipe connection
Incomming and return
Maybe check those
- Vehicle: v6 essex
Re: Essex v6 3.0
Ok set the timing and still no go. The carb only has one line in. Its getting fuel into the bowl. And when I crank the accelorator it sprays down the barrels... I took the two main jets out the are .05 smaller than they should be. That wouldn't cause it not to spray enough fuel to start right?
- Vehicle: v6 essex
Re: Essex v6 3.0
Its aliiiive! The problem was the carb. The one diaphrame had a crack and all the carb settings where out. Thanks for all the help from everybody! I can finaly get my bakkie moving again
- TKM
- Vehicle: Toyota hilux raider d/c, 3,4L Ford V6, Dual Tanks, OME springs, Gas shocks, Custom Exhaust
- Real Name: Karl
Re: Essex v6 3.0
Hi,
Could you perhaps tell me what jets are supposed to be in the carb? I run a 3,4L with a weber 38DCOE carb.
TKM
TKM
Go Hard or Go Home!!
- Vehicle: v6 essex
Re: Essex v6 3.0
Hi TKM, the main jets(145) Em. Tube(F50) air corr. Jet(185) idle jet(45) pump jet(70) pump exh.(30) needle valve(2.50) float level (MM) O/C (52.5/40). That's all the standerd parts for the 38 webber DGAS and DGES
- Vehicle: v6 essex
Re: Essex v6 3.0
The only DCOE I found would be a 40 weber.
- Vehicle: v6 essex
Re: Essex v6 3.0
And the DCOE is a weber sidedraft to my knowlage correct me if I'm wrong please
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Essex v6 3.0
DCOE is a side, they come in 40, 45 and 48mm.
The DGAS for the V6 has 38mm butterflys, but it comes in either 27 or 29mm venturis (stamped on the side and not removable), the 27mm is the one to get for a 4x4, more torquey and lighter on fuel. On reef altitude, you can go to 205 on the airs for better consumption.
aev@iburst.co.za
- TKM
- Real Name: Karl
Re: Essex v6 3.0
Sorry gents! Chrisv6 you are correct.... its a DGAS.... my memory played up!
Thanks for the info, I will check them asap.
Does anyone perhaps know where I could source the solenoid valves on the side of the carb? one of mine is faulty, but still need to check which one..... It has happened before but we battled to find one here in PE.
Thanks again for info!
- Sifu-Lux
- Real Name: Andrew
Re: Essex v6 3.0
Not sure what you mean about solenoid valves on the carb, mine does not have?
- Town: LANGS DIE ORANJE RIVIER
- Vehicle: 1994 2.2 Hilux
- Real Name: Lehan
Re: Essex v6 3.0
Ek het ook ook die 38weber dgas op my V6, maar daar by staan 4A2 en op n spaar weber staan daar by net 9A. Daar is n paar verskille tussen die 2. En die grootste een is dat die 4A2 glad n petrol return het nie! Het enige van julle al dit raak geloop?
- Vehicle: none
- Real Name: Julien
Re: Essex v6 3.0
Hi Guys
I've been reading this thread with interest, as well as any other threads about the Essex V6.
I have one in my Series 3 88" landy.
I have had alot of help from:
David Van Jaarsveld
Supreme Auto
Parkin Street
041 484 7701
Tell him Julien sent you.
He has helped me with setting the carb and changing jets etc.
Bear in mind he is an old school mechanic that used to work for Opel Motorsport.
He works on anything though.
This week I have seen from 50/60's Jaguar to a 3 or 4 year old Merc ML 320 diesel
Cheers
Julien
David Van Jaarsveld
Supreme Auto
Parkin Street
041 484 7701
Cheers
Julien
- Sifu-Lux
- Real Name: Andrew
