Hi guys I know this is a sore subject but i need advise.
My baby has a 7mge engine in, now ive got 35" tyres and steel bullbars front and back, rooftop tent, gona be building a alucab soon.
this is whats wrong with it so far- number 1 sparkplug get wet with fuel every now and again
- leaks oil almost everywhere
- power steering pump gives me about 10km/l
Should i just simply repair all the faults.
Buy a import for about 7k.
Or go for gold and put a lexus v8 in.
7mge or lexus v8
- sidewaysfrans
- Town: Brakpan
- Vehicle: 1988 hilux, 7m engine, OME suspension, snorkel, ARB bumpers, 120l s/s fuel tank,diff locks f/b
- Real Name: frans
- Scorpion
- Town: Emmarentia
- Real Name: Johann
Re: 7mge or lexus v8
That is a difficult question, as it will be determined by your budget and the "itching factor"...
The problem with going Lexus is that it's a whole new conversion with all the associated headaches. The cost would be much more, as you would need new EMS, new bellhousing, new engine mounts, etc. It's massive job with a lot of extra costs. And you most certainly will not get 10km/l with 35" tires! I get about 7km/l on mine - still beter than the 4,5 I got on the 4Y, but certainly not a good as yours...
As for buying a new import motor, or repairing your existing one. If you have had your 7M for a while and know it's quirks and condition, I would rather repair it (depending on the cost). A "new" motor is also not new and you do not know what you get until it's fitted, started and driven. On my "new' lexus we had to do belts and water pump shortly after fitment and the same (or worse) could happen with a "new" 7M. If you repair yours then you know what's been done and what condition it's in. But then again if it's going to cost R30k to fix, then buy an import - R25k is a lot of change to fix problems...
Good luck!
Good luck!
1978 Land Cruiser HJ45
If you can afford the 60K+ bill, the Lexus V8 is the clear winner!
If you got budget constraints don't even consider the V8, it always costs a packet more than you originally thought! Then, if you can find a decent condition import 7MGE, go for it... even by today's standards it's an excellent engine and they are starting to get a bit more scarce, so keeping the old one for spares would be handy! Repairing your current engine will probably be more expensive than installing another import engine! Just don't forget the give the new engine a major service... and definitely replace the timing chain/belts!
- KOBUSL
- Town: WOLSELEY
- Real Name: KOBUS
Hallo Frans,
Wat die twee here hierbo se is die waarheid. Ons het 2 7M masjiene op die pad in 'n d/k SFA en die ou 3l diesel. Die een het ons nog geen probleme gegee nie, behalwe die nou-en-dan se olielekkie, maar die ander een het PRESIES dieselfde simptome as joune, en kragstuurpompe is skaars ( nie by die handelaars nie, maar ons het nie R 6k nie ) Dis heerlike masjiene, maar ek dink hulle tyd raak nou uitgedien. As ek kon sou ek Lexus gegaan het, maar die gras lyk mos altyd groener anderkant die draad. As jy dit oorweeg, is die geheim om dit by die regte plek te laat doen. Jy sal hier op die forum kan vasstel wie dit is. En ek glo nie dat 4x4 en 7 M en Lexus V8 in dieselfde asem as brandtofbesparing genoem kan word nie.m50c
If you wanted to do an engine conversion from scratch, I would say Lexus. But seeing as you have the 7M already, I would say save yourself a heap of frustration and fix/replace the one you have.
I am also a 7MGE veteran,and loved it to bits... Most fantastic Hilux I ever owned, and I had a few...
- sidewaysfrans
- Town: Brakpan
- Real Name: frans
Thanks guys im thinking im going to buy a import 7mge i found one with a wiring harnes and fuse box for R7500
