Engine swap possibilities? YN57R 3Y petrol
Posted: Sun Oct 15, 2017 2:41 am
Hello friends,
I have a YN57R, I believe you call these Bakkies over in SA, but mine is the 2wd model (terrible I know, I'd love a 4wd chassis to put my body on). I am having never-ending problems with my carbureted 3Y engine.. New leads, spark plugs, distributor rotor and cap. Carburetor cleaned out, new gaskets and plunger from E-bay. Anti-dieseling solenoid cleaned with fine grit sandpaper, lubricated with WD-40 and hardwired to the ignition to bypass the emissions control box. Spayed all around the motor with engine degreaser with no signs of a vacuum leak. Yet it still refuses to idle properly
I have a few questions for the forum; Is the idle air/fuel mixture screw supposed to be wiggly? It is on both my carburetors, perhaps both of them are stuffed..?
2nd; Will a R151 auto transmission fit inside my gearbox tunnel? Is it hard to convert a 4wd auto transmission to a 2wd transmission? I'm contemplating putting a 1KZT-E 3.0 turbo diesel engine, or perhaps a 3RZ-E 2.7 petrol in my pickup. I have a feeling the 3rze and the gearbox will be closer to bolting up than the 1KZ.
Any feedback appreciated... Thanks from New Zealand
