Hi
Is the airconditioner unit in the Fortuner D-4D Auto really a "Climate Control" unit, where two different zones(front left and front right) can be maintained at different aircon settings in the car? Somehow when I looked at this feature it seemed to be just a single aircon unit with one setting for the entire front of the car...I do understadn that the rear system is operated seperately...or is that what is referred to as the "slipt" system?
Fortuner D-4D 3.0 Auto - DUal Zone A/C or not really?
- Blackadder
- Vehicle: Toyota Fortuner 3.0 D4D, Ironman Bumper, OME, Dual Battery, BFG'S, TJM Snorkel, Navstar 220 29mhz radio, LAS Pro Rear Bumper, Frontrunner Roofrack
- Real Name: Thinus
- Club VHF Licence: X82
Re: Fortuner D-4D 3.0 Auto - DUal Zone A/C or not really?
The only settings you can change in the rear is ON/Off and the air flow. Other than that it's pretty much up to what you do in the front. Temp stays the same. Definitely not climate control and definitely not able to set left and right independently. This is pre-facelift. I'm not sure if it changed with the later models.
On the new 'facelift' it does NOT work independently.WildWill wrote:Hi
- Vehicle: 2011 Toyota Fortuner 3.0 D4D 4x4
- Real Name: Jaco
The new model does have climate control (set a temp and the AC cools down to that) but it does not have independent heating/cooling for L and R.
