KZ sukkel om in die oggende te start - BATTERY Probleem!!!!!
rood
Town: Polokwane
Vehicle: 4LT V6 Prado 120, 3L Extra cab D4d 4x4, Suzuki SJ413
Real Name: rood
Post by rood »
die laaste 3 oggende sukkel my KZ on te start, klink of die battery pap is, maar hy is 12.9 volt, en charge 14 volt as die motor loop, :beg: as daar emige iemand raad kan gee.
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
Re: KZ sukkel om in die oggende te start
Post by JJBotes »
Myne sukkel nou-en-dan in die oggend,nou al vir meer as 'n maand.Veral as dit koud is.
Ek het die battery en glow plugs laat toets,by `n ander plek gaan diesel gooi en die bakkie gediens, maar hy het nog steeds sy streke.
Ek sal maar hier dop hou, dalk noem iemand iets waar aan ek nie gedink het nie.
:confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
:thumbup:
warrenaken
Town: JHB
Vehicle: 3.0 KZ-TE 4x4
Real Name: warren
Club VHF Licence: X04
Post by warrenaken »
Toyota Hilux KZ-TE
rood
Town: Polokwane
Real Name: rood
Post by rood »
IS TOE DIE BAKKIE SE BATTERY WAT SOMER MAAR NAT OP GEPAK HET, die battery is maar 14mnde oud SABAT Batery. Watse battery stel enige een voor sit ek in?
Re: KZ sukkel om in die oggende te start - BATTERY Probleem!
Raylite Silver Calcium.
It's the cold weather .... if a battery is getting weak, the cold pushes it over the edge. However there should be a claim on the old one .... 14 months is not acceptable.
Post by Family_Dog »
+1!!
AM Racing
Real Name: Dylan
Post by AM Racing »
Bosch-2 year warranty
Donkey
Town: Johannesburg
Club VHF Licence: X122
Post by Donkey »
Hi Rood
Is the truck still battling to start? :?: Change the diesel filter, if you have not done so already, it could be a solution. On very cold mornings I've also had to turn the ignition on about 3 times, allowing for the chambers to warm up sufficiently, and then it starts with no hassles.
A weak battery could also be your problem since I suspect it is slightly harder to turn a diesel engine upon starting, and it also has to be turn fairly quickly since diesel ignites on compression and not spark as is the case in petrol engines. I stand corrected on this one but hope the fundis will advice better.
I hope this helps a bit.
Please keep us posted. :thumbup:
Tumelo Maketekete
