Hi guys. I recently bought a 1998 Toyota Prado GX V6. This weekend I noticed a small leak in the extra fuel tank. It is clear that the area has been welded previously. I plugged the leak temporarily (extra tank was mostly empty anyway) but need to get it fixed properly. I'm new to Joburg and haven't yet found a reliable mechanic or auto shop in the area. Can anyone recommend someone please? I also need to give the car a service and would like to make some modifications. Someone reliable, good with Toyota's and won't rip me off. Preferably Joburg northern suburbs, but can also be elsewhere.
Thanks!
Prado mechanic in JHB?
Re: Prado mechanic in JHB?
I had my tank repaired at Siverton radiators in Kdorp. But you will have to remove it and take it to them, quite easy if it is empty. They flush and welded it proberly for about RR350.00.
- Vehicle: 98 Toyota Prado GX V6
- Real Name: Simon
Thanks Oooms, problem with mine is that the connection is the bracket holding the tank to the body is the problem - so they would need to change that too.
He will make a bracket for you, no problem. he has built tanks for me.Joburg1 wrote:Thanks Oooms, problem with mine is that the connection is the bracket holding the tank to the body is the problem - so they would need to change that too.
