22r mods
- gert-redelinghuys
- Town: polokwane
- Vehicle: 1996 hilux 2.4 4x4 dc raider rear locked 31 maxxis bighorns 2 inch lift
- Real Name: gert
22r mods
the reason why you should not swap your 22r out
The 20R 2200cc. / 22R 2400cc. engines were the most popular US Toyota engines. For 20 years, 1975 to 1995, these motors served as U.S.Toyota's dependable workhorse engine. These engines powered the popular Celicas until 1985, and the unbreakable Pick-up models used these engines until 1995 (in commercial models). Turbo models appeared briefly as the 22RTE in 1985-1988 on Pick-up and 4Runners. The 22RE Fuel injection models appeared in 1983, on some Celica and Pick-up models. In 1985- the 22RE had a major change. The block was taller and the head shorter, compared to the earlier models. The engines' blocks and heads are not interchangeable (for practical and cost purpose).
The engines are OHC design, with hemispherical combustion chambers. The cross-flow head was very efficient, short of a 2 or 4 valve (per cylinder) Twin Cam. The long stroke provided a lot of torque at a reasonable RPM range. The engine responded well to all the tuning tricks. The 20R head is different from the 22R heads. The 20R had open combustion chambers and the 22R had a swirl-inducing chamber (for cleaner emissions). The intake ports on the 20R were round, and rectangular on the 22R. Exhaust ports were identical round design. The later 22RE (with the shorter deck height) had keyhole shaped exhaust ports. There were available 22RE models that used the earlier 22R head, in the 1982 to 1984 Celica GTS. All 22RE from 1985 used the later blocks and heads.
The 22RTE Turbo engine was based on the later model 22RE (short block /tall head). This is a similar but entirely different block and head. The block was drilled with different oil passages to accommodate the Turbo oil requirements. The cylinder head's combustion chamber had a different shape. The piston was dished. Advertised horsepower was 145. The factory set the boost at 5.5-6 pounds, but completely stock internals survived boosts of up to 17-22 pounds, with proper fuel injection modifications. This is a testimony to the bulletproof bottom end design. Nitro / Methanol fueled dragsters, producing in excess of 1100 HP- used the original (modified) crankshafts and TOYSPORT pistons!
Toysport built the first 2400 cc. 20R, these evolved in the 20/22R hybrid engines, in the later years when the 22R engine was introduced in 1981. The 20R head holds a distinct advantage over the 22R / RE heads, it flowed better. The availability of big valves extended the tuning potential for the 20R (and all the other engines).
There was a Japanese version 21R 2000cc, which had both an early and late model cylinder head similar to the 20R and 22R. These were imported due to the big demand for used engines. There is nothing of interest from these engines.
In 1985 Toysport raced a 22RE Toyota Celica GTS in the Macao Grand Prix. The original plan was to use an 18RG, but since the vehicle had US serial #'s (from Toyota Motorsport) we were forced to use the U.S. engine the 22RE! To the entertainment of the other Toyota Teams from Japan, we qualified at the last minute, in the last half of the grid. The other Celicas (with their Twin Cams) were all in the top 6 positions. At the finish the Toysport Celica placed 3rd- behind 2 BMW Motorsport prepared 6 cylinder BMWs! This is the highest finish achieved by the 22RE in international racing competition.
From 1984 to 1989 Toysport prepared a Spec-Engine for SCORE / HDRA Toyota private entrants. The winnings from the Toyota Contingency Program testify to the racing capability of the set-up. The engine package kit is still available, as complete engines. This set-up won National Championships for Toyota in Class 7 and Class 7 4WD. The carbureted engines developed 185-195 HP, but consistently out ran the 239-240 HP Ford engines in the same class. The secret is in the torquey characteristics of the power band. The limiting factor of this engine is also its strongest point. The long stroke limits RPM capability to about 6200 maximum, but the bottom end will take a lot of abuse. The crankshaft is forged.
Modifying the 20R / 22R / 22RE / 22RTE Engines
BLOCK: The best set-up is achieved by starting with a 20R head and a 22R early block. This allows the use of the twin-row timing chains- over the late model single-chain type. Boring the 20R to 92mm is possible but some castings will develop bubbles in the bores that eventually clean up at 92mm. The high compression pistons for the 20R / 22R are forged. The stock early 22RE piston (full crown type) can also be used under the 20R head but the block and deck must not have more than .5mm cut, if used with big valves.
The 20R / 22R early and 22RE late model, responds well to high compression pistons. The rods can be prepped by stress relieving and shot-peening. The crankshaft oil galleys may be chamfered. High Tensile bolts can be upgraded to ARP- main, rods, and head bolts or stud kits.
The early and late style blocks have different engine mounting bosses, so interchangeability of late block to early chassis and vice versa may come up. Some early and late blocks have provisions for both. Really early and really late blocks do not have these provisions. When preparing an engine, make sure that the block has the correct mounting boss- or else you will have to deal with modifying them mounts.
The 22RTE with forged pistons will survive 25 lbs! A metal head gasket is required.
CYLINDER HEAD: It is mandatory to port all the heads. Big valves are also necessary to achieve and maximize the flow. Avoid cutting more than .50mm since valve clearance may be a problem with some piston combinations. Tri-Y headers work the best because they complement the wide torque band of these engines. If you are converting into the 20R head make sure that the 20R head has provisions for power steering (if you have power steering).
The choice in camshafts from many sources, must be carefully considered. High lift and long duration cams may affect the rocker arm geometry (and oil spraying function of the oil feed). Unless you take the time to ensure that the rocker arms are repositioned correctly (modifying the rocker assembly) do not even attempt. The long stroke / low RPM design of the engine dictates very mild cam lift and duration. You cannot redesign an engine with camshafts! Mild cams up to about 280 duration will work with the EFI with some adjustments to the AFM (air flow meter).
Stiffer valve springs are a safeguard from valve-float, but will not enhance performance since the best cam profiles will run fine with stock valve springs. An adjustable camshaft gear will allow the most accurate setting (remember that a Celica is totally different from a 4WD Pick-up).
There are no TwinCam heads available for these engines.
The 22RTE head chambers can be opened to lower compression and increase the flow. Big valves should also be considered, but not obligatory since this is forced induction.
FUEL SYSTEM: Twin side draft carburetors are a natural choice, but the EFI system will work excellent if the vehicle is originally equipped with one. (Some manifolds for the dual carbs have poorly designed water outlets that may cause overheating.) Long duration cams will seriously affect EFI engines, since combustion pressure drop dramatically even with high compression pistons. A fuel pressure adjuster may be needed. The Weber 32/36 or 38DPS are good upgrades for single carb set-ups. For carburetors, use a low pressure, high volume fuel pumps. Do not try to regulate lower fuel pressure with an adjuster because volume will also decrease. A fuel return line is mandatory to allow the fuel pump and carburetor to function properly. For any kind of performance do not rely on Toyota's mechanical or electric pump, they do not have enough volume. The 22RTE with any upgrade will need a higher output pump. The fuel pressure regulator should also be upgraded.
TURBO UPGRADE: The 22RTE needs forged pistons for any serious performance upgrade. The CT26 Supra Turbo (not the MR2/AllTrac) can be installed with minor fabrication. With boost controller, upgraded fuel delivery, 3" exhaust system, and intercooler- the 22RTE will put out in excess of 350HP, at about 25 psi!
Normally aspirated 20R / 22R engines can be turbocharged without too much problems. The stock pistons have to be replaced with low compression forged units.
IGNITION SYSTEM: The basic ignition unit was designed for low revving conditions. The electronics must be updated to the performance level intended for the engines. EFI engines converted to carburetors must use carburetor style distributors. Ignition amplifiers and knock sensors must be used to avoid high RPM misfires and detonation.
Some Recommended Set-ups:
For stock configuration- the 20R / 22R / 22RE engines are very easy to work on. Due to different emission requirements for the different model years, try to work on the original engine. Porting the head will increase breathing and will not hurt emissions- so basically to stay legal and improve performance- the cylinder head must be ported. The early 22RE pistons can be used to upgrade the 20R to 2400cc.
For modified configuration- the 20R head on top of early 22Rs will instantly give higher compression. All heads must be ported with big valves installed. Be careful of camshaft choice, just remember that all slow modified 20 / 22R / 22RE engines have been over-cammed. Do not try to install cams with duration over 280 on single carb or fuel injection models. Twin side carburetors are the best way to go. For limited budget use the Weber 38 DPS. Headers installed with 2 3/4" exhaust will be optimal. A heavier flywheel will help 4WD models, that should also have the gear ratios changed to compensate for tire sizes.
For racing configuration- basically these engines are truck engines. For off-road truck racing and high performance street use (both pick-ups and Celicas) the Toysport Spec SCORE / HDRA set-up is reliable and impressive. See the parts list for the 20R / 22R engines.
Although we have successfully used the 22RE in circuit racing and rallying, and truck off-road racing- the only reason these engines were used was because of the race regulations. The handicap is the block configuration- which was built for torque and longevity- meaning slow and heavy. The cylinder head modifications, if properly done increases head flow by up to 200%.
For turbo set-up- forged pistons, ported head with open chambers, big valves, TO4 or CT26 turbo, 3" exhaust, mild cam, Carillo Rods, boost controller, blow-off valve and keep the boost under 25 psi!!
Copyright 1999 / 2000 © Toysport Limited.
lock and crawl
niks loop soos `n john deere nie , behalwe `n hilux bakkie met `n john deere sticker agter op die bak
- Rooies
- Town: Strand
- Vehicle: 1994 2.4i (22RE) D/C Raider 4X4
- Real Name: Rudi
Re: 22r mods
Baie lekker lees materiaal Gert.
ROOIES: 1994 2.4i (22RE) Raider D/C - 200 000kms - Brospeed Branch & Powerflow Exhaust
MIKEM Suspension & Gabriel Safari Shocks - "31 BF Goodrich AT - GOMAD Aluminium Canopy
Melvill & Moon Seat Covers - Safari Snorkel - Bushwakka Weekender Offroad Trailer
Re: 22r mods
Interesting, Gert. Thanks!
- Rooies
- Town: Strand
- Real Name: Rudi
Re: 22r mods
SIES CSSIE MAN HOE MOET ONS NOU VOEL. Het vandag ou ROOIES se injectors by Bosch gaan ingee. Die ou daar het nogals gevra hoekom wil ek hulle laat diens want die Denso gee nooit probleme nie. So nou kan Hoppy binnekort met die conversion begin.
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
nou moet die. vrae gevra word het ons die nuwe 22r of die ou 22r motors in en waar gaan ons die 20r head kry , het iemand so iets al probeer ? een van my vriende het die 22re in sy lux met n 262 cam in stock head hy reken groot verskil in krag
lock and crawl
- Rooies
- Town: Strand
- Real Name: Rudi
Re: 22r mods
Gert n mens moet net seker maak as jy die cam sny dat jy nie met die low down torque voeter nie. Gewoontlik met daardie cams is die performance baie beter maar jy het ook meer rpm nodig. Wat nou weer bietjie slegter is as jy gaan 4X4.
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
Re: 22r mods
Gert, our 22R's are the later versions with the single cam chain. The heads are not interchangeable between the new & old versions.
Re: 22r mods
Ons kry nie die ou tipe 22R blocks hier nie. Ons s'n is almal van die nuwe tipe. Ja het al daarvan gehoor, die oens in die VSA doen daai hybrids gereeld. Hou net nie van die Weber carb idee nie ... op 'n street-racer miskien, maar nie op 'n 4x4 nie. Ek hou ook nie van cams ruil nie ... myne is nie std nie en ek probeer nog uitvind watse cam my enjin in het ... vermoed dis 'n 'mild' cam maar miskien 'n bietjie op die wilde kant.
- GeorgeJvR
- Town: Louis Trichardt
Re: 22r mods
Baie interesant dankie
Kom wat wil ek bly 'n Bul!
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
Re: 22r mods
Wonder self oor my CRD cam....sal dalk 2 keer moet dink oor die EFi Die enjin kan nog idle so ek skat die cam is mild...hy ry net lekker op 120km/h
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
die vriend van my het die marlin crawler 262 crawl cam in op efi 22r met standard Toyota fuel management , hy bly in amerika . ek sal gaan vir die cam maar sal beslis gaan invest in n vernier cam sprocket dan kan jy die cam mooi in dail , ek stem saam met die weber carb setup ek sal as ek moet vol uit gaan sal ek gaan vir I T B s (independent throttle bodies) soos wat rsi 20v op het met n goeie fuel injection system
lock and crawl
- GeorgeJvR
Re: 22r mods
Wat is die kostes op so 'n vernier cam sproket storie?
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
hier is n prys lys van toysport
AMSHAFT
BRAND
PRICE
ISKY
Duration: 280 / Lift: 11.18mm
$ 150.00
Duration: 300 / Lift: 11.82mm
$ 150.00
Duration: 310 / Lift: 12.82mm
$ 150.00
TRD
Duration: 262 / Lift: 10.50mm*
$ 120.00
Duration: 272 / Lift: 10.90mm
$ 120.00
Duration: 282 / Lift: 11.30mm
$ 120.00
MIKUNI
Duration: 268 / Lift: 10.50mm
$ 130.00
*Smog Legal
CAM-SPROCKET
BRAND
PRICE
HKS
Adjustable, ~84
$ 150.00
LC
Adjustable, 85~
$ 150.00
VALVES
BRAND
PRICE
TOYSPORT
Over Size, Intake, 44.0mm S.S., 20R
$ 15.00
Over Size, Exhaust, 36.0mm S.S., 20R
$ 15.00
Over Size, Intake, 45.6mm S.S., 22R
$ 15.00
Over Size, Exhaust, 38.0mm S.S., 22R
$ 15.00
Bronze Valve Guide
$ 4.00
JAPAN
Rocker Arm Set with Adjusters
$ 150.00
VALVE SPRING
BRAND
PRICE
ISKY
Inner Valve Spring
$ 36.00
GASKETS
BRAND
PRICE
TOYSPORT
Copper Head Gasket (Racing
Puposes Only, 0.7mm or 1.2mm)
$ 75.00
JAPAN
Engine Overhaul Gasket Set, 20R
$ 100.00
Engine Overhaul Gasket Set, 22RE
$ 110.00
Engine Overhaul Gasket Set, 22RTE
$ 145.00
Head Gasket Set, 20R
$ 80.00
Head Gasket Set, 22RE
$ 100.00
Head Gasket Set, 22RTE
$ 100.00
Cylinder Head Gasket (20/22R O.S.
94x1.0mm)
$ 25.00
Valve Cover Gasket
$ 5.50
Valve Cover Grommet Gasket (~84.8)
$ 1.10
Valve Cover Grommet (84.9~)
$ 2.50
Valve Cover Plug (half-moon)
$ 1.70
Timing Cover Gasket
$ 6.50
Oil Pan Gasket
$ 7.50
Intake Manifold Gasket, 20R
$ 7.50
Intake Manifold Gasket, 22R
$ 7.50
HKS
Cylinder Head Gasket, Metal
(93.5x2.0mm)
$ 160.00
THORLEY
Exhaust Manifold Gasket (Headers)
$ 12.50
PISTON SET
( INCLUDES PISTON, PIN, LOCK,
AND RINGS)
BRAND
PRICE
WISECO
Forged, 89.0mm, High Compression,
~84
$ 345.00
Forged, 90.0mm, High Compression,
~84
$ 345.00
Forged, 92.0mm, High Compression,
~84
$ 345.00
Forged, 92.5mm, High Compression,
~84
$ 345.00
Forged, 94.0mm, High Compression,
~84
$ 345.00
85~
$ 345.00
VENIOLA
Forged, 0.5mm Over/ Low Comp.
8.5:1, 22RT
$ 500.00
TIMING CHAIN KIT
BRAND
PRICE
JAPAN
Single Row, 84.9~
$ 129.95
Single Row, ~84.8
$ 129.95
Double Row, ~84.8
$ 83.50
OIL PUMP
BRAND
PRICE
JAPAN
OEM Type, 84.9~
$ 100.00
OEM Type, ~84.8
$ 100.00
BEARINGS
BRAND
PRICE
JAPAN
Main Bearing Set
$ 50.00
Con-Rod Bearing Set
$ 22.00
ASSEMBLY BOLT
BRAND
PRICE
ARP
Head Stud Kit
$ 170.00
Rod Bolt Kit
$ 45.00
let op dat die double row chain kit goedkoper is as die single row
AMSHAFT
BRAND
PRICE
ISKY
$ 150.00
$ 150.00
$ 150.00
TRD
$ 120.00
$ 120.00
$ 120.00
MIKUNI
$ 130.00
*Smog Legal
CAM-SPROCKET
BRAND
PRICE
HKS
Adjustable, ~84
$ 150.00
LC
Adjustable, 85~
$ 150.00
VALVES
BRAND
PRICE
TOYSPORT
$ 15.00
$ 15.00
$ 15.00
$ 15.00
Bronze Valve Guide
$ 4.00
JAPAN
$ 150.00
VALVE SPRING
BRAND
PRICE
ISKY
Inner Valve Spring
$ 36.00
GASKETS
BRAND
PRICE
TOYSPORT
$ 75.00
JAPAN
$ 100.00
$ 110.00
$ 145.00
$ 80.00
$ 100.00
$ 100.00
94x1.0mm)
$ 25.00
Valve Cover Gasket
$ 5.50
$ 1.10
$ 2.50
$ 1.70
Timing Cover Gasket
$ 6.50
Oil Pan Gasket
$ 7.50
$ 7.50
$ 7.50
HKS
(93.5x2.0mm)
$ 160.00
THORLEY
$ 12.50
PISTON SET
AND RINGS)
BRAND
PRICE
WISECO
~84
$ 345.00
~84
$ 345.00
~84
$ 345.00
~84
$ 345.00
~84
$ 345.00
85~
$ 345.00
VENIOLA
8.5:1, 22RT
$ 500.00
TIMING CHAIN KIT
BRAND
PRICE
JAPAN
Single Row, 84.9~
$ 129.95
Single Row, ~84.8
$ 129.95
Double Row, ~84.8
$ 83.50
OIL PUMP
BRAND
PRICE
JAPAN
OEM Type, 84.9~
$ 100.00
OEM Type, ~84.8
$ 100.00
BEARINGS
BRAND
PRICE
JAPAN
Main Bearing Set
$ 50.00
Con-Rod Bearing Set
$ 22.00
ASSEMBLY BOLT
BRAND
PRICE
ARP
Head Stud Kit
$ 170.00
Rod Bolt Kit
$ 45.00
lock and crawl
- GeorgeJvR
Re: 22r mods
Eina daar skuif my EFi up grade so pas bietjie aan as ek so aanhou gaan ek 'n wilde 22RE hê so ek sal moet ophou lees
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
dan moet jy eerder weg bly van lc engineering se web site af haha http://www.lcengineering.com" onclick="window.open(this.href);return false;
lock and crawl
- GeorgeJvR
Re: 22r mods
Jy bring 'n man darm vreeslik in die versoeking :razz:
- GeorgeJvR
Re: 22r mods
Nice websitegert-redelinghuys wrote:dan moet jy eerder weg bly van lc engineering se web site af haha http://www.lcengineering.com" onclick="window.open(this.href);return false;
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
kyk bietjie hulle crate. motors uit , daar sal mens darem baie held spandeer
lock and crawl
- GeorgeJvR
Re: 22r mods
Don't stare in to the light!
... :alvarin:
... :alvarin:
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
foto 1 : adj cam gear
foto 2 : lc engineering branch manifold
foto 3 : 22 r / re stage 5 pro off road
specs :22R/RE Stage 5 Pro Stroker Off Road Long Block
When you're ready to play with the big dogs, look no further than LC Engineering's Stage 5 series race engines! LCE's engine department has built some of the strongest 22R engines on the planet. Based on over 20 years of experience and countless hours of research and development from all forms of racing, we can supply you with not only some of the most powerful race engines, but also some of the most reliable. The Stage 5 is the accumulation of all these years of experience. Starting from the completely studded block (ARP head and main studs) to the radically modified cylinder head, there is no match for LC Engineering's Stage 5 race engines. All of our motors come blueprinted, assembled, and dyno tested.
ALL STAGE 5 SERIES ENGINES COME WITH THE FOLLOWING COMPONENTS:
LCE Pro Stroker Crankshaft & Crankshaft Scraper
LCE Chromoly H-Beam Connecting Rods
Oil Pan
LCE Pro Block Brace
Clevite Main, Rod & Thrust Bearings
Brand New Water Pump
LCE Pro Oil Pump & Oil Pump Bypass (Pressure Adjustment)
LCE Dual Row Timing Chain Kit & New Custom Timing Chain Cover
ARP Head Studs & ARP Main Cap Studs
Radically Ported Cylinder Head (Brand New Casting) & MLS Head Gasket
New OEM Aluminium Toyota Rocker Arms & LCE Pro Rocker Shafts
LCE Dual Row Adjustable Cam Gear
LCE Dual Valve Springs & Titanium Valve Spring Retainers
NGK Spark Plugs
Billet Oil Cap
LCE Pro Water Block Plate Kit
LCE "Red Head" Race Valve Cover
94mm Forged Pistons (Your Choice of Compression Ratios)
48mm Stainless Steel Swirl Polished Intake Valves & 40mm Stainless Steel Swirl Polished Exhaust Valves
Your Choice of Custom Performance Camshafts
power : 201.9hp (150kw) @ 5600
torque : 198 lb/ft (268nm) @ 5000
Oil Pan
LCE Pro Block Brace
NGK Spark Plugs
Billet Oil Cap
- Attachments
- stg5longblock.jpg (15.22 KiB) Viewed 5314 times
- STAGE5.jpg (27.48 KiB) Viewed 5314 times
- 1041024.jpg (33.2 KiB) Viewed 5314 times
- 1022006.jpg (13.6 KiB) Viewed 5314 times
lock and crawl
Re: 22r mods
Their vernier sprockets sound a bit pricey .... at over 1k plus shipping I would rather get an oem sprocket and take it to an engineering works locally.
Interesting site though!
- gert-redelinghuys
- Town: polokwane
- Real Name: gert
Re: 22r mods
m.youtube.com/watch?gl=US&hl=en-GB&client=mv-google&v=wMbxILPIKRg
22 r stage 5 op n enige dyno
lock and crawl
