Gooseneck on Trailer
Your view on different camping gear, off-road trailers and nice non-electronic gadgets
oxydog
Vehicle: '98 Hilux SFA 2.8D 4X4 D/C, '06 Hilux 4.0 V6 4X4 D/C
Real Name: Jarus
ORRA Call Sign: J67
Mon May 28, 2012 2:24 pm
We acquired a bicycle rack this weekend (Thule 3-bike, fits onto gooseneck and can swivel to provide access to canopy). I would now like to attach a gooseneck to my offroad trailer (modified Venter), so that I can attach the rack to it should we take the trailer on holiday as well. Will the trailer's chassis be strong enough or will I have to reinforce it first? Where can I have something like this done?
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG MT's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Eurolux 1500W inverter
• Midas driving lights
• 31" BFG AT's
jacques kotze
Town: Nelspruit.
Vehicle: Prado 4,0 V6, dual battery & 3.0 D4d S/C 4x4,front replacement,12000lbs winch.
Real Name: Jacques
Mon May 28, 2012 2:32 pm
If possible, load a picture of where you want to fix the gooseneck to the trailer.
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Mon May 28, 2012 2:47 pm
Thanks Jacques, I'll do that.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
MOFASA
Real Name: Johno
ORRA Call Sign: X119
Mon May 28, 2012 3:09 pm
Reinforce and fit........ :thumbup: as the tow bar on a car or bakkie is stronger than the frame of your trailer...........
Should be an easy diy :thumbup: :thumbup:
ImageImageImage[rimg=206x128]
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Mon May 28, 2012 3:31 pm
MOFASA wrote:Reinforce and fit........ :thumbup: as the tow bar on a car or bakkie is stronger than the frame of your trailer...........
...aaaaand that's where my problems start - I'm not really a DIY kind of guy. I always end up making something that doesn't work and looks ugly and then have to get someone to fix it. :oops: But I have friends who can help me there! :thumbup:
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
MOFASA
Real Name: Johno
Mon May 28, 2012 3:51 pm
oxydog wrote: ...aaaaand that's where my problems start - I'm not really a DIY kind of guy. I always end up making something that doesn't work and looks ugly and then have to get someone to fix it. :oops: But I have friends who can help me there! :thumbup:
Hmmmmmmmmm ok well ask the friends.......... :thumbup: :thumbup:
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Mon May 28, 2012 4:08 pm
Cool man, thanks for the advice.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Tue May 29, 2012 10:53 am
As promised...
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
jacques kotze
Town: Nelspruit.
Real Name: Jacques
Tue May 29, 2012 10:59 am
By the looks of it you don't need much improvement on the frame where you want to fix the goose neck, if it is only M Bikes you want to carry.
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Tue May 29, 2012 12:25 pm
jacques kotze wrote:By the looks of it you don't need much improvement on the frame where you want to fix the goose neck, if it is only M Bikes you want to carry.
That would be great, Jacques. Yip, just the 3 bikes.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
Maddoglips
Town: P.E.
Vehicle: Raider 2.2 4x4; Mikem 50mm raised suspension, long range tank, Monroe gasses all round.
Real Name: Zane
Tue May 29, 2012 1:29 pm
Hi M8
If you planning on fixing to the "steps" square frame, I would recommend putting in a cross brace either side just to give that bit extra.
If you planning on taking the 3 bikes with offroading, the jolting could be abit much otherwise.
Good Luck
Tue May 29, 2012 8:38 pm
How thick is the material where the two bolts go through the valance under the tailgate? :think:
This area of the frame's mounting is where it becomes critical. Instead of just the two lugsw and two bolts I would rather weld in a longer section of 5 x 30mm flat bar (about half the width of the trailer) centrally positioned of course, with at least 5 bolts. Then it should be able to withstand jolts with the 3 MT bikes loaded. A lot still would depend on how secure the valance itself is.
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Wed May 30, 2012 12:15 pm
Andy, I'll check the material.
On the other hand, I'm just thinking - if that step can support my body weight (which is currently under 80 kg's because I was in hospital for 3 weeks, but normally closer to 90 kg's), surely the brackets supporting that will also support a gooseneck, bicycle rack and 3 Mountain Bikes? Or is this theory flawed?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
george
Vehicle: Prado 90 VX 3.4 V6
ORRA Call Sign: HC107
Wed May 30, 2012 1:51 pm
oxydog wrote:Andy, I'll check the material.
Jarus my advice will be to make it as strong as possible. 3 bikes while jolting around creates a lot of energy. I have lost a rack before.Not the goosneck but the frame itself. Even try to fix it right at the top of the rack to the trailer.
oxydog
Real Name: Jarus
ORRA Call Sign: J67
Wed May 30, 2012 3:21 pm
George, you're probably right. Rather over-engineer it than run the risk of losing it with the bikes! I know I won't be doing any overly rough terrain with the bikes on, but still, not worth taking any chances.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
Return to “Camping gear, Trailers and Other Non-electronic Gadgets”
