Fortuner 2009 4x4 dash light-urgent info needed
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
- Club VHF Licence: M18
Hi all
I'm about to buy a 2009 fortuner. On test driving it the 4x4 light on the dash didn't come on when 4x4 engaged. Dealer reckons this year model doesn't have a light, only has one for diff lock.
Is this correct?
Seems odd to me, surely there is a light to tell you if you in HL, LL , etc.
Please let me know if this is right or if the dealer is trying to pull a fast one?
Cheers
luke
Is this correct?
Cheers
luke
- ronnie
- Town: Durbanville
- Vehicle: Totota Fortuner 2006 4.0 V6 4x4; Long Range fuel tank; AmadaXtreme suspension; C-Tek D250S dual battery system
- Real Name: Ronnie
- Club VHF Licence: HC 141
Re: Fortuner 2009 4x4 dash light-urgent info needed
I have 2006 model and it definitely has a warning light when CDL is engaged. I cant see how the newer models dont have as it serves as a warning so you disengage when back on the road. Sounds fishy.....
- jacques kotze
- Town: Nelspruit
- Real Name: Jacques
I can assure you it has a light indicating 4x4 is selected.
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
Thanks guys, I'll ask the dealer tomorrow why they lying to me.
Cheers
Cheers
- ronnie
- Town: Durbanville
- Real Name: Ronnie
Please do tell us there response; it could be quite interesting :roll:
- Town: Durbanville
- Vehicle: Prado 120 VX
- Real Name: Jaco
- Club VHF Licence: B35
The Fortuner is a permenant 4WD....
SuidWes is correct!
Two wheel drive versions are equipped with a lockable rear differential, while four wheel drive versions of the 3.0 D-4D and 4.0 V6 further adds a heavy duty transfer case and a lockable rear differential, with a Torsen limited slip centre differential. The 4x4 versions of the Fortuner are permanently in four wheel drive mode and the driver can use the transfer case to switch between 4WD High and 4WD Low.
- Town: Durbanville
- Vehicle: 2010 Toyota Fortuner 4x4
- Real Name: Richard
Yes, perm 4WD, but when you lock the CDL (switch from H to HL) there is a light that comes on on the dash indicating this. From HL to LL lights up even more icons.
- Christian Kuun
- Town: Stellenbosch
- Vehicle: 2008 Tuna V6 4x4 Manual
- Real Name: Christian Kuun
Suidwes, yes and no. It is permanent 4wd but when we talk about engaging 4x4, we mean that the CDL is locked. Without the CDL engaged you will get slip when the vehicle is under strain. When locked, the light does come on to indicate that the CDL is locked and we consider it proper 4x4.
Wynkop Kuun
O82 6l5 8lO5
O82 6l5 8lO5
- Town: JHB
- Vehicle: Fortuner
- Real Name: Luke
Thanks guys.
After physically showing them the light on another fortuner they now agree it should have one.
Sometimes I wonder if the dealers even know anything about the cars they selling.
- Town: Durbanville
- Real Name: Jaco
Sure, same as the Prado - CDL light but no 4x4 H or L light
