Fortuner in limp mode
- Town: Boksburg
- Vehicle: Fortuner D4D 3.0
- Real Name: Stan
Hi guys
Driving a long distance for instance on the highway and the first stop I make lets say at the toll gate my Fortuner goes into limp mode. I switch off restart then it goes well again until the next high speed(120)trip, same story, otherwise no problems. Any ideas, the reason.
Stan
Stan
- TOYODA
- Vehicle: '89 YN67R with Ford V6 3.0
- Real Name: Tiaan
Re: Fortuner in limp mode
Before the realy clever people starts to comment....
Just a question:
Any mods done to the FT? Chip, LR tank or anything else?
It might help them to figure out the problem.
Just a question:
- jacques kotze
- Town: Nelspruit
- Real Name: Jacques
I would say 90% of limp mode cases is chip related. But could be a Injector/s.
- Town: Boksburg
- Real Name: Stan
JSB
Yes a chip, been in for 4years only now the problem
- Town: Boksburg
- Real Name: Stan
JSB
only 58000 on the clock
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Welcome, the the forum... Most likely a faulty chip or loose connection somewhere, is it more prone in humid/wet conditions?
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
99% chance it is a chip, or as in my case, an aftermarket cruise control .... the dealers asked me about 10 times if I had fitted a chip ....
- Town: Boksburg
- Real Name: Stan
Chris yes I have a aftermarket cruise control for at least 3 years now. What did you do at the end, remove it?
unplug it, drive around the block, plug it back in.
Had my Hilux for almost 2 years before the cruise control acted up .... had Toyota Upington busy for a while (we were on holiday and enroute to Kgalagadi). Young mechanic that figured it out.
Drove more about 11 months before it acted up again - unplug, drive around the block, plug in, and 3 months later it is still going fine .... go figure ....
unplug the "top" plug set, unplug the plug from the pedal mount. the "very top" plug now goes straight onto the pedal mount. (hope this makes sense .... )
- Attachments
- IMG_0200 (Small).jpg (57.04 KiB) Viewed 3756 times
- Town: Boksburg
- Real Name: Stan
Chris
So you unplug the one and then plug the other in that ones place?
jip.
Lets say I number them 1,2,3 from the bottom up.
Then 1 and 2 are the plugs for the cruise control unit.
3 was originally plugged onto the throttle mechanism.
the installers just unplug "3" and insert 1 and 2.
these are classical "male / female" plugs, so you cant get it wrong. :)
PS - like so many of these plugs it has a "clip" that must be pressed down before you can unplug it. You will have sit on your knees outside the vehicle, then lean in with your head near the pedals to see the plugs. A torch or head lamp works WELL :)
- Town: Boksburg
- Real Name: Stan
I checked it out now will do it before my next trip. Thanks
- Stephan_V
- Vehicle: 07 Hilux D4D
- Real Name: Stephan
Same thing with me. When I had it at Toyota they said the error code related to the throttle. They disconnected it and I have had it disconnected now for 4 months and have not had any issues.
Chris thanks for the info I will have a look and hook it up again.
- jacques kotze
- Town: Nelspruit
The chip need to be re-mapped every 40 000 km or so. Mine was in my Hilux for 5 years when it started to go into limp mode.
Stephan when the mechanic SHOWED me what they unplugged I asked about the option of plugging it back in .....Stephan_V wrote:Same thing with me. When I had it at Toyota they said the error code related to the throttle. They disconnected it and I have had it disconnected now for 4 months and have not had any issues.
He shrugged his shoulders .... and could not give me a clear answer.
So I decided to take a chance - plugged it back in and USED it all the way from Upington to Kgalagadi. NO ISSUES.
Actually had no issues for the next 10 or 11 months. On the second day of the issues being back I stopped next to road, unplugged, drove a 100m, stopped, plugged it back in and fine since then.
Seems to be a classic software glitch that needs occational re-booting ...
I use my cruise control way too often !! :) :) has saved me so often from the camera men with badges .... :)
