4Y refurb or fong kong replacement???
- Josh Edwards
- Town: Durbanville
- Vehicle: Toyota Fortuner 3.0 D4D 4x4 and 1988 Hilux d/c 2.2 SFA Alu Canopy, 130 Liter Fuel Tank
- Real Name: Josh
Hi Guys
My 4Y has 270 000km on it now and I'm unsure on whether I should replace it with a fong kong or have it refurbished. I don't have the knowledge to do a refurbishment myself which is why I was considering a midas 4Y and then using my Toyota accessories. It worries me that if I have it refurbished a proper job won't be done and I will just end up having more problems. I know 270 000km is nothing for a Hilux but I've had endless trouble with my motor and bad experience with the mechanics who were supposed to fix the problems...
Blown head gasket. . Twice!
Fuel pump packed up
Starter packed up
Voltage regulator intermittent
Tappet cover gasket leaking
Front and rear main seals leaking
Sump gasket leaking
Engine missing under load
All of which was sorted and is still haunting me again now
Any advice would be great !
Josh
Fuel pump packed up
Starter packed up
Sump gasket leaking
Josh
Re: 4Y refurb or fong kong replacement???
Think cost will be the main factor especially if you "have" it refurbished.
You must hope you use somebody who knows what he is doing, because not everybody can assemble an engine to last another 500,00km, especially if their working space is not clean.
To have it refurbished might cost you double or 3 times of what an imported engine will cost you, and as I said, if you get an ass to refurbish it you will pay more and be worse off.
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
Thanks Piet, I think I will end up going the fong kong route and just use all my original accessories. I got a price of R10 900 from Mikes Place which seems very reasonable. I'm not sure if it is chinese or korean but I assume they all chinese nowadays. Going to start stripping next month and do a re-spray when I do the engine swap. Will start a thread when I begin and keep updated with pics
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
By the way my father in law built my canopy using your design on the forumn
I would say Fong Kong engine, but you're in CT, so then i would rather suggest that you take it to Hoppy for a proper repair. The reason I bought Fong Kong was because I did not trust the chaps here as well, although I did overhaul my 4Y as well just in case.
- LouisZ
A Complete Refurb will be about R8250
This is for;
1. Redo Head
2. Bore cylinders 1 size bigger
3. Pistons and rings oversize, connecting rods
4. Block skim
5. Complete gasket set(All gaskets and seals)
6. All bearings(big ends, small ends, main)
7. Crank cut
8. Oil
9. Anti freeze.
New Head,Block sump goes for R8950
This is for;
1. Redo Head
4. Block skim
7. Crank cut
8. Oil
9. Anti freeze.
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
@Family_Dog: Thanks, I have been reading only good things about Hoppy so I think I will send him a pm and see when he can have a look at it for me. I want to be able to overland with my vehicle with peace of mind that my engine is in top shape! I had it up for sale on the forum but have since removed it, there was interest but nothing really took off. I'm going to get the Hilux sorted and use it for what it was built for.
@Louis: Thanks Louis, That seems cheaper than me buying a fong kong and then all my consumables, seals etc ontop! I'm going to speak to Hoppy because if I can get my original 4Y overhauled and living up to their reliable reputation again I will be a happy man
- Wave
- Town: Edenvale
- Vehicle: Tuna 3.0 D4D 4x4
- Real Name: Geoff
I may be incorrect, but I saw a brand spanking new fong kong 4Y wrapped up in plastic, complete @ Turbo Toys in Boksburg for R8500.
Maybe give them a call and find out the final price
'10 Conqueror Comfort
- LouisZ
There are Fong Kongs and there are good quality ones. Just beware.
Josh is there other outstanding problems except the performance on the engine that stands out? i.e Does it still have problems with the Cooling?
If not keep the Engine as is. Don't open it if it is not necessary.
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
90 % of the time you don't have to replace con rods, skim block and cut crank.4x4megaworldpta wrote:A Complete Refurb will be about R8250
This is for;
1. Redo Head
4. Block scheme
7. Crank cut
8. Oil
9. Anti freeze.
unless you already have a big end knock, then you'll have to cut crank
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
@Geoff: Thanks I will keep that in mind!
@Louis: The only other problem is I'm getting white smoke from the exhaust upon startup and lasts about 15-20 minutes after, I've been thinking that this could just be condensation in the pipe maybe but it is also using coolant, which makes me think head gasket again. On downhills in gear with no accelerator input I'm getting minor missing/popping from the exhaust, which is more noticeable when the lux is loaded with more weight.
@Tarquin: Thanks Tarquin I will see what Hoppy says, but right now I'm very lost on what to do!
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
Oh and Louis, I'm getting white smoke as soon as I release the accelerator pedal, not while under power
- Agteros
- Vehicle: Toyota FJ Cruiser
- Real Name: Hugo
I think it is 99% sure its your headgasket - I had exactly, but exactly the same problem.Josh Edwards wrote:@Geoff: Thanks I will keep that in mind!
Here was mine at the time:
viewtopic.php?f=3&t=9510" onclick="window.open(this.href);return false;
2020 FJ Cruiser
- Josh Edwards
- Town: Durbanville
- Real Name: Josh
Thanks Hugo! Read the thread and will check all of this on the weekend!
- Vehicle: 1995 SFA
- Real Name: Jaco
Check your heater box for anti freeze residue. I lost coolant that way.
- Baasvark
- Town: Virginia
- Real Name: Shane
Had that problem too but then I changed my brand ....Josh Edwards wrote:Oh and Louis, I'm getting white smoke as soon as I release the accelerator pedal, not while under power
- LouisZ
I worked on worse case scenario. But I still will skim the block, yet I will polish the crank.
One way is to take off your tappet cover. If it is whitish inside you blown a head gasket.
