Some 2.7 IFS advise needed from the local Experts
Ultred
Town: Heidelberg
Vehicle: '00 Hilux 2.7i D/Cab IFS.
Real Name: Mike
Club VHF Licence: HC108
Post by Ultred »
Hi Guys,
At a speed above say 60km/h, when i accelerate there is a humming sound from under the vehicle, but as soon as i take my foot of the accelerator the humming stops, as soon as i accelerate its comes back again. What is running Dry?
If my truck stands at an angle over night or if it just stands for a while and cools off it struggles to start and smells very lean when it eventually does. But when the engine is warm, no prob. What can like to be the reason?
I MAY GET LOST, BUT NO WAY IN HELL WILL I GET STUCK
LouisZ
Re: Some 2.7 IFS advise needed from the local Experts
Post by LouisZ »
Your 1st problem could be the Rear diff that needs some oil or the other could be the crown wheel and pinion in the rear diff is worn.
Your engine problem could be sticky injectors or a partially blocked fuel filter, worse case fuel pump.
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
4x4megaworldpta wrote:Your 1st problem could be the Rear diff that needs some oil or the other could be the crown wheel and pinion in the rear diff is worn.
:thumbup: :thumbup:
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Post by Thunder02 »
It's because she stands too much, drop her off at my place and i'll solve that problem for you :tongue:
Scout motto:be prepared....
www.4x4direct.co.za
Post by Thabogrobler »
Neil,
Is all you horses back yet?
Post by pietpetoors »
for the stutter when starting also check this post
viewtopic.php?f=3&t=36787" onclick="window.open(this.href);return false;
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
Thanks Piet, ek loer gou.
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Post by Thunder02 »
Thabogrobler wrote:Neil,
Checked and cleaned Flow meter, little improvement, going in this week for the exhaust as i think one of the boxes are blocked. Fuel pump checked and all OK there.
Next will be spark plugs and timing checked.
There after a little chip installed.
The Italian Stallions should be back. :thumbup:
www.4x4direct.co.za
How did you test your fuel pump. My bakkie is also very pap at the moment.
