Engine swap in my Sj410
Asjas
Town: Secunda
Vehicle: Suzuki sj410
Real Name: Armandt
Tue Feb 09, 2016 6:01 pm
Hello all.
I have a suzuki sj410 running toyota diffs and box with a 4y moter.
What other engine can i install to gain a bit more power and speed. And also help on the feul usage?
Tue Feb 09, 2016 7:40 pm
2jz-gte :shh: :drool: :drool: :shock2: :shock2: :lmao: :lmao:
One can dream, can't we :lmao: :lmao:
Asjas
Town: Secunda
Real Name: Armandt
Sun Mar 13, 2016 10:18 pm
anyone got someones number whom can get me a bellhousing for the wl ford ranger moter to fit hilux gearbox
Sun Mar 13, 2016 11:43 pm
Try Gilo Engineering. :winkx:
Asjas
Town: Secunda
Real Name: Armandt
Wed Apr 13, 2016 12:19 am
Tnx will do. Might sell my 4y efi engine and computer box if I do the swap. If anyone is intrested.
Asjas
Town: Secunda
Real Name: Armandt
Thu Apr 14, 2016 6:23 pm
:twisted: Some change of plans. Just got a blown 3sgte engine running a huge t61 turbo for 3k by a friend. Will be using the 3s head on a 2.2 camry block and wil downgrade with a smaller turbo as I wont need 300kw in something as unstable as this little suzuki. Will keep you guys updated as soon as this takes of.
Only have 1 question thought. Will the 4y belhousing work with the 3s block?
Town: Bellville
Vehicle: Langpad (RAV4)
Thu Apr 14, 2016 7:29 pm
Asjas wrote::twisted: .... Will keep you guys updated as soon as this takes of. ...
as it would with 300kW .... :mocking: :tease:
probably wont last long, but dammm it will be an unforgetable period ... :lmao: :lmao:
jokes aside - what do you want to use it for ??
4x4 ? Low speeds and too much power = broken drive shafts .....
all that said - WOW !! lekker projek !!!!!!!!!!!!
alle vorspoed :thumbup:
Asjas
Town: Secunda
Real Name: Armandt
Fri Apr 15, 2016 11:18 pm
Haha nee nee hy het 300kw gemaak op 1.5 bar boost. Soos ek gese het kom dai moerse turbo af en n kliener oorspronklike een kom op. Max krag wat hy gan maak is 150kw en so 350nm. Ek ry nou en dan n baan of 2 met hom. Maar word meer as n daaglikse ryding gebruik en ek ry soms lang pad ook met hom.
Die turbo is vir die modder en dai 33" wiele.
Ek dink tog julle 3uz vvti moters en swaar bakies sit baie meer strain op die shafts en ratkas as my 800kg suzuki.
Lol kom ons kyk wat gebeur.
Asjas
Town: Secunda
Real Name: Armandt
Fri Apr 15, 2016 11:21 pm
And the 2c belhousing fits straight to the moter
Asjas
Town: Secunda
Real Name: Armandt
Fri Apr 15, 2016 11:25 pm
Would have liked to go with a lexus power plant as you can never have enough of it haha. Maar nou ja jy kan nie n 20duim rim in n 13 duim tire pas nie... as ek net plek gehaat het
Town: Bellville
Sat Apr 16, 2016 7:20 am
not what you are going for .. but just for information.
With the Jimny's the guys remove the 1300cc motor. Then fit 1600 or 1800cc Suzuki motors from Suzuki cars. Fits straight on the gearbox and sounds like it is almost a straight swop.
more than enough power for that suspension .... and extreme reliability
I have no idea if these would fit an SJ gearbox ....
Asjas
Town: Secunda
Real Name: Armandt
Sat May 19, 2018 1:36 am
Been a long time.....
Well long story short 4y removed.
Then mazda 2.0 16v fitted. Removed again...
And boom 2ct fitted :dance1:
And drowned again :siffler:
Rebuild and back in my sj..m
Also sy has ween turned into long arm coil suspe tion setup and also currently busy on body work.
