recovery points ?
- Ge23ev
- Town: Tehran
- Vehicle: Toyota Hilux
- Real Name: Shayan Givehchian
recovery points ?
Hey guys
i'm thinking about adding some recovery point to my vigo since there isn't any factory installed on the rear.
i have the original factory rear bumper.
i was thinking about a bracket with tow hitch or maybe just a recovery point for on the chassis to hook the shackles to.
any tips or info would be great on what will work best or even what i should do without changing the way it is since im kinda new to this thing and maybe i just couldnt find the tow points on the rear
thanks alot
thanks alot
- Parabat
- Town: Colchester
- Vehicle: Hilux 2.5 HL2
- Real Name: Ruari
Re: recovery points ?
To be honest, the front eyes are not actually rated recovery points, have a look at ARB front recovery points for the front. Would a beefy towbar not work for the back? You might want to see if anyone can fabricate rear recovery points if you don't want to use a towbar.
- Ge23ev
- Town: Tehran
Parabat wrote:To be honest, the front eyes are not actually rated recovery points, have a look at ARB front recovery points for the front. Would a beefy towbar not work for the back? You might want to see if anyone can fabricate rear recovery points if you don't want to use a towbar.
what do you think about something like this ?
The concept is good.
TWO things to watch:
- use the correct bolts !!
- have a good look if the rope/strap will clear the bumper ....
- Ge23ev
- Town: Tehran
ChrisF wrote:The concept is good.
Im kinda worried about the strap or shackles getting out of the hook in tension.
Nah, that won't just happen - tension will pull it into the hook. A lot of guys use those hooks. Personally I prefer a shackle - it's a bit more tedious to hook up but the ratings are nomally better than an open ended hook. The other thing I think about is that spring clip .... it'll get rusty over time, not a safety issue at all (unless it rusts off completely) but will just look crappy.
- Parabat
- Town: Colchester
- Real Name: Ruari
Looks OK, seems to have a load bearing rating stamped on it, just check that it's rated to the weight of your vehicle. Remember as well, always try to have two recovery points rather than one on the vehicle being recovered.Ge23ev wrote:Parabat wrote:To be honest, the front eyes are not actually rated recovery points, have a look at ARB front recovery points for the front. Would a beefy towbar not work for the back? You might want to see if anyone can fabricate rear recovery points if you don't want to use a towbar.
Shackles - make sure that they are similarly rated for recovery.
I'm going to be getting the ARB recovery points in the future -
- Town: London
- Vehicle: Hilux Vigo
- Real Name: Naas
I bought mine from APB trading. Good service received from them.Parabat wrote:Looks OK, seems to have a load bearing rating stamped on it, just check that it's rated to the weight of your vehicle. Remember as well, always try to have two recovery points rather than one on the vehicle being recovered.Ge23ev wrote:Parabat wrote:To be honest, the front eyes are not actually rated recovery points, have a look at ARB front recovery points for the front. Would a beefy towbar not work for the back? You might want to see if anyone can fabricate rear recovery points if you don't want to use a towbar.
- Choppies
- Town: Randburg
- Vehicle: Toyota Hilux 3.0l D4D 4x4 A/T D/C P/U, 50mm Leveling Kit, Custom bash plate, Custom rock sliders, Custom Front off road bumper, Canvas canopy.
- Real Name: Jacques
- Club VHF Licence: HC323
HiParabat wrote: ↑Fri Jun 10, 2016 4:16 pmLooks OK, seems to have a load bearing rating stamped on it, just check that it's rated to the weight of your vehicle. Remember as well, always try to have two recovery points rather than one on the vehicle being recovered.Ge23ev wrote:Parabat wrote:To be honest, the front eyes are not actually rated recovery points, have a look at ARB front recovery points for the front. Would a beefy towbar not work for the back? You might want to see if anyone can fabricate rear recovery points if you don't want to use a towbar.
Does anyone know where in SA I can purchase recovery points like these? Or any other decent recovery point?
2012 Toyota Hilux 3.0L D4D D/C 4x4 Auto
2014 Kia Rio TEC (SWAMBO's Platkar)
Veni Vidi Vici
- pieta.swanepoel
- Real Name: Pieta
Jacques, sien Ironman het. Maar dit is vir Revo. Dalk pas dit op Vigo
http://www.ironman4x4.co.za/accessories ... s/?pid=192
Hi all, are there any recommendations of someone in Joburg that can fit rear and front recovery points for my D4D?
Try 4x4Direct in Boksburg.
