Can someone please tell me how to shorten diff ratios on hixux 2.7 3rz 1999 model i want to fit 35 12.5 15?
Sent from my SM-G935F using Tapatalk
Diff ratios
- tuff tralies
- Town: Heidelberg
- Vehicle: hilux
- Real Name: christoffel
- Town: Calvinia
- Vehicle: 3.0L KZ-TE 4x2
- Real Name: HJ
Re: Diff ratios
Ek wil ook weet
- GRWLR ZN
- Town: Richards Bay
- Vehicle: Toyota Hilux - Lexus V8
Re: Diff ratios
By 'shorten' I assume you mean go to a higher ratio?
I am not hundred percent sure on what the ratio would be in the 2.7, if I would have to guess, it'd be around 4.1:1 to 4.3:1?
With wheels and tyres that big you should go for something like 4.8:1.
If your rear axle on there is the local type, you're in luck. You'll be able to get a kit to just change the crown wheel and pinion, if its the import type, then no luck. Will have to change out complete axle.
- tuff tralies
- Town: Heidelberg
- Vehicle: hilux
Re: Diff ratios
Thanx a lot wil have a look at it
