Anyone replaced Toyota Tazz tie-rods and tie-rod ends ?
KZTE Nut
Town: Johannesburg
Vehicle: Hilux KZTE DC 4x2
Real Name: Mervyn
Post by KZTE Nut »
I need to replace the tie rods and inner tie-rod ends on a Toyota Tazz. Anyone done this and give some advice or can recommend a mechanic in the Jhb or Eastern suburbs area ? I would do it myself but it looks like you need a special tool to loosen and tighten the inner tie-rod end :frustrated:
Rigger
Town: George
Real Name: Martiens
Re: Anyone replaced Toyota Tazz tie-rods and tie-rod ends ?
Post by Rigger »
If you are mechanically challenged then better take it to a mechanic. Otherwise, no special tool required. Good old pipe wrench (bobbejaanspanner) and you are good to go. Thery are usually very tight and you should tighten them again very tight with some thread locker. And then mark the old tie rod ends before taking them off so that when you reassemble the tow in is not too far off so that you can drive to a service centre who can adjust the wheel alignment for you. Good luck
Dingo
Vehicle: 95 4x4 DC Hilux, 7MG engine, EFS suspension, Home made custom off-road canopy.
Real Name: Scott
Post by Dingo »
You can buy the parts loose from Midas / Toyota / etc and take them with to the alignment shop, ask them to replace and do alignment all in one go.
KZTE Nut
Town: Johannesburg
Real Name: Mervyn
Post by KZTE Nut »
Thanks chaps !
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
Dingo wrote: Tue May 09, 2017 7:09 am You can buy the parts loose from Midas / Toyota / etc and take them with to the alignment shop, ask them to replace and do alignment all in one go.
+1
Most alignment places do it these days....even control arm bushes are press fitted right there & then
Return to “Open Discussion”
