electrical problem
pieter2011
Town: vereeniging
Vehicle: 2011 Toyota hilux dc sex 4x4
Real Name: pieter
electrical problem
Post by pieter2011 »
Good day
I have a 2011 Toyota hilux dc srx. I had a problem with my breaklights not working so I changed the fuse and checked the rest and replaced all the fuses now my power windows and tailights and a.c. does not work. any idees
Re: electrical problem
Post by Family_Dog »
Pieter, welcome to the forum. It would seem that one opf the new fuses is no longer working or making proper contact. Best is to check this fuse with a digital multimeter set to the 'ohms' or even 'diode' scale, it should of course read a dead short.
I had the same issue with a gate motor, the blade fuse looked ok but it didn't work. Replacing it did the job.
The brake lights could just be a bad earth or bad connection at the lamps themselves. The rest only happened when you disturbed the fuses, so almost certainly a fuse is now blown or more likely not making proper contact either on the fuse itself or on the fuse box wiring.
