Adjustable side mirror
Michael J D
Town: windhoek
Vehicle: Hilux DC 4x4 3.0L
Real Name: Michael
Mon Feb 05, 2018 8:03 am
Thanks admin for accept. Hi all. The RH side mirror of my vehicle adjusts inwards & outwards when I push the button.However it does not adjust upwards & downwards . The LH side mirror works perfectly through both dimensions.So the problem is not with the switch. Agents only want to replace the side mirror at cost of around R2500 ex vat & labour. Has anyone experienced this issue before and is there a way to solve it without replacing the entire unit? Looking forward to reply.Rgds Mike
Rebel 4x4
Town: Port Elizabeth
Vehicle: 2014 Suzuki Jimny Fully kitted with every extra you can imagine that is available for a Jimny
Real Name: Thomas
Mon Feb 05, 2018 10:02 am
Open it up and check for loose wires or something. Maybe it is pinched somewhere.
Sent from my iPhone
Rigger
Town: Oudtshoorn
Real Name: Martiens
Mon Feb 05, 2018 10:25 am
Mine does the same. However if I hold it in for about 5 seconds or so then it starts to move. Both my mirrors does it. I have removed the switch and cleaned the connections. But didn’t change anything. I just live with it as I am driving the bakkie 99% of the time so no adjusting necessary.
Mon Feb 05, 2018 1:12 pm
The problem is not with the switch if it operates the LHS mirror OK. More than likely the problem will be either the vertical plane motor itself or the connections to that motor (inside the mirror). Could also be as suggested that the wires have become pinched where they pass from the body to the door.
Michael J D
Town: windhoek
Real Name: Michael
Mon Feb 05, 2018 5:47 pm
Thanks for advice. It seems I will have to strip the mirror??
    Users browsing this forum: Google Adsense [Bot]
