Land Cruiser 1989
Posted: Fri May 14, 2010 9:46 pm
by farazharoon
Hello I have been given the job of maintaining a Land Cruiser 1989 model with a diesel 2H engine.
It has a manual transmission. Anybody know how I can find out what kind of transmission/gearbox I have, I mean the name of it, like is it a W or F etc. I want to look up the ratios on it. Anybody have idea about part number of transmission/gearbox number for this model?
Re: Land Cruiser 1989
Posted: Fri May 14, 2010 11:23 pm
by Maniac
Take your VIN number and go to
http://www.toyodiy.com" onclick="window.open(this.href);return false;. Type in the vin number and you will get all the info you need.
Manual download at
http://the-manuals.com/hj60-manual/" onclick="window.open(this.href);return false;
The 2H is a 4.0 L (3980 cc) inline 6, 12 valve OHV diesel engine. Bore is 91 mm and stroke is 102 mm, with a compression ratio of 20.7:1. Output is 103 hp (77 kW) at 3500 rpm - later production years 107 hp (80 kW) with 177 ft·lbf (240 N·m) of torque at 2000 rpm.
Applications
* Toyota Land Cruiser HJ47, HJ60
HJ 47 stopped production in 1980, so you must have a HJ60?
Model HJ60
Production years 1980-1990
Engine 2H
Cylinders 6 in line
Fuel diesel
Volume (cm3) 3980
Bore (mm) 91.0
Stroke (mm) 102.0
Power (kW (bhp)) 76 (102)
Torque, max. (Nm @ rpm) 241 @ 18003
Gear box H55F 5 speed
Gear I. 4.84
Gear II. 2.62
Gear III. 1.52
Gear IV. 1.00
Gear V. 0.845
Transfer H 1.000
Transfer L 1.96
Axle 3.70
Max. reduction I/L 35.1006
Posted: Sat May 15, 2010 9:17 pm
by farazharoon
Thanks so much for your help.
Where did you get the gear ratios from? Is that from toyodiy as well?
I want to compare the gear ratios of the land cruiser and 2005 vigo.
Posted: Sat May 15, 2010 9:29 pm
by Maniac
Google led me to
http://www.ulich.org/~thu/LC/HJ61/J6.html" onclick="window.open(this.href);return false;
For Vigo go to
http://www.4x4.ie/4x4/vigo_specification.htm" onclick="window.open(this.href);return false;
Posted: Sun May 16, 2010 6:47 pm
by farazharoon
You are a complete star man!
I've been googling this stuff but can't seem to find it especially for the Land Cruiser.
Do you think I can get this kind of information for newer Toyota too like the Toyota Surf 2004 model? Do I need the frame number of the Surf?
How about Toyota Prado (90 series) 2001 model.
THANK YOU SO MUCH FOR THIS INFORMATION!!!! So helpful!
Faraz
Posted: Sun May 16, 2010 11:41 pm
by Maniac
2004 Surf =
http://www.new-cars.com/2004/toyota/toy ... powertrain" onclick="window.open(this.href);return false;
all surfs=
http://www.4x4wire.com/toyota/faq/parts/" onclick="window.open(this.href);return false;
Prado = Seems more difficult ... will continue search tommorow
BTW Google for 2004 toyota Surf spec.....thats how I found it
Posted: Mon Aug 17, 2015 7:17 am
by farazharoon
Thank you for your help. Much appreciated
Posted: Sun Jun 05, 2016 8:36 pm
by Misha_9998
I also was wondering) tnx)
