How to reset D4D t-belt light
- AM Racing
- Real Name: Dylan
Ignition off press odo button
Hold odo switch ignition on for 5 seconds
Switch ignition off release odo
Press odo, switch ignition on and continue holding until light goes off
Switch off and check by starting vehicle. The light should be off....
- frik
- Town: Boksburg
- Vehicle: KZTE 3.0 4x4
- Real Name: Frik van Dyk
Re: How to reset D4D t-belt light
It just cost me R6000 to reset mine at Toyota after a new timing belt. :x
Don't ignore the timing belt warning .... it's there for good reason! Changing the belt timeously can save you big bucks. The dealers of course are smoking something strange as usual with those over inflated prices, so the trick to reset the light is a good one, but only reset it after you've had someone replace the belt or you've done it yourself.
- AM Racing
- Real Name: Dylan
Thats correct. Do the belt! If the guys want I can post a how to on the belt. You can do it yourself for under R600!!!
That wouldn't be a bad idea, Dylan. There's a lot of the guys that are quite mechanically capable, who would tackle it themselves if they just new how to go about it. Go for it!
- Town: Midrand
- Real Name: Nishan
i tried this and it didnt work
maybe i'm doing something wrong
This is what i did
Ignition off press and hold trip meter reset button
While holding trip meter reset, switch ignition on (to where all dashboard lights come one, but dont start bakkie) for 5 seconds
Switch ignition completely off (to the point where you can remove the key) release trip meter reset
Press trip meter reset, switch ignition on (to where all dashboard lights come one, but dont start bakkie) and continue holding
(All the usual dashboard lights are on at this point and non go off)
This is what i did
Real drivers use three pedals
- Dodging
- Town: Boksburg
- Vehicle: Golof
- Real Name: Andre
Anybody know how to do this on an IFS?
I'm changing the belt next weekend
Nothing is impossible - it just costs more
- AM Racing
- Real Name: Dylan
Hold it even longer then but it will resetDie$eL wrote:i tried this and it didnt work
This is what i did
- AM Racing
- Real Name: Dylan
This one involves the removing of the instrument cluster or partially. There is a small wire held on with a screw next to 2 other holes. Loosen the wire and move it , if I recall to the hole at the end. Switch the ignition on (cluster connected) and start the vehicle it should go off. If not then move it to the hole next door.....Dodging wrote:Anybody know how to do this on an IFS?
NOTE: If the light is not on you cannot reset it. It must come on first!
- Town: Kyalami
- Real Name: Mike
Thanks for this, going to try it, I had my cambelt replaced 10000 km ago, they reset the light but last wekeend I removed my speedo cluster and not long after that it came on again, I suspect its due to being disconnected.
I will give it a shot and see if i can reset myself
- Town: Midrand
- Real Name: Nishan
i still cant get it to work.
i held the button for like 3 minutes with no success.
can anyone help? i'll come to you. hate having extra lights on for no reason.
- Town: Kyalami
- Real Name: Mike
I also tried, no luck.
- Town: Kyalami
- Real Name: Mike
I GOT IT!!!!
Tried again this morning and by luck I cracked it
Dylan, your procedure isnt entirely right
Make sure your ODO is displaying and not trip meter A or B
Press reset button with Ignition off and hold it
Turn on ignition and start the engine while still holding button in, hold for at least 5 seconds and release,
DO NOT TURN IGNITION OFF
Press reset button again and a "1" should appear on the screen
If you press again a 2 will appear
I left mine on 2 as I assume this is for the second timing belt
Then press and hold the button in until the light goes off
VOILA!!!
VOILA!!!
- Town: Midrand
- Real Name: Nishan
this is great news
will try this evening and feedback
how the heck did u figure this out?
- Town: Kyalami
- Real Name: Mike
I just based it on Dylans instructions and figured it should be somethign similar, tried till I saw the "1" appear :-)
- Town: Kyalami
- Real Name: Mike
Shout if you have issues you in Midrand, not far from me
- Town: Midrand
- Real Name: Nishan
thanks for the offer. will do.
in that case, i think the tools we'd need = 6 beers....
- Town: Kyalami
- Real Name: Mike
You should Manage though
- Town: Midrand
- Real Name: Nishan
WOOOOOOOooo HOOOOOOoooooooooo!
It wekked!!!!
U truly are wise Mikie!
It wekked!!!!
- Town: Kyalami
- Real Name: Mike
Awesome!!! Now I am just not sure if selecting 2 was correct
- Town: Midrand
- Real Name: Nishan
well the light went off. lol
it makes sense if you think about how the old ones were done.
there were 2 holes on the back of the dash cluster and you had to swop a screw to the second hole (i'm thinking thereby closing the second circuit)
so with this, its kinda switching to the second circuit without removing the cluster.
- Town: Kyalami
- Real Name: Mike
Lol I hope so, Just remember that at 300 000 km you need to change it again it it doesnt come one, if the next replacement is at the mileage :)
- AM Racing
- Real Name: Dylan
Interesting. I never had a 1 or any other number show when I pressed the button. But glad you got it
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
thanks mike you system works perfectly
- Town: Kyalami
- Real Name: Mike
Tarquin wrote:thanks mike you system works perfectly
Excellent
- Town: Kathu
- Vehicle: Toyota Hilux 3.0 d4 4x4 D/C
- Real Name: Kolie
I changed the belt on my Hilux at 150123km about a year ago,today on our way home at 160123km the T belt light come on again ,can anyone tells me what is going on?
- Real Name: Marnus
Daardie waarskuwing is gekoppel aan die ODO. Het jy hom self reset of Toyota?
