Rock Sliders
- Fred79
- Town: Kent UK
- Vehicle: Toyota Hilux Icon 2.4
- Real Name: Frikkie
Rock Sliders
Het vandag my 'n stel rock sliders gekry vir goedkoper as wat ek die staal kon koop om my eie stel te bou. Die probleem is net dat dit is gebou vir 'n Defender 110 so ek sal die mounting brackets moet verander.
Enige ideas?
Enige ideas?
- 110--rock-tree-sliders-1.jpg (36.55 KiB) Viewed 5328 times
Re: Rock Sliders
Best is to mount on x2 places onto the chassis.
See here: viewtopic.php?f=94&t=9455&hilit=d4d+rock+sliders" onclick="window.open(this.href);return false;
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Re: Rock Sliders
Or even three places.Makes the strain on the chassis less
Re: Rock Sliders
I know Cobus puts on 3 brackets for the Vigo rock sliders, for the other Hiluxes he only put two
- Fred79
- Town: Kent UK
Re: Rock Sliders
Thanks, ek sal nou sien wat hier gaan uitkom, het 2003 op die plaas laas met 'n welder gewerk.
6mm flat bar sal seker die ding doen?
Re: Rock Sliders
10mm!!!!Fred79 wrote:Thanks, ek sal nou sien wat hier gaan uitkom, het 2003 op die plaas laas met 'n welder gewerk.
- Town: Springs
Re: Rock Sliders
Frikkie,onthou as daai brackets buig is jou body taboo.
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
Re: Rock Sliders
Pieter, jammer om die thread te hijack - waar kan ek vir Cobus in die hande kry? My trappies is uiteindelik gebuig, so ek het nou rede om dit met iets ordentliks te vervang.pietpetoors wrote:I know Cobus puts on 3 brackets for the Vigo rock sliders, for the other Hiluxes he only put two
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Re: Rock Sliders
- oxydog
- Real Name: Jarus
Re: Rock Sliders
Dankie!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Fred79
- Town: Kent UK
Re: Rock Sliders
At last is die rock sliders is af gelewer, maar nou moet hulle maar eers lê en wag vi my want my tassie is gepak vi SA
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
Rock Sliders
Het myne op 3 plekke gesit met 10 mm kan my hele hilux se gewig dra met n checker plate bo
I am here: http://maps.google.com/maps?ll=-26.012889,28.026034" onclick="window.open(this.href);return false;
Re: Rock Sliders
Fred, waar oorals in RSA sal jy wees?
- louis fourie
- Club VHF Licence: X101
Re: Rock Sliders
TheoTheodorus wrote:Het myne op 3 plekke gesit met 10 mm kan my hele hilux se gewig dra met n checker plate bo
Watter dikte boute het jy gebruik?
- Town: Randburg
- Vehicle: Fortuner
- Real Name: Brian
Re: Rock Sliders
You can also try Nico P. he makes a mean set of sliders.
- Gysie
- Events Coordinator
- Vehicle: Toyota
- Real Name: Ciske van Gijsen
Re: Rock Sliders
Try and use 12mm bolts - fine tread HT bolts and we use 10mm x 50 flat bar
Life does not consist of the cards you are dealt but in how you play the cards you are dealt!
http://www.gomad4x4.co.za
Re: Rock Sliders
Don't you guys think that 10mm is way overkill? If something were to have to give, I would prefer it to be the slider before the chassis gets kinked. A deformed chassis is very much weaker ans poses a real poblem. It's easier to replace sliders and do any necessary body repair than to strip and repair a chassis.
I had 5mm mounting plates that were 100mm wide, each secured with 4 x 10mm bolts and it sttod up to a lot of abuse ... the tubing bent before the mounting plates. Obviously if one uses only a 50mm wide flat bar, the 5mm gauge would be too thin for rigidity, but 50mm is too narrow IMO ...... a wider plate spreads the stress on the chassis rail over a larger area which is less likely to kink or deform it. It would also allow the bolts to be torqued further.
- louis fourie
Re: Rock Sliders
AndyMud Dog wrote:Don't you guys think that 10mm is way overkill? If something were to have to give, I would prefer it to be the slider before the chassis gets kinked. A deformed chassis is very much weaker ans poses a real poblem. It's easier to replace sliders and do any necessary body repair than to strip and repair a chassis.
My opinion:
When off-roading you will either have to drive very fast, or for some reason fall hard on your slider to twist the chasis. I would rather have my sliders strong not to break and damage my body than to worry about the chasis where the changes are very slim that you will get a "twisting". The mounting points must be as close as possible to the cross member/supports on your chasis which make the whole setup even stronger .
- Fred79
- Town: Kent UK
Re: Rock Sliders
Skuus oom Andy vir die stadige reply, nie altyd by die internet nie. Ek is maar meestal tussen Malmesbury, Wellington en Worcester.Mud Dog wrote:Fred, waar oorals in RSA sal jy wees?
- Theodorus
- Vehicle: HILUX
- Real Name: Theo
Rock Sliders
17 spanner
- Fred79
- Town: Kent UK
Re: Rock Sliders
Ek het toe maar 'n ingeneers besigheid gevra om vir my die brackets vir die rock sliders te bou, hulle het my nou gebel en gesê die die rock sliders sal dalk verhoed dat die side airbags kan af gaan en ek kan in groot moeilikhied beland sou ek in 'n ongeluk betrokke wees en eiemand in die voertuig kry seer.
Dink julle dit is waar? Hulle staan mos nie 2m uit al elke kan nie, die ander voertuig sal moes nogsteeds kontak maak as ek in 'n kant botsing betrokke is.
Kan ek vra dat iemand asseblief vir my 'n paar close up foto's stuur van die brackets en waar hulle mount gemount wees, die manne verstaan nie so lekker hier by ons nie.
- Fred79
- Town: Kent UK
Re: Rock Sliders
Eerder laat as nooit nie, het omtrent lank gewag vir hulle.
Baie sterk en baie tevrede!
- Blackadder
- Real Name: Thinus
- Club VHF Licence: X82
Re: Rock Sliders
Dit lyk bakgat...
Sent from my GT-I9100 using Tapatalk
- Town: Swartklip
- Vehicle: Toyota Hilux 2.5 D4D 4x4
- Real Name: Jan-Stefaans
Re: Rock Sliders
Frikkie,
Kan jy dalk fotos post van hoe die rocksliders vas gesit is op die bakkie. Indien moontlik
- Fred79
- Town: Kent UK
Re: Rock Sliders
Ek sal so maak vi jou.Jansie wrote:Frikkie,
- Fred79
- Town: Kent UK
Re: Rock Sliders
Hoop dit help. Het vir die 3 bracket opsie gegaan.Jansie wrote:Frikkie,
