Saddle correction a la Stef
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
Decided it is high time to add my extra blades in the front and do the saddle (pedestal for Andy ) correction at the same time.
Contemplating the 30mm axle move while I have the diff out
Diff almost out... diff out:
Note on the saddles; try hitting it from the inside out with a ball pin hammer and a 4 pounder before panelbeating from the top; saves a lot of time.
Used a 2nd cut file to mark/smooth out the high spots after the beating: one pack (back one in pic) washed & re-assembled with the 6th blade in position #3:
More to follow
More to follow
- LouisZ
Re: Saddle correction a la Stef
Daarsy, dis hoe mens dit doen. Co2 weld net die versterkings in.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Weet iemand dalk waar ek dit kan laat doen? Gaan nie weer na die naaste exhaust plek toe nie...daai ouens weet boggerol van sweis af4x4megaworldpta wrote:Co2 weld net die versterkings in.
...of as iemand een wil uithuur vir 'n paar koues...
- Club VHF Licence: X93-
Baie mooi gedoen Stef
.... this is actually the correct term. A saddle is normally something that bolts down over the top of something like a tube to hold it in place.Stef wrote:Decided it is high time to add my extra blades in the front and do the saddle (pedestal for Andy ) correction at the same time.
.... and ja, do the axle move while you're about it.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
I know about saddles...qualified sparky (before I went the light current route)
Guess it depends on one's point of view...the pedestal is over the diff...and holding it down (with some help from the leafs) therefor it must be a saddle Oh, it is bolted down as well
- LouisZ
The Auzzies use the term Saddle in their Ome cataloque. You know their different
According to the world English dictionary, saddle seems the more correct optionMud Dog wrote:.... this is actually the correct term. A saddle is normally something that bolts down over the top of something like a tube to hold it in place.Stef wrote:Decided it is high time to add my extra blades in the front and do the saddle (pedestal for Andy ) correction at the same time.
World English Dictionary
saddle (ˈsæd ə l) [Click for IPA pronunciation guide]
— n
1. a seat for a rider, usually made of leather, placed on a horse's back and secured with a girth under the belly
2. a similar seat on a bicycle, tractor, etc, made of leather or steel
3. a back pad forming part of the harness of a packhorse
4. anything that resembles a saddle in shape, position,or function
5. a cut of meat, esp mutton, consisting of part of the backbone and both loins
6. the part of a horse or similar animal on which a saddle is placed
7. the part of the back of a domestic chicken that is nearest to the tail
8. civil engineering a block on top of one of the towers of a suspension bridge that acts as a bearing surface over which the cables or chains pass
9. engineering the carriage that slides on the bed of a lathe and supports the slide rest, tool post, or turret
10. the nontechnical name for clitellum
11. another name for col
12. a raised piece of wood or metal for covering a doorsill
13. in the saddle in a position of control
pedestal (ˈpɛdɪst ə l) [Click for IPA pronunciation guide]
— n
1. a base that supports a column, statue, etc, as used in classical architecture
2. a position of eminence or supposed superiority (esp in the phrases place, put, or set on a pedestal )
3. a. either of a pair of sets of drawers used as supports for a writing surface
b. ( as modifier ): a pedestal desk
Always know it to be referred to as the spring pedestals, even spring perches ... but I'm slowly getting used to the saddle term. Wonder what reference is made in the Haynes manual.
Will check tonight what it says in my Gregory's manual.Mud Dog wrote:Always know it to be referred to as the spring pedestals, even spring perches ... but I'm slowly getting used to the saddle term. Wonder what reference is made in the Haynes manual.
Maybe it's called a saddle due to.... (a picture is worth a thousand words) Sorry ek het jou topic ge-hijack Stef
- Town: Cullinan
- Vehicle: Ford :Toyota
- Real Name: Barry
- Club VHF Licence: HC237
Hi Stef
Het jy toe reg gekom met daai tressels?
Wat ek is is net genade
Wat ek het is net geleen
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Barry, ja ek het, baie dankie Ek het teen die naweek eers besef ek het nie jou sel nommer nie
Marius was so gaaf om syne vir my te leen; ons het gedink dit gaan te klein wees, maar is toe heel voldoende. Seker nie nodig om die bumper tot teen die dak te lig nie
Die 2 ton jack werk ook heel goed, lig die bakkie net hoog genoeg; met die tressles op daai hoogte sak die diff mooi van die vere af met die jack onder hom. Nog genoeg spasie om die diff op jack uit te sleep
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Het die versterkings in...40 x 4.5 mm flat bar; alles vas "ge-tag" met die inverter. Versoeking was te groot, toe weld ek maar een van die versterkings heeltemal in.4x4megaworldpta wrote:Daarsy, dis hoe mens dit doen. Co2 weld net die versterkings in.
Moet dit CO2 wees? Ek dink gewone arc welds sal voldoende wees; hou net die versterkings in plek; dra nie fisies die gewig nie
- Gunta
- Real Name: Mark
Stef an easier option would have been to buy new saddles and replace them.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Who sells them?
I believe that a properly penetrating arc weld will do the trick here. I think the biggest hassle you might have is oxidisation in the weld (no gas blanket). Perhaps some rust inhibitor or cold galvanising on the 'heat' areas before painting.
- Gunta
- Real Name: Mark
Speak to Ronald.Stef wrote:Who sells them?
TAC 4x4 Traction
PO Box 2884
56 Platinum Street
Ladine
Polokwane
0700
Cell: 082 376 5378
Tel: (015) 293-0736
Fax: 086 664 9201
E-Mail: t.a.c@mweb.co.za
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
My thoughts as well so that's what I did; Inverter set at 90A with a 2mm rod. I little high for 2mm but wanted proper pentration on the thik plates.Mud Dog wrote:I believe that a properly penetrating arc weld will do the trick here. I think the biggest hassle you might have is oxidisation in the weld (no gas blanket). Perhaps some rust inhibitor or cold galvanising on the 'heat' areas before painting.
Gave the diff a once over with the grinder & wire brush last night. Today I'm cleaning up the hard to reach places before giving it some reddish (PA10 or the like) primer with a black QD enamel for a second coat.
- Gunta
- Real Name: Mark
Stef I see your bird s%^t actually runs flat.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Gunta wrote:Stef I see your bird s%^t actually runs flat.
Straight stripes, enough to embarrass most pigeons Stronger s%^t than that you won't find
- Gunta
- Real Name: Mark
Wait for the Hadeda bomb
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Not sure what they eat...al I know is it can't be foodGunta wrote:Wait for the Hadeda bomb
- Gunta
- Real Name: Mark
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Couldn't wait for Saturday morning...just under 2 hours & the diff was back in; 30mm axle move also done
MASSIVE improvement
Driver side = 40mm up; total 805mm bottom of rim to wheel arch
Passenger side = 30mm up; total 830mm
Noticed a 15mm difference between rear L/R; trim packer in the rear R ought to sort it out
MASSIVE improvement
- LouisZ
Let it settle before you trim, i.e drive it for about 10km.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Tx Louis; been meaning to contact you....I reckon a 10mm trim in the rear right will sort the front as well, but will drive it first, just need to get longer brake lines first due to axle move.4x4megaworldpta wrote:Let it settle before you trim, i.e drive it for about 10km.
What sizes are trim packers available in?
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Finally got the extended brake line for the passenger side (supplier ran out of teflon hose)...bled the brakes and took it for a spin. Steering etc seems to be fine after the diff move.
Took some measurements afterwards; now have 30mm difference between left & right sides both in the front & rear; guess I'll drive it a bit more (only did 4km's last night) & see where they sit then Maybe I ought to rip out the rear leafs & service them as well?
