What diesel engine to use?
Posted: Wed Mar 07, 2012 7:00 pm
by jacques kotze
Hi all!
A friend of mine just bought a 98 SFA D/Cab 4x4 with a 2,2 Petrol engine(not the original) He wants to change it to a Diesel mainly for fuel consumption. He is not worried about power.He is thinking of a 2.8D or a KZ, but I know both of them has they're drawbacks. I told him to keep the 2.2 but I'm not sure what the fuel consumption is on them. So the question is, should he keep the 2.2 , if so, what can he expect to get on liter of fuel, If he should go for Diesel, witch will be the better engine?
Thanks.
Re: What diesel engine to use?
Posted: Wed Mar 07, 2012 7:14 pm
by Kaspaas
Jacques, my 2.8D het my tussen 6.2 en 7.4km/l gegee. Hy is net so swaar op brandstof soos n 4Y, maar met baie minder krag, en furstreerende lae spoed.
Beste ombouing vir 'n Toyota diesel interme van brandstof verbruik is 'n 3CT of indien hy nie omgee om 'n Frod enjin in te sit nie, 'n 2.5DT (mazda) Hoppy het al baie van hulle ingesit met groot sukses.
Posted: Wed Mar 07, 2012 8:09 pm
by jacques kotze
Dankie Kaspaas, wat sal die brandstof omtrent wees op die 3ct(watse enjin is die?) en die Ford?
Posted: Thu Mar 08, 2012 12:06 am
by zepplin
The 3CT is a 2,0 diesel turbo Toyota motor - imported here.
A friend has the 2.5DT Mazda in a 2x4 & gets around 7.5Km/l driving like Miss Daisy so they not that light on juice.
Posted: Thu Mar 08, 2012 7:29 am
by jacques kotze
zepplin wrote:The 3CT is a 2,0 diesel turbo Toyota motor - imported here.
Thanks Steve,
Don't think the Ford/Mazda will do the trick. Anyone has any idea of the consumption of the 3CT?
Posted: Thu Mar 08, 2012 10:29 am
by Kaspaas
zepplin wrote:The 3CT is a 2,0 diesel turboToyota motor - imported here.
Zeppi, I think its a 2.2 Turbo.
Jacques there are guys on the forum who get well over 10km/l with a 3CT.
You can scroll through die "Consumption of your Hilux" topic. I know there is one or two 3CT stat's in there.
Posted: Thu Mar 08, 2012 10:53 am
by jacques kotze
[/quote]
Dankie Kaspaas, sal gaan krap.
Posted: Thu Mar 08, 2012 11:15 am
by oom dan
hello jacques, the way I understood it was the 2CT is a 2litre and there are plenty available from R3750 up. the 3CT is a 2.2 litre which we were interested in but could not find one anywhere and the price if available would be R14000. the good thing with these engines is no electronic issues and bell housings are interchangeable with 22R not sure about 4Y. have decided to stick with 22R
Posted: Thu Mar 08, 2012 11:18 am
by jacques kotze
Thanks oom Dan!
Posted: Thu Mar 08, 2012 11:51 am
by Kaspaas
oom dan wrote:hello jacques, the way I understood it was the 2CT is a 2litre and there are plenty available from R3750 up. the 3CT is a 3 litre whichwe were interested in but could not find one anywhere and the price if available would be R14000. the good thing with these engines is no electronic issues and bell housings are interchangeable with 22R not sure about 4Y. have decided to stick with 22R
Sorry oom Dan, maar jy sit die pot mis.
Die 3CT is n 2.2 diesel.
Posted: Thu Mar 08, 2012 12:26 pm
by Mr_B
Guys, don't be so quick to believe other okes fuel consumption stats! The only accurate way to measure fuel consumption is by logging it for a couple of tanks!
Posted: Thu Mar 08, 2012 12:28 pm
by ThysdJ
Mr_B wrote:Guys, don't be so quick to believe other okes fuel consumption stats! The only accurate way to measure fuel consumption is by logging it for a couple of tanks!
True... so true...
Posted: Fri Mar 09, 2012 11:33 am
by Wegbreek
We have the 3Ct motor and if you drive it nicely at 100-110km/h, 10km/l on the open road. We couldn't live with the fuel consumption of the 2.2 petrol either, and decided to to the conversion. Once we actually managed to get 13km/l on our way back from Kgalagadi! Has not happened again though :)
Posted: Fri Mar 09, 2012 11:48 am
by GI-
Cobus is reg.
3CT is 2.2 Diesel
Only issue is the availability of spares on these engines.
Posted: Fri Mar 09, 2012 2:29 pm
by oom dan
sorry Kaspaas you are right the 3CT is a 2.2lt the way fuel prices are going might become a popular transplant, anyone know what hp it develops
Posted: Fri Mar 09, 2012 2:47 pm
by Mr_B
oom dan wrote:...anyone know what hp it develops
Very little... like a std 4Y!
Posted: Fri Mar 09, 2012 6:16 pm
by jacques kotze
I think he should just keep it as it is.
Posted: Sat Mar 10, 2012 8:26 pm
by krazy_kameleon
Mr_B wrote:oom dan wrote:...anyone know what hp it develops
very similar to standard 4y
I had one in mine - fantastic fuel consumption! I did 30 000km on mine before I stripped my truck for a rebuild.
11-14 km/l best consumption I have EVER gotten on any vehicle EVER!
but as for spares????? terrible
Posted: Tue Mar 13, 2012 11:14 am
by Kaspaas
Rick, now it makes sence!! Didn't realise it was you going the 7MG
TE route!!
Good luck with that mate, I'm telling you now that will need a neckbrace for that whiplash-pull-away
What are going to do with youre trusty 3CT?
Did you really struggle with spares?
Every single bit or just some filters, injectors, ect?
Posted: Mon Apr 01, 2019 1:00 pm
by Turboprop101
Hello. Where can i find a 3ct motor?
by Turboprop101
Hello. Where can i find a 3ct motor? 0720733088
Posted: Mon Apr 01, 2019 10:35 pm
You can try Japan Auto (JHB) but I'm not too sure that you will get lucky. The "C" series diesels are old motors dating back to the 1960's and the 3c-t (turbo) were used up until the mid to late 1990's when they were phased out.
Other than that you can try scrap yards, but again, old motors and you'll need to very lucky to find one in reasonable nick. Then as mentioned, spares are going to be a problem.
If you're looking to fit it into your Landy, then you're obviously not a purist so why not rather go for the Ford 2.5 WL motor. These are pretty tough and reliable motors with good fuel economy and decent torque / power. There are very few Ford motors that I'd recommend but this is definitely one of them.
Posted: Mon Apr 08, 2019 9:43 pm
by Andries
KRY VIR JOU N D4D ENGINE EN SIT HOM IN JY KAN HULLE NOU KRY SOOS DIE LEXUS ENGINS KLAAR BEDRAAD VIR R50000
Posted: Wed Jun 26, 2019 9:57 pm
by obies
Where can I find a D4D complete
