Ammo Box Camp Light
- Johannes van die See
Ammo Box Camp Light
I was looking forward to getting home and starting this small project.
Thanks to Heinrich Traveler for the Ammo Boxes and Piet Petoors for the nice goodies that went inside the box.
This project was fairly simple and straight forward but still practical.
As so many people have made Ammo Box Lights before I had to make myne unique and the main idea was to mount a all round camp light in such a way that I don't need a tree or something high to hang it from, the light should also be high enough so that it does not blind anyone.
The third important feature was that the whole kit should fit inside the Ammo Box.
Lastly an extra feature was to make it remotely operated for those moments where you're already tucked in in your RTT but forgot to switch off the camp light.
Step 1
Sourcing two 7.5ah Lead Acid Sealed Batteries, installing it inside the box, wire it up (parralel for 12V 15ah supply)
Connecting this to the mounted Hella socket.
Step 2
This is where I got the great idea of using an old bow tent pole to mount the light high enough with.
I've cut all the section to length so that it would fit inside the Ammo box, then inserted the thin electrical cable and elastic rope. Connected the LED strip to the top end and the Hella plug to the bottom end of the cable.
Step 3
Then I used one of Piet's Remotely Operated LED Switch/Dimmer to control the switching of the LED strip via Remote Control.
The dimming function also works very nice.
Step 4
Lastly I manufactured a clip-on Stainless Steel bracket to mount the light pole onto the box.
This mounting easily clips off and fits inside the box together with the batteries, light switch/dimmer and folded light mounting pole.
Step 5
Still to come, I will find a way to to fit the 10W 750Lm Spot light so that the box can also be used as a powerful torch.
I did not include a 220V charger as originally planned but for now I will charge it off my Hilux main battery and if needed I'll use my Benton to charge it off 220V power.
The Picks.
Total Cost:
- Ammo Box R75
- 2 x 7.5ah Batteries R300
- 1 Remote Switch/Dimmer R90
- 1m High Bright LED Strip R150
- 2 Hella Plugs R100
- Wire (had it in garage)
- Tent Pole (had it in garage)
Total = R715
Step 1
Step 2
Step 3
Step 4
Step 5
The Picks.
Total Cost:
- Ammo Box R75
Total = R715
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Re: Ammo Box Camp Light
julle manne is vol tricks daar aan die weskus. mooi, goed ontwerp en nagedink. SO hoeveel kos een van daai pakkette kompleet met AMO box en lig etc.
- scout
- Town: White River
- Vehicle: 91 Hilux dc -pro comp , arb bb , winch , 33'' muds
- Real Name: Jonathan
looks really good no I can kick myself for not buying some off those ama boxes
" Yes I know we are lost , but we are making good time "
Total Cost:Hilux 1 wrote:julle manne is vol tricks daar aan die weskus. mooi, goed ontwerp en nagedink. SO hoeveel kos een van daai pakkette kompleet met AMO box en lig etc.
- Ammo Box R75
Total = R715
- Frederick
- Town: Hendrina Mpumalanga
- Vehicle: 2011 Hilux. 2016 79 Land Cruiser
- Real Name: Frederick
- Club VHF Licence: X42
As daar iewers 'n prys is vir 'n oulike idee moet jy dit verseker wen.
Neem jy bestellings?
Dankie vir die komplimente.
Jammer ek kan nie bestellings neem nie want daar is nie meer Ammo Boxe beskukbaar nie.
- Hilux 1
johannes, gee my joune, dan soek jy weer verder
- Hilux 1
Jis Johannes, het jy al getoets hoe lank daai battery jou hou met die lig aan?
Nog nie getoets nie maar hier is die somme.Hilux 1 wrote:Jis Johannes, het jy al getoets hoe lank daai battery jou hou met die lig aan?
Die strip gebruik 0.7amp
Die batterye kan 15ah lewer.
Teoreties moet ek 21uure kry voor die batterye pap is en herlaai moet word.
Onthou pap beteken nie 0V nie maar 10.5V
As ek dus n 3Amp laaier gebruik om die batterye te herlaai sal dit net 5uure neem om vol te laai.
3amp x 5uure = 15ah
Johannes het die lig op die paal gesit
Mooi so, hy het mooi uitgekom
Pieter, praat jy nou uit die huis uitpietpetoors wrote:Johannes het die lig op die paal gesit
Baie nice idee Johannes, ek hou van jou tent paal idee
Johannes het jy die hele meter gebruik?
As dit een meter is op een battery behoort hy gemaklik 6 ure te hou, maar ek het hom al 9 ure op so battery laat hardloop, maar dan druk jy dit bietjie, as daai batterye te pap raak beskadig jy jou battery.
Netnou is ons alweer innie toilet!pietpetoors wrote:Johannes het die lig op die paal gesit
Nice idea Johannes ..... now you will have to incorporate a couple of guy-ropes for that mast in the windy west coast!
Ag no... I just through away an old tent, with the poles which were still in good condition! Thanks Johan, I could have made 5 or 6 of those!
:evil: In future will all of you inventors notify us of upcoming inventions well in advance, as well as supplying a list on items/materials you plan on using!
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
I bought 4 of those boxes & have had the same idea for two of them but using a telescopic pole. Been racking my brains to find one but never considered the tent pole!!!
If there's no copyright on it I'll do the same.
How do you mount the extended pole on the top of the box?
With the little clip-on bracket that's next to the box and poles in the pic before assembly (3rd pic).zepplin wrote:I bought 4 of those boxes & have had the same idea for two of them but using a telescopic pole. Been racking my brains to find one but never considered the tent pole!!!
- Doom
- Town: Windhoek
- Vehicle: '92 Hilux 2.2 DC 4x4 - "Boetman"; '96 Toyota Hilux 4x4 - Lexus, 98 Toyota Hilux 2.4 4x4
- Real Name: Willem
Ek kan inisiatief waardeer. Wel gedaan.
LOS MAAR DIE KAAS, GENIET DIT NET !!
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Baie nice Matroos
Wat van 'n reflector "hoedjie" bo die lig wat nog meer lig kan af weerkaats
Skerp Pieter, dis ontrent al wat op op die paal kan sit,............sport model.pietpetoors wrote:Johannes het die lig op die paal gesit
Sharp thanks Mark,OOOOMS wrote: Baie nice idee Johannes, ek hou van jou tent paal idee
Yes ek het die hele 1m gebruik, dalk moet ek die batterye vol charge en dit run en kyk wat gebeur, ek weet teoretiese somme kan nie altyd prakties toegepas word nie.pietpetoors wrote:Johannes het jy die hele meter gebruik?
I thought the same thing, will have to keep some rope & pegs in the box just for in case ne,Mud Dog wrote: Nice idea Johannes ..... now you will have to incorporate a couple of guy-ropes for that mast in the windy west coast!
I'm a collector, never through away anything, can become a problem with space :evil:Mr_B wrote:Ag no... I just through away an old tent, with the poles which were still in good condition! Thanks Johan, I could have made 5 or 6 of those!
Next time keep what ever looks useful
Go ahead mate, use the idea, it's my pleasure to be of some assistance.zepplin wrote:I bought 4 of those boxes & have had the same idea for two of them but using a telescopic pole. Been racking my brains to find one but never considered the tent pole!!!
I made a small clip on Stainless bracket that sits on the box lid, the pole slides over the pin and it's quite sturdy.
Dankie Oom Doom,Doom wrote:Ek kan inisiatief waardeer. Wel gedaan.
Smaak my julle lees my gedagtes, ek kon nog net nie iets geskuks vind wat sal werk nie, maar ja, al daai lig wat gemors word na bo kan deur die manier lekker af weerkaats word, as jy n idee het help maar asb George.george wrote:Baie nice Matroos
- zepplin
- Real Name: Steve
What about your wife's brand new soup ladle??? Nice and shiny, comes with a convenient handle to mount to the pole too!!Johannes van die See wrote:george wrote:
Baie nice Matroos
zepplin wrote:What about your wife's brand new soup ladle??? Nice and shiny, comes with a convenient handle to mount to the pole too!!Johannes van die See wrote:george wrote:
Baie nice Matroos
Instantly in die k4k, no doubt, but thanks,
- george
- Town: Velddrif
Kry vir jou 'n stukkie "aluminum" wat 'n mens op die dakke gebruik. Van die manne hier gebruik dit vir heatshield in hulle motors
Of 'n ou aluminum eet bord - sideplategeorge wrote:Kry vir jou 'n stukkie "aluminum" wat 'n mens op die dakke gebruik. Van die manne hier gebruik dit vir heatshield in hulle motors
- jacques kotze
- Real Name: Jacques
Goeie werk Johannes.
Mark ek dink jou voorstel is die beste nogOOOOMS wrote:Of 'n ou aluminum eet bord - sideplategeorge wrote:Kry vir jou 'n stukkie "aluminum" wat 'n mens op die dakke gebruik. Van die manne hier gebruik dit vir heatshield in hulle motors
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Johan, hoe wyd gooi daai lampie van jou sy lig?
Weereens, jy het great job gedoen. Nog nooit so iets gesien nie.
Know what you don't know.
Good one, Johan! Simple, quick, easy & efficient.
Sal oor die naweek gou buite loer as dit heel donker is en nie reen nie dan laatweet ek jou.Traveler wrote:Johan, hoe wyd gooi daai lampie van jou sy lig?
Cheers Eric, thanksFamily_Dog wrote:Good one, Johan! Simple, quick, easy & efficient.
- Opsmedic
- Town: Port Elizabeth
- Vehicle: 2001 Hilux KZ TE 4x4 D/C and Suzuki SJ413
- Real Name: David
- Club VHF Licence: HC 308
Baie netjies
- Bugzy
- Town: Rustenburg
- Vehicle: 2015 Hilux S/C 4X4 Dakar1996 2.8D s/c 4x4 Hilux with 3CT Toyota motor
- Real Name: Buks
- Club VHF Licence: X56
Hannelie staan hier by my en lees - nou is ek in die moeilikheid want waar kry ek no so boksie. Sy luister nie na rede of verskonings nie. SY WIL EEN HE!!!!!
Gesels met Traveler, hy het die Ammo Boxe verkoop.
- Club VHF Licence: X93-
Netjiese stukkie werk Johannes.Iets om beslis op trots te wees
Ek het 2 van daai boksies. Lyk my ons kan n veiling begin hou, behoort nogal goeie prys te kry
En ekke het nog drie oor.
- Town: nidrand
- Vehicle: hilux D4d3L
- Real Name: JAMES
hi all i have
90 off the ammo boxes left if anyone wants to buy pm me and we can make a plan
thanks
james
thanks
james
James, the previous forum price was R75, what is your price?James Candy wrote:hi all i have
thanks
james
- mushroom
- Town: krugersdorp
- Vehicle: '16 Legend 45 DC 4x4M
- Real Name: James
Very nice light dude in terms of the reflector - what about cutting two coke tins in half lengthways, glue the inverted lids together. Then you have a lekka reflective surface, which is also very "light"
Q20 if its stuck, duct tape if it moves
- Town: nidrand
- Real Name: JAMES
OOPS i forgot the price
hi all i have
90 off the ammo boxes left at R 60 each if anyone wants to buy pm me and we can make a plan
thanks
im in midrand
james
hi all i have
thanks
im in midrand
james
- Town: nidrand
- Real Name: JAMES
hi Johannes
yip its the same steel ammo boxes no only 80 left going fast
- Town: Durbanville
- Real Name: Richard
@James: Price to get to CPT?
Maybe it is a good idea to send the Cape boxes to one address and distribute from there. Courier for one box will be about R120.00 but courier for 20 will be about R400.00
Makes a small difference.
- KOBUSL
- Town: WOLSELEY
- Real Name: KOBUS
Ou Valiant wheelcap.george wrote:Baie nice Matroos
- STAMPIE
- Town: Durbanville
- Vehicle: '05 4L V6 DC
- Real Name: Danie
Ek sal ook graag een wil hê.
