Ultimate Vigo Hilux's
- African Child
- Town: Grabouw
- Vehicle: Hilux 4L 4x4
- Real Name: Leon
Modifications
It has been modified for 38 inch tires and is currently running 38 inch Radial Monster Mudder. The front suspension was cut of and lowered by 5 cm and moved forward by 4cm (no bolt on lift kit with higher CV angle etc.) and then there was placed a spacer between the front springs for 4cm additional lift, so the total lift is 9cm. The rear suspension is a custom made 4link coil spring suspension, moved 6cm back and the lift is approx 10cm (rear coil springs, shocks and other parts in the rear suspension is from LandCruiser 80). Auxiliary fuel tank (total capacity 150L) and 2,5 inch exhaust pipes. It has 1:4,88 gears and ARB lockers front and rear, ARB compressors for the lockers and one other on board 12V 65A 175L/min compressor for tire inflation. Garmin navigational system and VHF radio
- oskarandri_MG_1653.jpg (39.29 KiB) Viewed 8350 times
- oskarandriHilux07-4.jpg (48.28 KiB) Viewed 8350 times
- African Child
- Town: Grabouw
- Real Name: Leon
Re: Ultimate Hilux's
Modifications
Has colour coded grill
has colour coded flares
Safari Snorkel
3" Monster Rides Rekon Suspension Kit with the works.
Add a leaf rear to factory springs and reset.
extended 2.5" rear LSPV brake line fitted for the extra lift when fully flexed
Black Dynamic Steel Wheels in 16x8 (with "0" offset)
305/70x16 Goodyear Kevlar MTR's
Custom Made high clearance bash plate. (gained 2 inches height and first point of contact is 4 inches further back, now behind the front of the tyres)
Black Xrox Bar
Black Millweld Rock Sliders
Lightforce 240 Blitz Spotlights
Tinted Windows
Tub-Liner with custom anchor points
Rear Quarter Chop and Custom towbar brackets made up to raise towbar few inches higher.
55Watt utility light to light up the tub at night
3 inch Dump Pipe and 3 inch exhaust (Sterling brand) from Humex in Albury
Custom Made Transfer Case Protector.
Front and Rear ARB Air Lockers
Smoked LED tail-lights
Marlin Crawler with 4.7 Gears
Safari Snorkel
Black Xrox Bar
Tinted Windows
- Hilux MaxP1000590 (Small).JPG (43 KiB) Viewed 8345 times
- Hilux MaxIMG_7771 (Small).jpg (57.77 KiB) Viewed 8345 times
- Hilux MaxIMG_7765 (Small).jpg (58.76 KiB) Viewed 8345 times
- African Child
- Town: Grabouw
- Real Name: Leon
Re: Ultimate Vigo Hilux's
Suspension - Modified Ultimate Suspension lift kit now about 5.5-6 inch
Tyres - 285/75/16 Mickey Thompson MTZ (33 inch)
Total lift - About 8 inch
Rims - Chrome Alloy Pro-Comp
BullBar - C/C ARB Winch Bar
Side Rails - C/C ARB Side Rails
Side Steps - C/C ARB Side Steps
Rear Step / Tow Bar - C/C ARB H/Duty Rear Step Tow Bar
Trailer plugs - 7 Pin Round & 7 Pin Flat
Winch - 9.500 Ib Warn Winch
Duel Battery - ARB Duel Battery Kit with Smart Soleniod
Accesory Socket - 1 x Merit, 1 x Cig, 1 x ASPAN Mounted
Seat Covers - Michelle Sacks (Grey) front and rear
Floor Mats - Moulded vineyl clip in (ARB)
Compressor - ARB Under Bonnet Compressor & Pump Up Kit
UHF - GME TX3400 & GME 4705G Aerial
Phone Kit - Nokia Hands Free, with External Aerial
Driving Lights - BullBar IPF 900XS Extreame Sport
- Roof IPF 900XS Extreame Sport
Tub liner - Toyota Tub Liner
Hard Lid - Toyota Hard Lid
Extened Rear brake line
Extened Rear Axle U-Bolts
- DakesPicture 037.jpg (66.51 KiB) Viewed 8344 times
- DakesToyotaHiLuxUltimateLiftKit_1 (Small).JPG (52.03 KiB) Viewed 8344 times
- African Child
- Town: Grabouw
- Real Name: Leon
Modifications
ARB Bull Bar
Magnum Winch 9000lb
Synthetic Winch Rope
Custom Made Scrub Rails & Sliders By Unlimited Industries
Rear Quarter Chop
Custom Rear Bar With Swing Away Wheel Carrier & Jerry Can Holder By Unlimited Industries
Kaymar Wheel Carrier Light
Outback Roof Console
Safari Snorkel
SAS Conversion By Unlimited Industries Including GQ Patrol Front & Rear Diffs Fox Coil Over Shocks On The Front With Eibach Springs ,4 Point Rear With Coils & Koni Shocks
Front & Rear Lockers ARB
Front & Rear Diff Breathers
Custom Exhaust With Ceramic Coated Headers And High Flow Cats
Sprint Booster
Custom Fuel Tank By Unlimited Industries
Second Factory Fuel Filler
Carry Boy Canopy
Rhino Roof Racks
Rhino Shovel Holder
Rhino High Lift Mount
Lightforce 240 XGT Spots / Blue Covers
Dynamica Steel Rims With Unlimited Industries External Beadlocks 16"
ProComp Alloy Rims 17"
ProComp All Terrain Tyres 33/12/17
Simex Centipede 35/10.5/16
Monster Rides Flares Customised
Pirahna Dual Battery System
Pirahna Dual Battery Moniter
Optima Batteries x 3
Toyota Genuine In Dash Gps
GME TX3420 UHF
Ipad 2 Running Memory Map with Windscreen Mount
Eclipse Ipod Docking Station
Eclipse Reversing Camera
Auto Skin Pro ( paint Protection)
ARB High Flow Compressor
MAXTRAX
Hella Micro De x 4
Maggiolina Adventure
ARB Side Awning
Black Widow Rear Awning
Custom Stainless Steel Water Tank Under Cab
Boat Style Stainless Water Filler Nozzle in second filler Pocket
12v switch pannel
Shurflo 12V Water Pump
Just Straps Tie Down System
Scangauge ii
ARB Bull Bar
Magnum Winch 9000lb
Rear Quarter Chop
Safari Snorkel
Sprint Booster
Carry Boy Canopy
Rhino Roof Racks
Rhino Shovel Holder
GME TX3420 UHF
MAXTRAX
Hella Micro De x 4
ARB Side Awning
12v switch pannel
Scangauge ii
- ScotsManIMG_0192 [640x480].jpg (57.56 KiB) Viewed 8336 times
- ScotsManSAM_0922 [640x480].jpg (64.99 KiB) Viewed 8336 times
- ScotsManSAM_0920 [640x480].jpg (87.29 KiB) Viewed 8336 times
- African Child
- Town: Grabouw
- Real Name: Leon
Ongelukkig geen info op die een.
- (63.56 KiB) Downloaded 4436 times
- jacques kotze
- Real Name: Jacques
Impressive
- African Child
- Town: Grabouw
- Real Name: Leon
Modifications
ARB color coded sahara bar, sidesteps, rear step towbar.
ARB compressor, inverter, UHF, stereo system with reverse camera, dvd and sub. Rear seat flip down mod. ARB smooth finish canopy with awning.
Dual batts with monitor, DP chip, IPF spots and spread.
3.5/4" lift consisting of old man emu 2" with 1" strut spacers and extended ball joint in the UCA (stops from hitting the spring on full droop). Extended shackles in the rear.
MR diff drop, custom made bash plate to suit (modified TJM).
305-70-16 MT claws on Dynamic 16x8 0 offset, inner gaurds modded to fit as well as body mount chop an plate. ARB splash gaurds modded as well.
Front and rear ARB air lockers
- teza50IMG_0302 (Small).jpg (49.39 KiB) Viewed 8331 times
- teza50IMG_0412 (Small).jpg (70.88 KiB) Viewed 8331 times
- teza50IMG_0416 (Small).jpg (64.71 KiB) Viewed 8331 times
Velly, velly nice....
- mmaaxx
- Town: melbourne
- Real Name: Max
Hi guys, Came across this thread by accident so thought Id contribute some more recent pics for your enjoyment -
On the way are:
-New sliders
-Beadlocked Wheels and 35" tyres from USA
-Fibreglass Fenders will be removed and fenders will be cut open more
-Larger front brake
and a few other smaller R & D projects along the way that will help 35's work on 3-3.5" lift properly.
Heres a quick Vid from my last trip showing how well the IFS front works.
http://s61.photobucket.com/albums/h68/m ... 5-done.mp4
If anyone has any questions about any of the Monster Rides products in our range Im happy to answer them. Send me an email as max@monsterrides.com.au
On the way are:
-New sliders
-Larger front brake
2007 Hilux SR 4x4
4" Monster Rides Kit, 4.7 Marlin Crawl Box, Front ARB Locker, 305/70x16 MTR Kevlar and a bunch of other stuff.
- Town: Mtunzini
- Vehicle: Toyota Hilux
- Real Name: Max
Loving this thread!
- Town: Petaling Jaya
- Vehicle: Hilux Vigo
- Real Name: Alan
Hi Love this thread!
i just joined the Vigo 35" club, am still learning and slowly modding based on experience.
Hope to learn from all here.
Will post my pict here too, my picts are in a different thread "Lifting my Vigo".
vn wanneer af word pornografie toegelaat op die Forum ?
MOOI !!!!!!!!!
MOOI !!!!!!!!!
- Vehicle: het nie 1 nie
- Real Name: Willem
Maggies...awesome
