Footwell courtesy lights
- Town: Midrand
- Real Name: Nishan
Hi all,
I eventually got around to doing this. Took a long while to figure out how I was going to wire it up to have the lights come on when you open a door.
I eventually figured out that the door switch for the dome light controls the negative loop and not positive.
So, here is what i did:
- got myself 2 LED strip lights (the motor quip ones for R90 each. Other were way more expensive)
- tapped into the negative feed from the passenger door switch to the dome light
- sourced + off my amp which sits under the passenger seat
- mounted one LED strip under the cubby and the other under the dash on the drivers side
- looped power from the first LED to the second
you can connect it off just one door switch. It still works when any of the doors is opened.
i think its not too bright or dim, just perfect!
- (163.87 KiB) Downloaded 1246 times
- IMG-20121001-00328a.jpg (73.57 KiB) Viewed 5749 times
Real drivers use three pedals
- BenRich
- Town: Boksburg
- Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
Re: Footwell courtesy lights
Very Clever...I Like
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Nice idea... I like x2
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Ulfie
- Town: Midrand
- Vehicle: Hilux 3.0D4D D/C 4x4 auto
- Real Name: Ulf
This looks very neat!
Just one question, how does the dome light lens come off? My dome light lens is very tight and I do not want to break it.... Where do I apply pressure to get the lens to release?
They do clip in very tight and need a bit of "encouragement" to pop off. Try the end opposite the switch first, if that doesn't work, try the switch end..Ulfie wrote:This looks very neat!
Ja, those foot-well lights are very handy at night, especially if you're travelling. I wired mine up to a separate toggle switch on the dash (centre console so that the passenger can get to it as well). I used the LED strips available from "The Shop" .... one has to use them in minimum lengths of 3 led's, but three per side is perfect.
Have a squizz at this thread for some tips ........ viewtopic.php?f=94&t=22460" onclick="window.open(this.href);return false;
- Town: Kyalami
- Real Name: Mike
Looking good, I did that over a year ago, but also added a strip under each front seat to light up the rear footwells as well, SWAMBO says its just cheesey and is dof, but she is a girl, what does she know, I think its awesome and comes in handy too.
I also added one to the Cubby hole and centre console compartment, those are linked to the dash lights so they only come on when the lights are on.
- RiyadhFortuner
- Town: Lansdowne
- Vehicle: 2015 Ford Ranger T6
- Real Name: riyadh
Yeah looking good, I miss that feature, had it in my previous car, well done
Just a couple of pics of my installation. The switch is below the cigarette lighter .... there is a punch-out to fit a switch, but mine already had a switch in there from the previous owner and conveniently enough it already had a "Lights" emblem on the switch ... not sure what it was used for before, but perfect for the foot-well lights.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Next upgrade would be a delay timer, so that it would stay on even when you have already closed the doors?
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Town: Midrand
- Real Name: Nishan
the dome light has that, so i suppose if you plugged into that system it would be the samePolarbear2008 wrote:Next upgrade would be a delay timer, so that it would stay on even when you have already closed the doors?
- Town: Kyalami
- Real Name: Mike
Die$eL wrote:the dome light has that, so i suppose if you plugged into that system it would be the samePolarbear2008 wrote:Next upgrade would be a delay timer, so that it would stay on even when you have already closed the doors?
I think thats only from the Vigo models
The way I see it is that foot-well lights should be manually switched ..... to my mind, the point of these lights is to assist in the dark if you dropped something or if Swambo / your passenger wants to look for something in her / his travelling bag, whatever. If you have to open a door while driving .... .... and activating the dome light for this purpose can be a bit distracting.
- Polarbear2008
@Mud dog: I see your point.
I compared this to the lights that my Jeep Grand Cherokee had - they worked this way.
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Nice, BUT why?
- 3RZ
- Real Name: Willem Grimsell
So that you can see who stepped in the doggy doo :)
- Town: Mtunzini
- Vehicle: Toyota Hilux
- Real Name: Max
Very nice - like a lot! There are a lot of different LED strip lights available in various shops - where did you get yours from? I guess they're much of a muchness?
- Town: Midrand
- Real Name: Nishan
i got mine from makro. they were R90 a strip. they not the best quality but they should be fine as they are out the way and dont get moved/touched or anything
Get them here ..... http://www.hilux4x4.co.za/shop/" onclick="window.open(this.href);return false;
Good quality and very reasonably priced! Service is prompt and efficient!
- Vehicle: het nie 1 nie
- Real Name: Willem
Nishan you said that you connected the + to your amp and the neg from the wire from the door switch,,,if door opens they come on,,,what happens if you manually switch the dome light from door to the on position,,,,does the footwell lights also come on ??.......
my electronics background is way rusted,,,sorry for my uneducated ques!
I imagine that they would because you would be opening the circuit. You could prevent ths by fitting a diode which only allows current flow in one direction.
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
So you do not step on the biltong you dropped earlier.Thabogrobler wrote:Nice, BUT why?
Know what you don't know.
- Town: Kyalami
- Real Name: Mike
Traveler wrote:So you do not step on the biltong you dropped earlier.Thabogrobler wrote:Nice, BUT why?
- Town: Midrand
- Real Name: Nishan
nope they dontWillem01 wrote:Nishan you said that you connected the + to your amp and the neg from the wire from the door switch,,,if door opens they come on,,,what happens if you manually switch the dome light from door to the on position,,,,does the footwell lights also come on ??.......
they only come on when a door is opened
FYI, i fitted this to all 3 of my vehicles now. With the RunX they also come on when the boot is opened. As simple a mod it may be, it comes in Very handy and leaves you wondering, "why didnt i do this all along?"
The only bad part is that this light is white and the dome light is yellow. I need to place a big order from the 4x4 shop.
Fog light bulbs x 4
number plate lights x 6
dome lights x 3
dashboard cluster bulbs x ? (need to open it out and check first)
I also need to sort something for the light fitting in the canopy...
A couple of LED strips in the canopy (one each side) works fantastically! (Also available from "The Shop")
