KZTE Cooling System Pressured expansion tank
- Town: Vereeniging
- Vehicle: Hilux 3.0 D4D S/C
- Real Name: Phil
Gents, I noticed this when browsing for a double cab for sale. Radiator sealed and pressure cap on the expansion bottle.
Can anyone explain this to me. I think it is standard to have a pressurised radiator and not an expansion tank?
- //www.hilux4x4.co.za/views/viewtopic.php?f=129&t=27197
- (146.41 KiB) Downloaded 402 times
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Re: KZTE Cooling System Pressured expansion tank
I've also seen this on later models, think 2004 and up... I personally think its better than way, no radiator cap that can leak!
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
4x4Maniac wrote:I've also seen this on later models, think 2004 and up... I personally think its better than way, no radiator cap that can leak!
Sien jy Werner, dis my bakkie daai, ons het ook mos na dit gekyk. Phillip het my gevra maar eks nie seker wat is standaard nie, en/of soos jy se hulle dit dalk verander het.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Yes this is correct. All the facelift (bullnose) KZ-TE layouts are like that.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Nope!Polarbear2008 wrote:Yes this is correct. All the facelift (bullnose) KZ-TE layouts are like that.
My facelift(2002 - June) Kz still has a radiator cap and expansion bottle. However, the expansion botlle is not pressurised.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Wayne, ek wou se iets lyk bekend aan daai engine bay!
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Not all bullnose facelifts have this, mine is a late 2003 and have a cap and separate expansion bottle, also not pressurised.Thabogrobler wrote: My facelift(2002 - June) Kz still has a radiator cap and expansion bottle. However, the expansion botlle is not pressurised.
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Sun Chaser
- Vehicle: '02Hilux Raider 3.0 KZTE 4x4. Jeep Grand Cherokee 3L V6 CRD Overland
- Real Name: Ian
First time I've seen it, my '02 KZTE has a radiator cap and seperate bottle,"not pressurised".
'02 Hilux 3.0KZTE
Iron Man Suspension
Air Ride Suspension
Alu Cab Canopy
Alu Cab Rooftop Tent
Dual battery Kit
6oL LRT
BFG 31x10.5 A/T
2014 Jeep Grand Cherokee 3L V6 CRD Overland
Ek wonder nou,
Die ouens wat almal heads gekraak het, was dit meer van die ou soort of meer die nuwes?
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Ek wonder ook, ek neem aan die vroer modelle sal aan neem dat dit aangebring is na die probleem ontdek is.....Thabogrobler wrote:Ek wonder nou,
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Ek het ook daai een gewonder, miskien het Toyota aandag gegee ivm die cooling, presies vir daai rede... Miskien moet ons n poll maak om te kyk hoeveel KZTE's se tops het al gekraak per jaar model?Thabogrobler wrote:Ek wonder nou,
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- louis fourie
- Club VHF Licence: X101
My head het gekraak en is van die "ou" soort:oThabogrobler wrote:Ek wonder nou,
