What gear ratios on a KZ to turn 35's?
- Donkey
- Club VHF Licence: X122
Been searching but not winning, what is the proper diff ratios on a KZ to be able to turn 35's? Please help.
Tumelo Maketekete
Re: What gear ratios on a KZ to turn 35's?
Don't know about the ratio's, but that will be at least another 3 rows of brick above the garage door!
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Thabogrobler wrote:Don't know about the ratio's, but that will be at least another 3 rows of brick above the garage door!
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Town: Muscat and Midrand
- Vehicle: 2.7 Hilux 4x4
- Real Name: Roelof
Hi Donkey
What is the standard diff ratio and tire diameter/circumference? At what RPM do you normally change gears?
If I have that I can calculate the ideal replacement diff for 35”s. You may not be able to get exactly the same but it will give you a good enough idea.
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
there are only two ratios available for the front diff on your IFS, your current 3.66 and the 4.55 used in the 2.7I and 3000D. The 4.55 will work perfect with the 35's, but you need a 4" suspension and a 3" body lift to get those in. With 33" tyres you can get away with only one of the two.
- Hoppy
viewtopic.php?f=136&t=17499" onclick="window.open(this.href);return false;
I did exactly that a few years ago on "Kwagga 2" we had 4.55 ratos, 35's on 10" rims, 4" pro comp suspension and 3" body lift
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
when you say a 4 suspention and 3 body! what does that mean in mm? or how does it work?
4inch + 3 inch= 7 inch!!!Tarquin wrote:when you say a 4 suspention and 3 body! what does that mean in mm? or how does it work?
1 inch = 25.4mm, therefore:
7x25.4 = 177.8mm!!!
- Tarquin
geeze that's a lot
what is the width of 35's?
35 10.5 15?
what would one have to change to put those on a SFA
35 10.5 15?
- TOYODA
- Real Name: Tiaan
Tarquin wrote:geeze that's a lot
35 10.5 15? what would one have to change to put those on a SFA
35's op 'n 15" rim kry jy nie 10.5 nie, jy kry wel 12.5(318mm) of 13.5(343mm).
- Tarquin
so jy kry 35 12.5 15? Kan jy die origional rims gebruik?TOYODA wrote:Tarquin wrote:geeze that's a lot
- Tarquin
ok i understand many thanks
- Donkey
Tumelo Maketekete
- Donkey
Thanks guys for the input guys.
@ Hoppy - what is the standard ratio on the KZ? Should I go 4.55 or 4.88?
@ Thabo - already fits in the garage
Will report progress on my other thread about the panelbeater
Tumelo Maketekete
- JJBotes
- Town: Witbank
- Vehicle: KZ-TE
- Real Name: JJ
Where can I find your "other thread " ?Donkey wrote:Thanks guys for the input guys.
Will report progress on my other threadabout the panelbeater
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
What are you trying to do to that TZ of yours.....Donkey wrote:Thanks guys for the input guys.
@ Hoppy - what is the standard ratio on the KZ? Should I go 4.55 or 4.88? FIT 4.55 SEE UBOVE
@ Thabo - already fits in the garage If you put 35" on you wont fit it in the garage...
33" is already big enough....
You gonna make it really thirsty....
[rimg=206x128]
[rimg=206x128]
- Donkey
I don't drive like a maniac to make it thirsty and even then it'll beat your 4Y with consumptionMOFASA wrote:What are you trying to do to that TZ of yours.....Donkey wrote:Thanks guys for the input guys.
@ Hoppy - what is the standard ratio on the KZ? Should I go 4.55 or 4.88? FIT 4.55 SEE UBOVE -
@ Thabo - already fits in the garage If you put 35" on you wont fit it in the garage... - ALREADY HAS 35'S AND IT FITS
Tumelo Maketekete
