Ek wil my kompresser agter my agterste sitplek sit maar is effe groot. Ek gaan die voetstuk af haal om verder van die sitplek te kom. Het iemand dit al gedoen soek raat met hoe om hom vas te sit en wat moet ek as voet stuk gebruik en hoe warm word die kompressers?
Sent from my SGP321 using Tapatalk 4
Kompresser agter die agterste sitplek
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
- Genissie
- Town: Hartenbos
- Vehicle: LC 80, 4500
- Real Name: Andries
- Club VHF Licence: X254
Re: Kompresser agter die agterste sitplek
daai compressor word erg warm, selfs die couplings kan jy nie aan vat nie, maak dus seker dit raak nie aan die seat of iets nie
- Town: Howick
- Vehicle: 1998 Hi-lux 2,4 S/cab (p); 1997 Hi-lux 2,4 D/cab (p)
- Real Name: Harold
Rather have compressor seperate; fixed behind the seat restricts use to the immediate surround of the vehicle. Space behind the seat is ideal for other loose items, such as a briefcase, magazines, maps, toilet paper, etc, etc, etc.
I have mine fitted into one of the smaller ammo boxes, which has enough room for other items such as the extension cord, pressure gauge, puncture repair kit, etc.
- arb.jpg (92.45 KiB) Viewed 1892 times
Harold (Greytown, KZN)
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Got mine strapped in the canopy.
Was behind the seat,but would get to hot and awkward to reach all around the vehicle,must also look at Cassies system,but please don't put it on while driving,the air pressure is to high and tends to flip the bakkie over Not all those who wander are lost!
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Ek sal my dood huil as dit my oor kom. Ek wil ook iets soos hy doen maar will die kompresser permanent instaleer wou eers dit langs die air filter sit maar is bang die hitte van die engine brand die kompresser na n ruk.Thunder02 wrote:Got mine strapped in the canopy.Was behind the seat,but would get to hot and awkward to reach all around the vehicle,must also look at Cassies system,but please don't put it on while driving,the air pressure is to high and tends to flip the bakkie over
The best IMO is not to mount it in a fixed position, so that you are flexible with it's use .... you might need to assist another vehicle or any other use away from your own vehicle. Additionally, if placed outside during operation it gets better air cooling which allows a slightly longer duty cycle and the unit is more likely to last longer.
- merwn
- Town: Kriel
- Vehicle: 1995 Hilux 4x4 DC
- Real Name: Nick
Hallo
Ek het myne in Jan 2010 ingesit in die bonnet het my lux verkoop en werk nog steeds het net 'n lang hose wat buite op onder voor fender in pas met coupler dan kan jy ver by kom kyk op die link
viewtopic.php?f=41&t=5671" onclick="window.open(this.href);return false;
