Dust Ingress Hilux
Mikeljon
Vehicle: Hilux 3.0 D4D
Real Name: Mike
Dust Ingress Hilux
Post by Mikeljon »
Have a standard Hilux 2012 4x4 DC with Beekman Executive canopy, and need to seal somewhere to prevent dust ingress. Any solutions out there?
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Re: Dust Ingress Hilux
Post by FIRSTGEER »
Welcome to the forum Mike.I believe that installing air vents to the canopy will caust the canopy to have higher air pressure and thus reduce the dust inflow dramatically.Vents were previously advertized for sale on this forum and I'm certain one of the members will assist you in this regard.Good luck.
Welcome aboard, Mike! :thumbup: :thumbup:
Yes, the vents make a big difference - they must be fitted and oriented so that they feed air into the canopy (positive pressure). Even leaving the 'cab-slider' window open a bit solves most of the problem. Vents are readily available at most spares outlets, but for quality, fast efficient service and extremely competitive on-line prices, "The Shop" (link provided in sub-header at the top of the page) is the way to go. ( http://www.4x4direct.co.za/shop/canopy- ... -p-307.htm" onclick="window.open(this.href);return false; )
Post by 4x4BEES »
Welcome Mike.
You have come to the right place for advice :thumbup: :thumbup:
LouisZ
Post by LouisZ »
Check the 4 corners of the load bin 1st. It is there wher most of the dust get in, water also. Your wheels throw it into the wheel arch and then into the load bin. Use sponge to block the holes.
Check the photo.
(107.39 KiB) Downloaded 479 times
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
Open the front slider window Mike... That causes positive pressure inside the canopy.. :thumbup: :thumbup:
Rianc
Vehicle: 2.8GD6 Double CabHilux 4X4
Real Name: Rian
Post by Rianc »
En wat van die Fortuner? Hy suig ook lekker stof in op die agter deur. Sit gewoonlik die aircon full blast met outside air om die druk verhouding te kry, maar werk nie altyd nie?
Rianc wrote:En wat van die Fortuner? Hy suig ook lekker stof in op die agter deur. Sit gewoonlik die aircon full blast met outside air om die druk verhouding te kry, maar werk nie altyd nie?
You could fit a pair of 'wrap-around' vanes at the back, like one sometimes used to see on older station wagons. What they do is minimise the low pressure vortices at the rear of a vehicle and in so doing draw less dust up directly behind the vehicle. If I'm not mistaken, someone submitted a post here where that did that to the back of a canopy with positive results. ;-)
ThysdJ
Post by ThysdJ »
It is my Cortina Flaps you are talking about Andy.. Yes it could work, but they will have to be quite big and low down on the vehicle. Mine works beautifully to keep dust off the back of the vehicle, but I always drive with the cab slider open, so that was not the reason for fitting them. With the Fortuner I would say go see Toyota and tell them to fix the rear door seals. That seal around the back door should be air tight to keep exhaust gasses out as well. If exhaust gasses can get it the vehicle is unsafe... :shock: :shock:
You could always get in there with adhesive foam strips to improve the seal, but it's not supposed to be like that.. :silent: :silent:
Return to “Useful Articles”
