Exhaust pump for tyres?
doggone
Vehicle: Hilux 4X4 3.0 D4D
Real Name: Pierre
Post by doggone »
I have been wondering for a while why no one has designed a pump for tyres that works off the exhaust like those air jacks. Surely there is more gas flow than what our 12v units can put out.Pressure can also not be a problem.
If it is a question of the gas being too hot then maybe the gas can be used to drive a pump like it does a turbo?
I would love to hear from the technically proficient people on this site.
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Re: Exhaust pump for tyres?
Post by Bushwacker »
george
Town: Velddrif
Vehicle: Triton 3.5l V6
Club VHF Licence: HC107
Post by george »
When I still had a petrol I had one of these pumps where you took out on of the plugs and put an adapter in there and you start the car.The engine compression than supplied the air.That thing was extremely powerful and could bead a tyre easily.
doggone
Real Name: Pierre
Post by doggone »
Thanks . Makes sense now.
Hunter26
Town: King Williams Town
Vehicle: Isuzu
Real Name: Craig
Post by Hunter26 »
What if you have a diesel,no spark plugs :D
Craig
Isuzu 250D 4x2 with diffy lock
1 x Humorous Driver
GPS,Dashcam,tyre levers
I don't live in Africa, Africa lives in me - Kyle my son.
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Post by zepplin »
Diesels don't get flats............. :twisted: :twisted:
Nickey
Town: Malmesbury
Vehicle: fortuner
Real Name: nickey
Club VHF Licence: X 100
Post by Nickey »
Here in Nigeria, they use an old air con pump that is connected to a honda engine via a fan belt. It works, so i was thinking that in an emergency situation one can try that.
Hunter26
Vehicle: Isuzu
Real Name: Craig
Post by Hunter26 »
Nickey wrote:Here in Nigeria, they use an old air con pump that is connected to a honda engine via a fan belt. It works, so i was thinking that in an emergency situation one can try that.
After all the cost and hassels one might as well just buy a 4x4 heavy duty 12v compressor.
Reading about using an aircon as a compressor,one has to add a few tsp of oil into the aircon to lubricate it as it gets it lub from the oils added into the aircon gas- some thing to that effect.
An expensive but similar idea would maybe work ,is to make a separate air storage tank and take a feed off the compressor ( the one you use to jack up the air suspensions) to fill this tank.
Craig
1 x Humorous Driver
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
Aircon compressor works great. You connect the air intake of the compressor to the tappet cover breather and it will get lubricated from there.
Haboob
Real Name: Edge
Club VHF Licence: HC129
Post by Haboob »
& suck all the oil out the engine... :laugh2: :blackeye: :surrender:
HABOOB means "Dust Storm"
ThysdJ
Post by ThysdJ »
Haboob wrote:Aircon compressor works great. You connect the air intake of the compressor to the tappet cover breather and it will get lubricated from there.
It'll have to really suck!! :twisted: :twisted: :twisted:
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Buy a York 210 compressor that has a sump, try and fit it in the engine bay, if it doesn't fit(like in my case) connect it to a 2kW+ starter motor with a 2:1 ratio at least, then you have a serious bad ass wheel pump... a few points to note though is you need a oil trap on the outlet, 25mmsq+ SHORT as possible power cables, a lot of patience in finding the right stuff to make it work...
(95.72 KiB) Downloaded 99 times
(105.37 KiB) Downloaded 99 times
2632 (Small).JPG (92.6 KiB) Viewed 1942 times
2735 (Small).JPG (92.86 KiB) Viewed 1942 times
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
