Bleeding cooling system
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
I changed my water pump on my V6 Ford last night, now its running hot. How do I go about bleeding it?
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: Bleeding cooling system
Put a 4Y or 7M in it.......
Run the engine without the radiator cap and also switch on the heater and then let the motor idle until its starts to warms up. Then let it cool down, top up the radiator, put the cap back then then go drive it and run the heater for a while to make sure that there is no airlock in the system.
to add to JohanM's post. You can also undo the top hose from you radiator and pour water in there until it is full and re-attach the hose to the radiator. Idle the motor without the radiator-cap and trickle water into the radiator until no more bubbles. :)
m2cw
m2cw
Jy kan ook die boonste radiator hose soos 'n pomp gebruik (as die prop af is sodat jy kan sien hoe die lug uitkom) om airlocks uit die systeem te pomp
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
Top hose was not getting warm, replaced thermostat. 100%. I first tested the thermostat in boiling water, it only opened when the wate was boiling.
So she's okay now??
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
yip, I also removed the aircon radiator from the front. Pulls in air nicely.
good... she should be fine now.. :roll: :roll:
