blown head gasket symptoms
- Tinman
- Town: perth
- Vehicle: 1991 hilux surf with 31" kuhmo kl71's
- Real Name: Stuart
i have the mayonaise in the rocker cover, brown sludgy oil, and hardly any radiator fluid left.
how hard is it to change the head gasket?
Re: blown head gasket syptons
Not difficult if you follow your fellow countryman's Instruction Manual:Tinman wrote:i have the mayonaise in the rocker cover, brown sludgy oil, and hardly any radiator fluid left.
Hilux/4 Runner 1970-1997
Automobile Repair Manual
Author: Max Ellery
Code: EP.TH4P
Available From:
Max Ellery Publications
78 Hatham
Golden Square
Victoria 3555
Ph. 03 5444 5622
Fax. 03 5444 2660
Best of luck
Rich
For the South Africans:
It's available through Kalahari.net for R250
For Other Hilux Manuals go to:
http://www.ellery.com.au
Retrieve the relevant Code:
ie. Code-EP.TH4D for all SFA Hilux Diesels
Then Order through Kalahari.net
Rich
Rich
Hi Tinman,
The 4Y often blows on the outer edge of the no.4 cylinder.
Replacing the head gasket is pretty straight forward, but there are a few things to watch out for. The 4Y is a push-rod motor, so the cam is in the block, the head can be removed without having to remove the timing chain and assembly. The rocker assembly just bolts off, but can be bit of a pain to put back on, you have to keep rocker arms/push rods in place while bolting the assembly back on. You must also mark which pushrod goes where and put them back exactly as they were. You will have to drain the coolant, disconnect the water pipe at the top, as well as the pipe from the rear of the head. Drain oil, remove oil filter and replace.
Once the head is off, the block and head should be pressure tested and checked for warping/ visible crackes, if warped they(head/block) will need to be skimmed as least, if cracked you will need to get advise from an automotive engineering firm on whether it's repairable. Many mechs just put a new gasket in without checking the head and block, leading to premature failure of the head gasket.
You will need a good torque wrench, to torque the head bolts back to spec, the head bolts must be re-torque'd after 1000km's...
If you are not entirely positive you can do the job rather get a good mechanic to do it, may work out cheaper in the long run!
B
B
- Tinman
- Town: perth
- Real Name: Stuart
Re: blown head gasket symptoms
i have a manual on how to do it and i have everything that i need, shouldnt be too hard. lets just hope there isnt to much corrossion. what is the best way to clean the surfaces if there is a very slight bit of corrosion?
On any other mating surface I would say use a mating surface file and some emery paper, but this the head and block... if you want the job to last a decent length of time, then skimming the head is vital!
B
B
I need to polish up my fluffel valves, so:snipes wrote:On any other mating surface I would say use a mating surface file and some emery paper, but this the head and block... if you want the job to last a decent length of time, then skimming the head is vital!
B
Where can I get a bag of skimming powder from Bretton or does it now come in a Gel
Rich
- dalkill
- Town: Cape TOwn
- Vehicle: 2.4 GD6 SR D/C 4x4
- Real Name: Shaakir
I had the same with my SC 2.2. Previous owner had skimmed the thing to it's last so I had to replace - with pirate head. Was fine after that till one day one of the water pipes burst and I did not notice the temp go up past red... Tested it when I was selling it some time after that. Slight crack in the gasket, but all seemed to be OK.snipes wrote: The 4Y often blows on the outer edge of the no.4 cylinder.
Does the import 4y's have the same problem?
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
Interesting questiondalkill wrote:Does the import 4y's have the same problem?snipes wrote: The 4Y often blows on the outer edge of the no.4 cylinder.
4Y Head gaskets usually blow on Original 4Y's at nothing under: 180,000 and then it's not uncommon for them to go again around 230,000 and then again around 300,000 odd Kms
As the Korean ones are manufactured using the tooling they bought from Toyota Japan; I guess they will follow suite :roll:
Rich
My opinion on 4th cylinder blows:
The wall between the water jacket and cylinder is pretty thin at the back end of the no.4 cylinder. On the block and head this water channel is one wide channel, but the head gasket divides it into 2 section, with a piece of gasket inbetween. So over time(lots of time...) the piece of gasket between the 2 channels weakens and deforms, allowing the high combustion pressure to push the steel 'cylinder' part of the gasket back a bit, making it fold, and eventually you have a blow head gasket. I would think that the original head gasket is higher quality and lasts longer. The pirate gaskets are probably weaker and therefore suffer this fate sooner than the OEM part. This is exactly what I found with my lux!
m2cw :D
B
m2cw :D
B
- Scorpion
- Town: Emmarentia
- Real Name: Johann
My original 4Y went 360k km's before the headgasket went...Dadz Toy BFI wrote:
1978 Land Cruiser HJ45
I met one that has done 470k and is still going strong heyScorpion wrote:My original 4Y went 360k km's before the head gasket went...Dadz Toy BFI wrote:
Mine was blowing on the 1st and 4th head when we took the head off after the transplant
(she'd done 183k)
When you look closely at the block you can see the susceptible area at the back of No.4; where the barrel and water jacket are close, close true.
I took some close up high definition photos with Bretton's camera, hopefully he'll release them when his laptop comes back from the repair shop :roll:
Rich
The repair shop is battling with my laptop, not sure why, maybe sony parts availability, anyway I may well fire up the old desktop PC this evening as backup!
B
B
Stuart
Check out these New 4Y's from a Dealer in Brizzy Mate
http://www.brisbanemotorimports.com.au/new-parts.htm
Rich
Rich
- Tinman
- Town: perth
- Real Name: Stuart
cheers for the link.
the head is off!!! head gasket was blown through on every cylinder, and the head is warped by about 1mm.
the block seems fine, so i will probably get the head skimmed or get a new head. what is the best way to clean the head gasket off the head and block?
- Tinman
- Town: perth
- Real Name: Stuart
ok maybe 1mm is a bit off its actually .1 of a mm off
anyproblems with just new gasket and re torquing a bit tighter than its supose to be?
im trying to get this runnung again as cheep as possible.
You can get a special file "just for the job".Tinman wrote:cheers for the link.
Bretton (Snipes) might just take a picy of his for you
Rich
- Tinman
- Town: perth
- Real Name: Stuart
sorry to get ur hopes up chaps, the head is stuffed, the water jacket next to no4 is corroded so closes that it would blow the head instantly because the twit of a previous owner used water not coolant.
Yeah, mine looked pretty horrible too mateTinman wrote:sorry to get ur hopes up chaps, the head is stuffed, the water jacket next to no4 is corroded so closes that it would blow the head instantly because the twit of a previous owner used water not coolant.
Any chance that you can post some photos of your engine showing the probs; as many folk never get to see it 1st hand - helps us understand and ol' :roll:
So what will it be for you Sir a Korean Beauty
Rich
- Tinman
- Town: perth
- Real Name: Stuart
i will post pics as soon as possible.
no im gonna stick with my block because that's fine. im just gonna get a new head, which comes in on tuesday
All up for complete head and head gasket kit $730 australian
then when i have it all going good. WEBBER TIME
also whats a good way to get the rear rocker bolt out??? it doesnt want to budge
Stuart
Just remember to get your lux some wooden wheels with the Webber as both rechnologies has been around from about the same era
- Tinman
- Town: perth
- Real Name: Stuart
heres a few more pics
Hi Stuart,
Yip that's a blown head gasket alright! I'm 100% sure your lux will a much happier lady with the new head on! The file that Richard mentioned is a surface mating file, but I wouldn't recommend it for use on the head or block. I have cleaned the block surface before with a solvent(like thinners) and a light scraper/stanley knife blade, doing the job carefully!
The part I don't enjoy is cleaning the head around the exhaust/intake manifold, those pesky studs are a pain!
B
B
Thanks for the Pics Stuart :!:
Maybe one of the Mods can do something nice with those photos ;
Will make a great Reference Thread for the average Lux Owner who's never seen his engine.......
Naked
Have also got some good macro shots of my shot gasket and similarly corroded No.4 jacket, once Petrol Head Bretton (Snipes) gets around to downloading them :roll:
Thanks again mate
Rich
Naked
Thanks again mate
Rich
- Scooter
- Town: JHB
- Real Name: Scott
Stuart, try giving it a "little" tap, the vibrations tends to loosen bolts. Also try leaving a bit of silicon spay etc (wd40 etc) for a day or two.Tinman wrote: also whats a good way to get the rear rocker bolt out??? it doesnt want to budge
If corroded, then im afraid the only way is to break it off and drill it out.
Glad you foudn your problem. The lux will be much happier with a new head. :D
Stuart
Please post a few photos of your old head too
My vehicle's Original Motor looks quite different to the regular 4y's in RSA, I'm wondering if it was an Ausy Spec.
I'm keen to see the top view mate
Rich
Rich
- Tinman
- Town: perth
- Real Name: Stuart
i got the head bolt off with a 3' torque bar, shows just how tight it was on there.
Hopefully the new head and gasket kits comes in today.
the sooner it comes in the sooner i can let it rip
- Tinman
- Town: perth
- Real Name: Stuart
heres the pics of the new head and assebly
You Beauty !!!
Very Nice Stuart
Big thanks for posting such awesome pics
Rich
Very Nice Stuart
Rich
- Scooter
- Town: JHB
- Real Name: Scott
Nice Stuart, Looking good mate.
Just looking at the pics, that engine bay looks way to clean to be a working lux
Seriously though, have you thought about replacing that old points dissi with an electronic one Would give you even better performance :!:
Stuart
Can you tell us what state the water inlet flange was in please
Mine was quite corroded, but we salvaged it and used some high temp' grey silicone on the outside - to be safe
Also - my motor didn't have a thermostat
Just the top half of the thermostat was installed; to make use of the rubber seal :roll:
Suffice to say we installed a new Toyota one in the new Korean 4Y
By the way I was keen to see your head as my old one had "unusual" wells in the top - not usually seen on a 4Y in RSA and the "Aussie Spec" was my 1st guess. Does yours have four deep wells on the right hand (manifold) side; when viewed from the top - I can't get a clear look at that area on your photos:?:
Thanks for Posting Stuart, it's great to see how you do things down-under
Rich
Rich
- Tinman
- Town: perth
- Real Name: Stuart
yeah my head has the bits that u were tlking about.
its so clean at the moment, as soon as i get oil coolant and a filter im off to find some GLORIOUS DIRT ill post some pics of that.
yeah im going to look into an electronic ignition there about $200 aus
mite leave it a bit tho because my dizzie is near new.
What is the BEST oil for the 4y?
- Tinman
- Town: perth
- Real Name: Stuart
the inlet flange was slightly corroded but it cleaned up fine and seeled fine.
yes the wells are there in the right manifold
Also is there some easy way to put rockers in becuse we ended up using one way ties and string to hold everythin place, that or u have 10 arms. the string and ties worked well tho.
Great News mate :!:Tinman wrote:the inlet flange was slightly corroded but it cleaned up fine and seeled fine.
Looking forward to seeing and hearing about you getting down n' dirty with your shiny bitz
Rich
Hi Stuart,
On holding the rocker arms in place on the shaft, I used the long pieces of hard wire left from used rivets(cause they were strong enough), bent the 2 ends down, pushed the ends into the holes on top of the rocker arms to keep them in place, worked perfectly!
Can't wait to hear how she runs!
B
B
- Tinman
- Town: perth
- Real Name: Stuart
sorry ladies and gentlemen but shes not running.
shes got oil and coolant
all plugs are cleeen, all cables r correct it turnes over, fuel is going into the carby.
anyidea people?????
anyidea people?????
- Scooter
- Town: JHB
- Real Name: Scott
Timing out? rotor in? points opening? Spark?
Be sure your dizzy isn't fitted 180deg out of position. I caught myself like that once or twice.
- Tinman
- Town: perth
- Real Name: Stuart
k heres the diagnostic report
great spark
good compression
timing is correct
fuel is going into the fuel bowel in the carby
however i remember when ever iv taken the carby off there was a pool of fuel in the manifold, so im thinking bad jets, or something else with the carby. the carby has no choke and both ovcv have been disabled.
im goining to try cleaning the jets on the carby tomorrow.
great spark
good compression
timing is correct
- Tinman
- Town: perth
- Real Name: Stuart
ok all jets are clean
and it runs but it back fired up through the carby.
iv tightened up the manifold nuts however iv got a flat battery (DAMN U MURFY)
im going to get a new battery, and nice big propper one, because mine is a cheap small generic one.
what battery do u guys recomend? my mums has an exide n50 light truck/4x4 which has lasted ages and is great, and iv used it in mine once when i needed 2 move mine when my bat was flat, and it was soo much better.
Exide 652 will fit and has somewhat higher capacity than the standard 647. Not sure whether the battery reference numbers in Aus are the same as here, but you can compare the specs & sizes from this PDF chart. The 652 is slightly taller than the original spec 647 battery and you will need a new J-bolt, has to be about 15mm longer than the original one.
Australian Exide: http://www.exide.com.au/products/specifications.php
- 1912_willard_folder_p11.pdf
- Willard Battery Specs
- (21.1 KiB) Downloaded 31 times
Hi Stuart,
Back firing through the carb is typical of the dizzi shaft/rotor being installed 180deg out. Do you have the instructions to check if it is installed correctly? It's an easy mistake to make... I too have been caught out like this!
B
B
- Scooter
- Town: JHB
- Real Name: Scott
Turn the motor over at the crank unitl No1 is firing and make sure the rotor lines up with the correct spark plug lead.
There should also be a marking line on the dissy itself (with cap off) that shows the correct position for the rotor to line up with.
Worth a look :D
Worth a look :D
- Tinman
- Town: perth
- Real Name: Stuart
ill be checking all what u guys said in a few hours once iv finished some papper work, and then my old battery should be chared.
- Tinman
- Town: perth
- Real Name: Stuart
all rotors are fine however there is about half a mm maximum between the bracker at peek, is that correct?
This is exactly what caught us out as well. The timing mark is on zero, piston one is at TDC but if you do not check to ensure that the valves are rocking the dizzy may very well be out by 180.Scooter wrote:Turn the motor over at the crank unitl No1 is firing and make sure the rotor lines up with the correct spark plug lead.
Worth a look :D
To test this, remove the plug and alu tube at no 1 stick your fingers in the hole and feel the pushrods moving while you turn the motor slowly by hand. Both the pushrods should be down and not move while the engine turns and the timing mark on the crank pulley passes the 0 degree mark.
This is the correct way but experience taught me that if she misfires back through the carb it is normally an indication that she is out by 180 degrees.
Simple check is to quickly take out the dizzy, swing it 180 and put it back in. Swing her now and if the backfiring stopped she should now fire on no1 during the compression/power stroke and not while a valve on no1 is open
Hope she starts now
- Scooter
- Town: JHB
- Real Name: Scott
Can always rely on Bennie to give us a better explanation :D
Stuart, the breaker point gap for the 4Y should be 0.45mm so yours sounds good.
For the mechnically challenged guys like me, what Bennie means when he says 'swing it 180 and put it back in':BenHur wrote:Scooter wrote:Simple check is to quickly take out the dizzy, swing it 180 and put it back in. Swing her now and if the backfiring stopped she should now fire on no1 during the compression/power stroke and not while a valve on no1 is open
Take a (very) deep breath, Take the dizzi cap off, take the dizzi lock bolt out, exhale - breath in (fetch a beer)note the position of the rotor, lift the dizzi body up until the rotor shaft can turn freely(disengaged from the worm gear),exhale - breath in (down the beer) turn the rotor shaft 180deg, slide the dizzi body back into place but remember to compensate for the worm gear, cause that will affect where to rotor points once the shaft is back in place... when you done the rotor should point exactly 180deg from where it originally was.exhale (fetch another beer)
Bretton you left out a few steps - I added it in red and I tweaked it a little more!
:D
I sense a Bennie spoek!
So did I by changing your extra comments to BLUEsnipes wrote:and I tweaked it a little more!
and locking you out from your own post so you can not go and stuff it up again
- Tinman
- Town: perth
- Real Name: Stuart
Ok guys theres one massive problem with it all
WHAT DO I DO WITH THE OTHER BEER YOU DIDNT SAY TO DRINK THE SECOND ONE!!!!!
I cant do self thought ahhhhhhhhhhhhhhhhhhhhhh.
ok ill be checking everything tomorrow afternoon when i get home from work so about 7am ur time
and ill be getting the new battery for it. also, has anyone fitted a 4y with a 34 adf webber because thats wat everyone does here in kangaroo land and i hate my nikki, it must have been put together on a friday after noon.
the webber is $395 australian, and everyone here recons its worth it.
cheers for the advice
I used a 36/36 Weber before the BH-EFI conversion. The Webber provided netter pulling power than the original carb, not much difference in fuel consumption, (both was horrible) and useless on a steep incline. But it sounded very nice!
- Tinman
- Town: perth
- Real Name: Stuart
hey all
it works but i got carby issues, cos the choke has had it it only runs through one butterfly which aint enough so it dies at low rpm and sounds lik a gattlin gun.
- Scooter
- Town: JHB
- Real Name: Scott
You sure you not trying to sell yourself a weberTinman wrote:hey all
Eish, it is proving difficult to diagnose over the net on this one. What have you checked and changed so far Stuart
- Tinman
- Town: perth
- Real Name: Stuart
ok the carby has been cleaned and all new gaskets and everything.
the problem is that the ovcv is broken so im just not getting enough air/fuel through to the engine.
im going to try making a linkage so as to get both butterflies working in unison,
i just dont want to get stuck anywere because of that carby which has been a lemon since day one.
im gonna try as much as i can with it, however i have driven a lux with a webbered 4y and it definately had more grunt than mine. if only i had the time and expertise to go efi.
Tinman wrote: ......................im going to try making a linkage so as to get both butterflies working in unison,
What's the Latest Stuart;
did you get both butterflies working in unison
(Bennie is open to Holidays down-under hey )
All the best :!:
Rich
- Tinman
- Town: perth
- Real Name: Stuart
sorry its been so long
iv fitted a new solenoid and accelorator pump
when i tried it i never sealed it up properly so i think it is leaking, because it keeps dying at low rpm and i ran out of daylight.
HOWEVER, i had a spiffing idea, can the nikki carby and in its place twin 1.5inch SU carbies off a 1100cc mini of which i allready have one, this idea cam from my brothers who never have problems with there mini carbies due to the simplicity of them.
if i can get an identical carby to match my other SU i will go for it, well i do have one but apparently that mini needs it
the plan would be a plenum which bolts onto the original manifold into which the 2 carbs would bolt
ill try and get the nikki working enough so as to get the lux into the workshop, then i can work day and night on the SU idea, if it goes to plan it will be a one of a kind and seriously meen looking beast
ill keep you all posted but ill make up another topic.
- Tinman
- Town: perth
- Real Name: Stuart
heres the topic link
viewtopic.php?f=1&t=4303
